Bosch PVS631FB1E Induction Hob: Interpreting and Resolving Error Code 0513 After Installation
Marek32ldz 93546 10
How can I diagnose and fix Bosch induction hob error 0513 after wiring it to a two- or three-phase supply?
Error 0513 indicates an incorrect electrical connection; in the confirmed case, the hob’s protective-earth/ground conductor was connected incorrectly. An electrician corrected the ground wire and the hob then worked normally [#17532936] Have an authorized electrician check the earth, neutral, phase conductors, terminal bridges, and the selected 1N/3N wiring diagram rather than repeatedly changing links yourself [#16894531] The 3N arrangement can use multiple phase inputs and provides full hob power, while a single-phase connection limits the load to about 3,700 W [#16980929]
  • #1 16893113
    Marek32ldz
    Rate: 19
    I bought a new Bosch induction hob and connected it according to the scheme for two phases:
    yellow-green to terminal 6
    neutral to terminal 4 and 5
    the first phase to terminals 1 and 2
    the second phase to terminal 3
    After switching on the three-phase fuse, E flashes on the left cooking zones.
    According to the instruction manual, I pressed the "sensor of the appropriate hotplate" and E disappeared, and the error code 0 5 13 or 0513 appeared, if you prefer. On Monday I will call the service, because the album is only a month old (I connected it today). What does this error mean and what will they mention to me? Will they fix it? I would prefer a new part or subassembly.
    PS.
    I connected as in the diagram from the first post, I have the same instruction.
    :arrow: Link Bosch PIE631FB1E - Connecting an induction hob without a protective conductor
    I tried to stick the link well, but I think it didn't work out, sorry.
    I have corrected TONI_2003
  • #2 16894269
    Piotr2608
    Help: 851
    Rate: 4488
    The hob was connected by an authorized person, i.e. an electrician, did you do it yourself without authorization?
    I am asking because no stamp in the warranty card = no warranty.
    ZimTech Piotr Zimny
  • #3 16894481
    Marek32ldz
    Rate: 19
    I have a seal, and on Wednesday someone will come from the site, I would like to know what kind of mistake is this?
  • #4 16894531
    mrhari
    Help: 836
    Rate: 3243
    Only in the link you have a diagram for 3 phases, not two.
    Look at this:
  • #5 16894997
    Marek32ldz
    Rate: 19
    I tried the third version without the bridge on terminal 1, but it doesn't change anything (the rest is the same, because there are no two separate neutral wires).
    Where is the 3 phase installation diagram? I can see L1 and L2 and there is an L1 bridge on jumper 1 and 2.
    On the back of the board there is a sticker with a diagram and there is only 1N and 3N, I can paste photos.
    Bosch PVS631FB1E Induction Hob: Interpreting and Resolving Error Code 0513 After Installation Bosch PVS631FB1E Induction Hob: Interpreting and Resolving Error Code 0513 After Installation
  • #6 16897837
    Marek32ldz
    Rate: 19
    Will someone explain to me why the scheme is 3N and the phase designation is only two L1 and L2?
  • #7 16977050
    arkady_
    in the picture you have the phases and numbers of connectors described - even the colors are nicely shown:
    1. gray
    2. brown
    3.black
    The colors above will tell you everything to an electrician with permissions :) .
    Have it connected to a licensed electrician, he will check your installation by the way, because maybe someone has mixed up the installation.
  • 3-phase wiring explanation and 3,700 W limit
    #8 16980929
    Piotr2608
    Help: 851
    Rate: 4488
    Do you expect lectures, tutoring or summaries of many years of study in one sentence?
    Do the terms: phase voltage - between phase, connection star - triangle say something to you?
    L1 - N phase voltage U = 230V
    L2 - N phase voltage U = 230V
    L1 - L2 phase-to-phase voltage U = 400V
    When connecting 3 phases, we get the full power of the induction hob.
    Connecting the plate to the 1st phase results in restrictions of the allocated power on the cooking zones.
    The maximum phase 1 load is approx. 3,700 W.
    ZimTech Piotr Zimny
  • #9 17190459
    Chalabala
    Rate: 66
    To eliminate the problems, I connected the Bosch hob directly to the box for a short time. I have a 3-phase installation. According to diagram 3, I used two. The voltages on the fuses are ok. Other household appliances work fine.
    However, when the fuses are turned on, a short circuit occurs and fuses are released from sockets throughout the apartment. This applies to all ports at once.
    When checking the circuits, I noticed that a small voltage of several dozen V appears on the ground in the box.
    After turning off the fuses, the oven shows a wrong connection error 5 0 13.
    What could this situation result from?
  • #10 17529697
    korek1
    Help: 5
    Rate: 61
    I have the same problem. What was the reason?
  • #11 17532936
    Chalabala
    Rate: 66
    Badly connected ground in the table. An electrician came, switched the wire and it worked ;)
The discussion revolves around the Bosch PVS631FB1E induction hob, specifically addressing the error code 0513 encountered after installation. The user connected the hob according to a two-phase wiring scheme but received an error indicating a potential issue with the installation. Responses highlight the importance of proper wiring, with suggestions to consult a licensed electrician to verify connections. Some users experienced similar issues, attributing the error to incorrect grounding or wiring configurations. The conversation emphasizes the need for correct phase connections to ensure the hob operates effectively and to avoid power restrictions.
