Super Power Jack Actuator: Remote Control Issue - How to Achieve Smooth Gate Opening & Closing
Bozena12345 10437 18
How can I make my Super Power Jack gate open and close with one remote button press instead of holding the button down?
Set the Chinese two-relay controller to “change of state” (toggle) mode instead of monostable mode, so one press latches a relay and the next press switches direction [#16642296] If your board has a jumper or mode setting, check the manual and put it in the correct position; if it has no change-of-state option at all, the controller itself is the wrong type and should be replaced or returned [#16642314][#16642853] Another thing to try is reducing the amperometric/overload protection sensitivity with the small adjustment knob, because too much sensitivity can make the controller stop normal operation and require repeated presses [#16644336] Incorrect actuator limit-switch settings are not the main cause here, since with wrong limit switches the actuators would typically not work at all [#16642916]
  • #1 16634041
    Bozena12345
    I have a problem with Super Power Jack cylinders. For the gate to close or open I have to keep pressing the button on the remote control. I am asking for advice. What should I do to make the gate open and close smoothly?
  • #2 16634911
    kamo502
    Help: 24
    Rate: 140
    What driver do you have for this?
    Chinese on two relays?
  • #3 16642242
    tami272
    Rate: 29
    yes chinese on two relays. What advice do you do?
    Added after 11 [minutes]:
    I have the same problem . What to do with this ?
  • #4 16642296
    kotbury
    Gantry automation specialist
    Help: 2102
    Rate: 3634
    If you bought something with an antenna rolled up in a pigtail sold for a ... o by e ...... them and others then you can set jumpers in 3 modes (monostable, bistable, change of state) - you have probably set monostable mode you have to switch to the mode called "status change" by sellers. In this mode, after successive presses of one remote control button, one of the relays closes permanently, the other opens - and so on.
    And if you bought one that has no status change option and only has mono and bistable mode, buy one that has this status change.
  • #5 16642309
    tami272
    Rate: 29
    How to do it ?
  • #6 16642314
    kotbury
    Help: 2102
    Rate: 3634
    READ THE MANUAL and put the jumper on properly.
  • #7 16642317
    tami272
    Rate: 29
    There is nothing about this in the instructions
  • #8 16642327
    kotbury
    Help: 2102
    Rate: 3634
    Such?
    If not, scan and give the instruction because it is more interesting invention than the above ....
    • st4.pdf (51.16 KB) You must be logged in to download this attachment.
  • #10 16642853
    kotbury
    Help: 2102
    Rate: 3634
    In fact - there are no configuration options (by the way, I see something like this for the first time but enterprising Poles are still working and will soon import the entire cross-section of Chinese technical thought ...).
    It remains to molest the seller - remote sales = unconditional exchange or return of goods within 2 weeks, the guest should also recognize the warranty claim ...
  • #11 16642874
    kortyleski
    Help: 957
    Rate: 3860
    It should be added that when setting the change of state, the limit switches in the motors should be set correctly
  • #12 16642916
    kotbury
    Help: 2102
    Rate: 3634
    In this case, with the wrong setting of the limit switches, the servomotors would not work at all (the limit switches in these servomotors permanently cut off the engine power supply and only the change of polarity brings the motor back to life) - that is the fault on the "central" side.
  • #13 16642941
    tami272
    Rate: 29
    In short, ask the seller to replace the driver or advertise all equipment.
    Thank you for your help . greetings
  • #14 16643056
    kortyleski
    Help: 957
    Rate: 3860
    kotbury wrote:
    In this case, the actuators would not work at the wrong limit settings
    Unless they are set to a range larger than the gate has a swing. Then something will break ...
  • #15 16644199
    tami272
    Rate: 29
    Kródko. Will this driver what I got in the set will work correctly or not ?????
  • #16 16644336
    kotbury
    Help: 2102
    Rate: 3634
    There will be but some patience:
    Now one more thing occurred to me - try to reduce the sensitivity of the amperometric protection with this famous "small knob" from the manual. It may be - that the sensitivity of the protection is too high from the very beginning (after all, one output pulls two servomotors) - turns off normal operation and by constantly pressing the remote control, you force the controller to operate in an emergency.
    If maneuvers adjusting the security sensitivity do not work (for starters try extreme positions and the potentiometer looks multi-turn i.e. you need to wind up) - consider contacting the seller and replacing the equipment.
    And what the previous speaker stubbornly mentions - that is, the correct setting of the limit switches on each actuator - is the next and final stage of adjustment.
  • #17 16644430
    tami272
    Rate: 29
    It is true that I already did as you write but I did not try it in the extreme positions of the overload sensor. I will do it tomorrow and let you know.
    Added after 9 [hours] 14 [minutes]:
    Hello. I did as you wrote. Unfortunately no reaction.
  • #18 16655323
    tami272
    Rate: 29
    Hello all. I installed a new driver and the gate works ok. I have only a question I want to install the second antenna because what is too weak. I want to buy one placed only on the pole where to connect it. Can I cut the antenna that is in the controller (spiral) and solder in series what I buy. Is it possible and will it work?
  • #19 16655636
    kotbury
    Help: 2102
    Rate: 3634
    Well - such a risk from the PRC
    I have only a question I want to set up a second antenna because the one that is too weak
    In general, desolder the spiral (or cut it close to the board and leave as short a piece of wire as a pin) - and solder instead (or to this pin) the middle coaxial cable. Leave the screen unconnected or, if there is a wide, obvious mass field nearby - solder the screen to it.
    Or another way - straighten this spiral, set it as "vertically" and if it has a different length - cut to exactly 16.5 cm - it should improve the range a lot.
The discussion revolves around issues with the Super Power Jack actuator system, specifically regarding the need to continuously press the remote control button for gate operation. Users suggest that the problem may stem from the driver configuration, particularly if it is set to monostable mode instead of the desired status change mode. Recommendations include checking the jumper settings, ensuring limit switches are correctly configured, and adjusting the sensitivity of the amperometric protection. Some users have successfully resolved the issue by replacing the driver, while others are exploring antenna modifications to improve remote control range.
TL;DR: If your Super Power Jack gate moves only while holding the button, switch to a toggle/state-change controller and set limits; for weak range, “cut to exactly 16.5 cm” antenna length helps. [Elektroda, kotbury, post #16655636]
Why it matters: This FAQ helps DIY owners fix stop‑start motion and poor remote range without unsafe hacks, fast.
How do I fix a gate that moves only while I keep pressing the remote?
Your board is acting in monostable mode. Use a controller with a "status change" (toggle) mode so one press starts and the next stops/reverses. Many two‑relay RF boards have jumper‑selectable modes. If your unit lacks toggle mode, replace it with one that supports it. [Elektroda, kotbury, post #16642296]
My Chinese two‑relay driver has no jumpers—will it ever work smoothly?
If the board offers no configuration options, you cannot enable toggle behavior. Users report such boards need replacement or return to the seller to achieve proper one‑press open/close operation. [Elektroda, kotbury, post #16642853]
How do I change modes on these RF relay boards?
Locate the mode jumpers and set from monostable to the seller‑named “status change” mode. In this mode, each press toggles a relay state for hands‑free travel. “Set jumpers in 3 modes.” [Elektroda, kotbury, post #16642296]
What does “status change” (toggle) mode mean on a gate controller?
Each press of the same remote button latches a relay on or off. One press commands open; a later press commands close. This avoids holding the button during travel and enables smooth automation. [Elektroda, kotbury, post #16642296]
How do I stop emergency ‘stepping’ caused by overload protection?
Turn the small amperometric‑protection knob through its full range. It is multi‑turn, so wind it to both extremes to test. Over‑sensitive settings can trip during normal motion and force you to keep pressing the remote. If no change, consider replacement. [Elektroda, kotbury, post #16644336]
Do I need to set the limit switches before daily use?
Yes. Set the open and close limits correctly on each actuator before enabling toggle mode. Incorrect limits can cause stalls or damage. “The limit switches should be set correctly.” [Elektroda, kortyleski, post #16642874]
What happens if limit switches are set beyond the gate’s swing?
If limits exceed mechanical travel, the system may drive past safe points and break components. This is an edge case that causes physical damage rather than just stopping movement. [Elektroda, kortyleski, post #16643056]
Could bad limit switch settings be why my actuators won’t move?
On these actuators, internal limit switches cut motor power until polarity reverses. If the controller is at fault, actuators may appear dead despite correct wiring. This points to a central control issue, not only limits. [Elektroda, kotbury, post #16642916]
The gate still stutters after adjustments—what should I replace first?
Replace the driver/controller. A user resolved identical symptoms by installing a new driver; normal open/close returned immediately. Keep the actuators and wiring if they test fine. [Elektroda, tami272, post #16655323]
How can I improve weak remote range on this kit?
Desolder or cut the spiral antenna near the pad and solder a 433 MHz wire or coax center to that point. Leave the shield unconnected or bond it to a nearby ground plane. Cut the vertical radiator to 16.5 cm for best reach. “Cut to exactly 16.5 cm.” [Elektroda, kotbury, post #16655636]
Where exactly do I connect an external pole‑mounted antenna?
Use coax. Solder the center conductor to the PCB’s antenna pad where the spiral attached. Leave the shield floating or tie it to a broad ground area, if present. Route to your mast antenna. [Elektroda, kotbury, post #16655636]
Is continuous‑press operation normal for these actuators?
No. Continuous pressing indicates monostable mode. Gates should use a toggle (“status change”) mode so a single press completes a cycle. If your board cannot toggle, choose a different controller. [Elektroda, kotbury, post #16642296]
What is a “two‑relay Chinese driver” in this context?
It’s a low‑cost RF receiver board with two relays and jumper‑selectable modes: monostable, bistable, and status‑change. For gates, the toggle/status‑change mode is required for one‑press travel. [Elektroda, kotbury, post #16642296]
The manual doesn’t mention mode settings—what should I do?
Some kits ship with minimalist manuals and no jumpers. If the documentation lacks mode guidance and the PCB lacks jumpers, replacing the controller is the practical fix. [Elektroda, kotbury, post #16642853]
Quick 3‑step checklist to get smooth opening and closing?
  1. Turn the overload knob through its full multi‑turn range and test.
  2. Verify and set both actuator limit switches accurately.
  3. If symptoms persist, contact the seller or replace the controller. [Elektroda, kotbury, post #16644336]
Do these boards really have three operating modes?
Yes—three distinct modes are cited: monostable, bistable, and a state‑change toggle. Use the third mode for gates. This “3 modes” detail also explains why continuous‑press behavior appears with the wrong setting. [Elektroda, kotbury, post #16642296]
