High Internet Bill Abroad: 28,000 KB Downloaded in 4 Minutes in Bosnia and Herzegovina
backspace777 4647 9
Can 28,000 KB be downloaded in 4 minutes abroad, and can it really generate a bill of 1000 PLN in Bosnia and Herzegovina?
Yes, 28,000 KB in 4 minutes is possible, and such a bill can happen in roaming outside the EU. 28,000 KB over 240 seconds is only about 117 KB/s, which is below 1 Mb/s and can happen even from ordinary web browsing or pages that load video or larger resources [#16633599] A forum reply also noted that T-Mobile’s 2016 Bosnia and Herzegovina tariff charged 4.03 PLN per 100 kB, so this amount of data can indeed add up to around 1000 PLN [#16633648] Another reply pointed out that EU free-roaming rules apply only within the EU, so they do not protect usage in Bosnia and Herzegovina [#16873730]
  • #1 16632961
    backspace777
    I have recently traveled through Bosnia and Herzegovina, which is not in the EU. I got a bill for 1000 PLN. After analysis sent by the mobile network, it turned out that for 4 minutes of using the Internet, I downloaded about 28,000 KB. Is it possible for me to download so much for such a short time? :|
  • #2 16632973
    korrus666
    Level 40  
    Help: 584
    Rate: 476
    This is not a problem with LTE transmission.
  • #3 16632978
    bogiebog
    Help: 2569
    Rate: 1530
    Yes possible
    roaming outside the EU, free American.
    let's assume 1 Eur / MB => 150 E * 4pln / E => 450pln
    at 2 Euro / MB you have 1000 PLN
  • #4 16632990
    sanfran
    Help: 966
    Rate: 3008
    And in Poland, is there sometimes an automatically set upper ceiling for using the Internet abroad at the level of 50 Euro? This should probably be set by default by the operator.
  • #5 16633094
    bogiebog
    Help: 2569
    Rate: 1530
    Provide sources for this statement other than heard.
  • #6 16633143
    sanfran
    Help: 966
    Rate: 3008
    In the UK this is because the Union has ordered. And regarding Poland this is the first link from the shore:
    http://komorkomania.pl/18819,roaming-w-ue-moz...symalne-wydatki-za-transmisje-danych#comments
    In what I gave it is not straightforward that it is set by default, therefore I ask.
    Because if something like this is the basis for a complaint.
  • 28 MB in 4 minutes is plausible
    #7 16633599
    Rognor
    Help: 78
    Rate: 120
    And what is he at?
    backspace777 wrote:
    for 4 minutes of using the internet, I downloaded about 28,000 KB. Is it possible for me to download so much for such a short time? :|
    Simple division 28,000: 240 = 116, (6) - only. This is a speed below 1 Mb / s.
    This can be achieved easily by browsing the pages on which a video will be launched, but also typical pages are 1-3 MB. However, there is a lot bigger, e.g. checking account on Play24 used to take 15 MB! For what? In real terms it was from 1 MB + 14 MB for some unnecessary flash. So your 28 MB is nothing.
  • #8 16633648
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    I checked the T-Mobile price list from 2016. For each 100kB they counted (in Bosnia and Herzegovina of course) PLN 4.03. So such a bill is possible.
  • #9 16635726
    makosuu
    Help: 369
    Rate: 371
    Rognor wrote:
    And what is he at?
    It depends on the speed. It doesn't change anything.
  • #10 16873730
The discussion revolves around a user's unexpectedly high mobile internet bill of 1000 PLN incurred while using data in Bosnia and Herzegovina, a non-EU country. The user downloaded approximately 28,000 KB in just 4 minutes, raising questions about the feasibility of such data consumption in a short time frame. Responses indicate that high data usage is plausible, especially with roaming charges outside the EU, where costs can reach up to 2 Euro per MB. Users also mention that certain mobile operators may impose automatic spending caps for data usage abroad. The conversation highlights the importance of understanding roaming charges and data consumption rates, particularly in non-EU regions.
