Laguna II 1.9dci 2004 Steering Column Lock Removal: Step-by-Step Guide, Photos, Videos
Krzysiek636 6288 10
How do I remove the steering column lock from a 2004 Renault Laguna II 1.9 dCi, and is it normal for the lock to move 0.5–1 cm on the column?
To remove it, the lock must be unlocked first, because the retaining screw will not come out, and that screw has a left-hand thread [#16620798] The play you describe does not sound fully normal; one reply said it looked like the lock was frozen halfway between fully extended and fully retracted [#16621036] After the screw was backed out about 1–1.5 cm, it still would not come free and only wiggled in place [#16625465] The only further suggestion given was that the screw may be spinning in place, so you may need to tap it with a hammer and a flat screwdriver to try to free it [#16625603] It was also noted that the black outer case is just a plastic housing [#16625680]
  • #1 16620758
    Krzysiek636
    Hello. I am a freshman here and I do not quite know how to navigate the portal and I have quite a burning matter ... Can anyone describe, step by step, have photos or a video, anything how to remove the steering lock in Laguna II 1.9dci 2004? For the hell, I don't know how to go about this contraption ...
    Ps. Should the lock itself move on the column? I am asking because mine is moving front - back within 0.5-1 cm. Is this a normal phenomenon?
    Best regards and thank you in advance for any advice
  • #2 16620798
    bodzio012
    Help: 161
    Rate: 780
    First of all, it should be unlocked because the screw will not come out. Remember that left thread.
  • #3 16621036
    Krzysiek636
    In fact, it is unlocked, i.e. it sounds as if it was frozen halfway between fully extended and fully retracted. Generally, the steering wheel ticks on every groove on the column when turning. Where is that left screw, in the sense where?
  • #4 16621153
    kamiloskop
    Help: 42
    Rate: 279
    Why do you want to replace it? You know that the second one must be clean or you have to solder the memory of the current one.
  • #5 16621192
    Krzysiek636
    Yes, I know it must be clean. I want to replace it because it is the reason for not starting the car. The problem is that I have no idea how to go about it ...
  • #6 16625426
    kamiloskop
    Help: 42
    Rate: 279
    Hmmm and she's blocked all the time or something. You know that when it is locked, it will be a problem to unscrew the screw
  • #7 16625465
    Krzysiek636
    Just today I found a little more time and started this contraption. To be honest, I had no idea whether it was blocked or not, although when turning the steering wheel - which was possible - there was a "chirping" from the lock, as if the lock pin was clearly "halfway" and caught on the keyways in the steering column. I got to the screw, which is not easy for a 2 meter person :) and remembering that it has a left-hand thread I unscrewed it. But ... Well, exactly but ... after unscrewing about 1-1.5 cm, the screw still does not go. He wiggles in place: / I have no idea how to get France out of here ...
  • #8 16625603
    kamiloskop
    Help: 42
    Rate: 279
    I don't want to mislead you, but I think a hammer and a good flat screwdriver to hit and go. The screw will probably be spinning in place. Let someone say something if he has a different idea
  • #9 16625679
    Krzysiek636
    Damn, even there is not enough with a hammer: / Unless you mean breaking the plastic housing ...
  • #10 16625680
    kamiloskop
    Help: 42
    Rate: 279
    I don't comment on this anymore, maybe someone has a different idea. The black case is just a plastic case
  • #11 16625691
    Krzysiek636
    Ok, thanks for the intention
The discussion revolves around the removal of the steering column lock in a 2004 Laguna II 1.9dci. The original poster seeks a step-by-step guide, including photos or videos, due to difficulties in understanding the mechanism. Responses highlight the importance of ensuring the lock is unlocked before attempting to remove the screw, which has a left-hand thread. Users share experiences of the lock being stuck or "chirping" during operation, indicating potential issues. Suggestions include using a hammer and screwdriver to loosen the screw, although concerns about damaging the plastic housing are raised. The conversation emphasizes the need for caution and the challenges faced during the removal process.
