Quiet 230V electric winch for wall-mounted lift bed 35-40 kg
Pawell1891 3615 2
  • #1 16633747
    Pawell1891
    Hello, does anyone know which 230V electric winches run quietly? What I mean is that the motor should not make any noise, because I need such a winch for a bed that is lifted onto the wall. The bed weighs about 35-40 kg. I bought a dragon 125/250 kg, but screwed to the wall it makes too much noise.
    Thank you in advance for your feedback.
    czareqpl
    Help: 196
    Rate: 580
    Consider fitting the winch through vibration isolators. To start with, try bolting it through thick pieces of rubber to the wall. If that doesn't work then I would try a two-stage vibration isolator. For this you need a decent piece of stiff rubber that can withstand the weight of the bed.
  • #3 16634023
    Pawell1891
    Thanks for the hint with this rubber or vibration isolator, I will use a belt instead of the steel cable. Best regards
