Gerda Cylinder RIM6000: Pawls Fell Out After WD40 Application - Can It Be Fixed or Replaced?
czarnyblack 6951 3
  • #1 16613273
    czarnyblack
    Rate: 22
    Some time ago I unnecessarily sprayed WD40 on Gerda's lock and since then only problems. I tried to save it with a special Gerda lock spray and there was a slight improvement. I figured I'd take the zipper out and spit more nooks and crannies. Unfortunately, when I had already removed the insert and put the key in it, when I pulled it out, a 1cm barrel slipped out and 4 pawls fell out. I understand that now each of them has to go back to its proper place? A lot of these combinations will work out. Is there a chance to buy only one insert by specifying a number? I damaged what was inside the apartment. I was also in one store on Franciszkańska in Koszalin, but the Lord, having both inserts, was not able to sell me a new one because he claimed that there was no number there. He only said that the cost of the new one was PLN 400. So: Is there a chance to fix it somehow? If not, is there a chance to buy a specific insert for the same keys, specifying a number?
    Ps. The model is RIM 6000
  • #3 16614632
    czarnyblack
    Rate: 22
    It was too late to call them. Only on Monday can I try to contact you.
  • #4 16636207
    czarnyblack
    Rate: 22
    As if anyone were wondering, it is such a possibility. You have to send the key back to the Gerda representative and they use it to make a lock. I didn't have time for this and bought a new lock.
