Ozone generator - Which one should you choose for private use?
makaronmc 13098 10
What ozone generator should I choose for private use to ozonize a car interior and air conditioning?
For occasional private use in a car, a cheap ready-made ozonator with low output can be enough, but a DIY unit is often the better value if you want to save money [#16612643][#16612801] Ready-made units were said to cost about 500–700 PLN, while DIY or assembled-from-parts versions were around 250–300 PLN, and one example build cost about 130 PLN plus half an hour of work [#16612480][#16612801] That DIY example used a 230 V duct fan and was reported to work well for rooms, cars, carpets, and even a washing machine [#16612801] If you want the generator outside the car, you can reduce the outlet to the needed diameter and attach a duct/muffler hose into the cabin [#16612810][#16612821]
  • #1 16611938
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    Hello gentlemen...
    Which car ozone generator should you choose for private use?
    Greetings,
  • #2 16612038
    bubu1769
    Help: 1177
    Rate: 2377
    It depends on what you are going to use it for.
  • #3 16612141
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    Ozonation of the car interior / air conditioning.
  • #4 16612238
    bubu1769
    Help: 1177
    Rate: 2377
    Are you interested in the finished product or do you want to play folding?
  • #5 16612446
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    A finished product would be welcome, but if the price were much lower, I could consider folding
  • DIY ozone generator options and electrode considerations
    #6 16612480
    bubu1769
    Help: 1177
    Rate: 2377
    Ready ozonators with a cost of about 500-700 PLN, putty for self-assembly about 250-300 PLN, you can also combine yourself with the available parts, I built my WN ozonators from an oil furnace, a thermometer tube and a few rubbish that I had on hand, there is a lot to look for on the electrode.
    Here you have given two popular models https://www.elektroda.pl/rtvforum/topic3177215.html#15515747
    Here is a description of ozonators on ready putty https://www.elektroda.pl/rtvforum/topic3222554.html#15786057
  • #7 16612643
    Ireneo
    Help: 747
    Rate: 2474
    Ready to buy for 150 has only a small performance but it doesn't bother you.
  • #8 16612790
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    I need a generator to ozonise a car twice a year
  • #9 16612801
    mariuszp19
    Help: 311
    Rate: 410
    I did similar as in the post # 19 https://www.elektroda.pl/rtvforum/topic3222554.html#15786057
    Only a fan I put a 230V duct. The total cost is PLN 130 and a half hours of work. I have ozonized a room, a car, carpets (I have a dog), even a washing machine and the effect is amazing. I used to borrow some "traffic" for around PLN 150, it wasn't a problem.
  • #10 16612810
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    I would prefer to be able to attach a muffler so that the generator is outside and the muffler inside the car.
    You can also ozonate a washing machine? ;)
  • #11 16612821
    mariuszp19
    Help: 311
    Rate: 410
    I did it out of curiosity, if I would get rid of the bad smell. After this treatment, the washing machine smells like new. As for the drawer, you can do the reduction at the outlet to the desired diameter and attach the drawer.
The discussion revolves around selecting an ozone generator for private use, specifically for ozonating car interiors and air conditioning systems. Users express interest in both ready-made products and DIY options, with price considerations influencing their choices. Recommendations include ready-made ozonators priced between 500-700 PLN and DIY solutions costing around 250-300 PLN. Some participants share their experiences with homemade generators, highlighting their effectiveness in eliminating odors from various sources, including cars and washing machines. The possibility of using a muffler to position the generator outside the vehicle while directing ozone inside is also discussed.
