Race Wreck Car Modifications: Installing Multiple Engine Coolers, Raising Suspension & More
AudioMonster 5136 2
  • #1 16620573
    AudioMonster
    Hello. I am thinking about starting in the "wreck race", therefore I intend to choose and prepare a car for this race, my questions are as follows:
    -Can I be able to install 2 or even 3 engine coolers?
    -How to raise the suspension by 10cm or more if needed?
    -Can you make a look in the front drive?
    - Will the alternator be able to handle 4 or 5 fans from the radiator?
    Thank you for the answers. Regards.
    robokop
    Help: 1763
    Rate: 6373
    for what purpose? Just one, if it is installed in a way that ensures its safety against damage in the event of a small bump and was protected from mud.
    By installing either diesel springs or by placing rubber inserts in the springs.
    Maybe turbo and nitro? Are you aware that the "rider" will prevent turning on a muddy track?
    mario 77
    Help: 66
    Rate: 335
    The radiator is enough with one that it is best to move it to a safer place than the front belt. For example, in IE there is a similar discipline except that it is more competitive than for fun (autograss) and most cars have radiators moved backwards inside the vehicle. As for the hinge, a friend above gave you the easiest and cheapest way. Searchlights for many cars can be bought, but parts of this type for motorsport will definitely exceed the value of the entire vehicle if we assume that the wreck-race are cars up to 1000 PLN. If you have the desire and manual skills and a spare chest, you can try to weld the differential. The car will be great to push back, but it requires experience in turns to be able to drive it.
