WSK175: Comparing Durable Crankshafts - gmoto.pl 55344 vs. 85164 vs. 81316
Ignacy.Kr 6426 6
  • #2 16405424
    TheGolibroda
    Rate: 14
    Maybe in turn. The best will be a shaft with sheet metal, not full counterweights. On full load the engine is much harder to "swing" to higher revolutions, the bearings wear out more, the seats in the crankcase are easier to form. I have a friend whose shaft twisted after 400 km on full counterweights. I have heard positive opinions about those with Duells connecting rods. Unfortunately, from what you have given you only have one to choose from, because the other 2 are shafts up to index 125.
  • #3 16406738
    Ignacy.Kr
    Thanks. The only problem is that you will not find a shaft with a duella connecting rod or a shaft with covered counterweights: /
  • #4 16406778
    E8600
    Help: 529
    Rate: 2520
    As for the covered counterweights, people plug the holes with a stopper and it improves the rotation. As for the shaft, I recommend regenerating the old one if it is not a complete corpse. If only the play on the connecting rod, pierce / replace the crank and it will be better than such inventions.
  • #5 16406792
    Ignacy.Kr
    The engine was lying in parts for several years, the shaft was cracked and I have no idea where it is. Does anyone know how much would it cost to regenerate the shaft along with sealing the holes?
  • #6 16406878
    E8600
    Help: 529
    Rate: 2520
    Regeneration depends on the condition of the shaft and a specialist / plant and you will do the sealing yourself because it is simple. The wine cork, epoxy glue and holes are matted with sandpaper, you degrease and paste.
  • Recommended company for crankshaft and crankcase refurbishment
    #7 16407725
    TheGolibroda
    Rate: 14
    I can recommend one company that deals with cylinder grinding, regeneration of karters and shafts for various motorcycles. If the shaft is not a complete corpse they will do it, upon customer request they can also provide connecting rod from other shafts like Yamaha. Like something pv. Once upon a time I had a case where I took a shaft from SSC 125 to a local company, which had already been reconditioned. Unfortunately, they refused the service.
The discussion centers on the durability of crankshafts for the WSK175 model, comparing three specific options: gmoto.pl 55344, 85164, and 81316. Participants suggest that crankshafts with sheet metal rather than full counterweights are preferable, as they reduce wear on bearings and crankcase seats. One user mentions a friend's experience with a full counterweight shaft failing after 400 km. Regeneration of an old shaft is recommended if it is not severely damaged, with advice on sealing holes using simple materials. A company specializing in the regeneration of motorcycle components is also mentioned, indicating that they can work with connecting rods from other brands if needed.
