Power Bank Stops Charging: Huawei P8 Lite & Other Phones, Chinese Powerbank, 1A Output, Flashlight
abdul.98 5673 3
  • Protection circuit latches off under phone load
    #1 16610658
    abdul.98
    Help: 21
    Rate: 57
    I come to you with a little problem yesterday I bought a Chinese powerbank for the electronics only, then the original link was dead (0.5V).
    I soldered a much larger link to the system and everything is ok until the Huwawei p8 lite is connected, then the power bank starts charging and after a while it stops and the diode lightly lights (powerbank with a flashlight) disconnecting the phone does not give anything, only desoldering the cell and re-soldering allows for another landing. I checked on another phone and this problem is not only with my huwawei, I will add that on HTC desire 310 there are no problems and the power bank has a 1A output
  • #2 16610804
    szymon122
    Help: 302
    Rate: 761
    What link did you install?
  • #3 16610948
    Ronin64
    Help: 248
    Rate: 349
    Plug something in such and you should explain what's wrong. Probably the phone starts to draw a lot of current and the protection is activated.
  • Suggesting overcurrent protection as the cause
    #4 16611667
    abdul.98
    Help: 21
    Rate: 57
    I do not know a lot about the link, only that it was in an electric bike and my friend has already got rid of the housing, the link is 6.5cm x12.5cm x1.5cm (not counting these terminals, the link is 13cm high)
    Added after 33 [seconds]:
    Ronin64 wrote:
    Plug in something like that and you should explain what's wrong. Probably the phone starts to draw a lot of current and the protection is activated.
    unfortunately I do not have such a meter but I think it will not be a problem to check it with a multimeter
