Long-term Load Capacity & Max Current for OWY 5x2.5mm2 Cable: Load Tables & Conditions
robertcb 30093 2
  • #1 16615493
    robertcb
    Rate: 34
    What is the maximum current that can flow for a long time with the OWY (żo) 5x2.5mm2 cable (cable, loose cable)
    I cannot find in the load tables for this cable under such conditions.
  • #2 16615515
    kokapetyl
    Help: 1787
    Rate: 2108
    Maybe something closer to this combination. For this cross-section it is about 20A minimum, and it also depends on the conditions.
