Installing Magneti Marelli LPQ080 Daytime Running Lights in Opel Vectra C lift 1.9CDTI
10482 8
  • #1 16633507
  • #2 16633532
    andrzej20001
    Help: 1574
    Rate: 6645
    How do you connect under the lights will turn off after 10 seconds. Lights up again later when you fire up. Blue under positional. How the lamp does not work for a complaint
  • #3 16633546
  • #4 16634000
    daniel_lhr
    Rate: 31
    I had the same with quinols, I added some resistors and capacitors I don't remember exactly and it works.
  • #5 16634056
  • #6 16634513
    andrzej20001
    Help: 1574
    Rate: 6645
    You bought lamps for 200> PLN, advertise them. They have to walk as I wrote you.
  • #7 16635019
  • #8 16635847
    daniel_lhr
    Rate: 31
    It's best if you turn off checking the light bulbs completely, it would not be a problem. Umnie and so are the LEDs on stops and I have an error on the board. I think CBs interfere with these impulses.
  • #9 16636308
✨ The discussion revolves around the installation of Magneti Marelli LPQ080 daytime running lights in an Opel Vectra C lift 1.9CDTI. The user seeks guidance on connecting the lights, facing issues with LED blinking due to CAN bus interference. Various solutions are proposed, including using resistors and capacitors, and ultimately, the user resolves the issue by employing a universal 12V relay to prevent the CAN bus from sending interference signals. The relay setup allows the LEDs to function correctly without blinking when the parking lights are activated. The conversation also touches on the possibility of disabling bulb checks in the CAN bus system to avoid errors.
