Xbox One Pad Issue: Left Analog Stick Drifts Upward - Used Controller Troubleshooting
nici 60966 4
  • #1 16629724
    nici
    Help: 266
    Rate: 979
    Hello, I bought a used Pad for Xbox and there is a small drawback.
    Namely, the left analog itself goes up (not always). It helps move down and it stays at the zero point. I improved February and nothing comes to my mind.
    Anyone have an idea?
  • #2 16630526
    pawciok354
    it's just the mechanism of the analogue used for me, but it always happens in a different way
  • #3 16635356
    Jan_Serce
    Rate: 11
    A sensible repair is to replace the "analog" (most likely use the original Alps), if it does not help, you may need to replace the a / c converter.
  • #4 16639413
    nici
    Help: 266
    Rate: 979
    Can he bathe him in IPA first?
    Added after 39 [minutes]:
    Ipa did not give anything, so I'm going to say a new part.
  • #5 16646091
    nici
    Help: 266
    Rate: 979
    I replaced the analog, it works. I advise against bathing, after which Dpad went crazy, washing and cutting the foil, basking helped. A 100 percent efficient pad.
