[Solved] Bosch iron TDS1216 - how to disassemble the casing to get to the pump?
Piotr591121 5913 2
  • #1 16623251
    Piotr591121
    Rate: 12
    Please let me know how to get to the pump on the TDS1216 model?
    I unscrewed the back cover and two screws connecting the body to the base, as well as the cable attachment and the upper part of the housing. I don't want to leave, despite bending the two tabs. The back part goes off, but the front part holds firmly.
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    A screw under the pump buttons. A screw under the water filler flap hinge. The hinge is snap-on, but it comes off nicely. The keys are worse, please remove them sensitively because the debut in most cases ends with a broken pump stem.
    Kawa i Naprawa - Serwis AGD
  • #3 17174153
    Piotr591121
    Rate: 12
    Thank you for your help
