Dragon Alien KIT 220W TC MOD: Reviews, Performance, and OLED Display - Is it Worth Buying?
daamiaan94 25011 8
  • #1 16619935
    daamiaan94
    Rate: 63
    Hello, I am going to buy an e-cigarette as in the title, I am looking for an opinion on it, but on the internet it's hard to find a good one, there are a few reviews on YouTube, but I did not find out too much, maybe someone was in contact with this modem and would say something about him how it works, etc., please do not write that I choose something else, because I'm interested in only this equipment, but I do not know anything about it, only what I read from the parameters, not to look below parameters:
    - Power regulation from 6W to 220W
    - Powered by 2 × 18650
    - OLED display
    - Output voltage from 0.35V to 8V
    - Resistance support from 0.1 ohm to 3 ohms in power mode
    - 3 output modes: Hard, Normal, Soft
    - Software updates provided
    - Temperature control support for nickel, titanium and stainless steel wires
    - Resistance support from 0.06 ohm to 3 ohms in temperature control mode
    - Manual temperature settings TCR
    - A number of short-circuit and temperature protections
    - Gold-plated contacts with 24-carat gold
    - Loading and updating software via the microUSB port
    I expect answers, thanks greetings
  • #3 16619941
    daamiaan94
    Rate: 63
    Thanks, I have not noticed this site, and I am looking for a moment of opinion :)
  • #4 16621387
    daamiaan94
    Rate: 63
    I bought it this is the equipment, to be honest, after the reviews you can not deduce what is seen live, it is really mega, there is nothing to cling to, there are a lot of different options, I have not tested all yet because I have it only 1 day, has 3 modes of work, which is a really good idea, variable amount of Watt, ideally with the evaporator TFV 8, max 70-90 W, with a larger amount you can even get burned, you can easily change the brightness of the display, automatic blocking, there is also an option that very much surprise, you can set the maximum number of puffs eg 10, or 10 epetlocks after which you have to unlock / reset from the new maximum or disable this option, setting the temperature of heating the heater, we can also set ohms, batteries if they are high-end can withstand really long, finally 2 rechargeable batteries, the taste is very good in comparison to epets from the lower shelf, what can be said more, the equipment really recommendable, it is known that you have to spend some time with him to master all the options, the manual is in the set but honestly you can deal even without using it. If anyone had any questions I will answer without a problem.
  • #5 16642506
    PresidentPL
    Hello, I advise against the purchase of Dragon Alien for the following reasons. I bought an orange alder and after 3 months when I woke up in the morning and wanted to pull the sparks started to fly from it and the display system burned down. Well, I'm telling you, I was stupid, I was loading USB, because I actually loaded it at the beginning via the USB port. I was good speaking, I was very happy with him, this is another, this time a red one. Of course, the red does not even snap under USB, after which the history repeats even after three-fourths of use, so this time the mod works because the bush can be but the display fell completely and nothing to see. I wanted to report it somehow, give it to repair, but what turns out to be. First, complaints are only accepted in the US + the time for complaints is 3 months. Good, no? Both aliases were checked in terms of legality and both proved to be genuine, they did not say so after scraping. So I have 2 tfv8 atomizers and now I have to do it. I bought teslacigs toucha 150 and so far smiga. So after my experience with alien I strongly advise against this despite the fact that I was really happy with him, and he turned out to be a Chinese gown for 3 months. As you know, cheap is not, and so 3 months on a commodity that costs PLN 300 is a slight exaggeration. I recommend atomizer tfv8 because it is in the forefront of the world, however, I advise you not to buy fashion, unless you like to buy every 3 months a new one is as cool as possible. Greetings.
  • #6 16645004
    daamiaan94
    Rate: 63
    I charge via USB, I have LG HB6 rechargeable batteries (18650), nothing happens, my colleague also bought in the same place as me, it also loads via usb, it's possible that you've come across a faulty product, it's different "how will it go". Everyone wrote that after a week of use the paint goes away, I have nothing at all and I have it for about 3 weeks, I use it very often, paint like new, zero scratches or scratches, I keep it in my pocket which is susceptible to scratches. In case of what I have a guarantee, with the earlier "fashion" with the guarantee I did not have to wait long, 2 weeks :) depends on who is approaching the warranty and how it treats the customer. At home I have nothing to complain very quickly dealing with complaints, also as I say you had to hit a faulty e-cigarette :) greetings
  • #7 16881169
    Damoan
    Will vtc6 match it ??
    goldi74
    Help: 1367
    Rate: 1539
    They will fit. Watch out only for fakes because they happen with these links.
  • #9 16952210
    daamiaan94
    Rate: 63
    Returning after half a year break, for those who want to buy this is the "e-peta", I recommend it in 100%, I read for a long time about it, other forums, websites, wondering whether to buy, and can let it go? I made a good choice, some even wrote that the paint splatters, crap, just buy a silicone case, so far my e-pet looks like new, no paint does not want to scratch, as for the kartomizer, for such a mod, the cartomizer is too weak in order to get the maximum out of it, you have to change something better, in general, even the cartridgeizer is OK and meets my requirements when it comes to the heater, it can easily last up to 2 months, it also depends on what brand liquidy to him, we advise against dark color because 3 weeks and heater for rubbish, battery also fine, I bought new and decided to test, with intense use, a few puffs every 5 minutes and so throughout the day, I lost 1/4 of the battery, also here is nothing to cling to, there are also a lot of settings, which I have not tried yet, returning to her Eszcz for liquids, including e-peta is very good taste, for example, the taste of green apple, the same taste as eating a real apple, also for this price I recommend buying, certainly no one will be disappointed. :)
The Dragon Alien KIT 220W TC MOD has garnered mixed reviews from users. Positive feedback highlights its robust performance, versatility with three output modes (Hard, Normal, Soft), and the ability to adjust wattage from 6W to 220W. Users appreciate the OLED display, customizable settings, and the long battery life when using high-quality 18650 batteries. However, some users reported issues with the device's durability, particularly with the display failing after a few months of use, especially when charged via USB. Recommendations include using a silicone case to protect the device from scratches. Overall, while many users recommend the mod for its features and performance, caution is advised regarding potential quality control issues.
