Solar Panel Installation Fitter: Job Insights, Pros & Cons, Work Experiences
22350 12
What is the work of a solar panel installer like, and is it worth taking the job?
The job is mainly physical roof work, often with travel, climbing equipment, and safety ropes, so it is worth considering only if you are comfortable with heights [#16634965][#16635840][#17182539] One installer said the work is mostly delegation, ground-mounted systems for private customers are relatively rare, and carrying panels up to the roof is the most tedious part [#17182539] The actual assembly is described as fairly straightforward, like building Lego blocks, while the cable work involves drilling, forging, or digging, and inverter programming/software updates are the most pleasant tasks [#17182539] People compared the experience to electrician work such as lightning protection or antenna mounting, saying the skills and experience can pay off later [#16634994] Pay reports vary: one former worker mentioned about 1,300 PLN net in 2015, while another said 500 PLN per kW would not be worth it unless the installation is larger and access is convenient [#17182539][#16635908] If the employer does not provide ropes and other protection, workers said you should refuse the job [#17182539]
  • #1 16634925
  • #2 16634965
    osiniak75
    Help: 350
    Rate: 544
    If you are not afraid of heights, why not?
  • #3 16634973
  • #4 16634994
    osiniak75
    Help: 350
    Rate: 544
    Of course, yes, I do not personally work on panels, but I think that it is not much different from the work of an electrician when laying lightning installation or mounting antennas. The experience gained will definitely pay off one day.
  • #5 16635840
    Lisciasty
    Help: 19
    Rate: 123
    After assembling my installation, I find it hard work. And climbing equipment is essential:>
  • #6 16635908
    Jan_Werbinski
    Help: 76
    Rate: 671
    For 500 PLN from kW I would not do that. Unless some larger installation with convenient access and 250W panels / pcs.
  • #7 16636594
    wnoto
    Help: 58
    Rate: 744
    And these are the rates for the fitter? Is there also a dayday or rather "monthly"?
  • #8 17178427
    ablativus01
    Rate: 14
    I am conquering the topic because I got a job offer during assembly and I never did anything at heights and I do not know whether to go about it or look for another more mundane, I do not have fear of height but I never walked on the roof.
  • #9 17182539
    nitros66
    Help: 58
    Rate: 39
    I worked only a month in the industry in a company from Tarnów. I didn't like the boss who probably had some kind of stalking mania - every boy wanted to rob him or spy on him and compel the loyalist for 3 years after any training, the guy had a lot of staff rotation - I switched from PV to electrical installations which I do not regret.
    Returning to the question - PV installer - work mainly in delegation, mostly physical on roofs - ground constructions are relatively rarely mounted at private investors - I installed one on Mazury, the other roofing. The installation consists of Lego blocks, only the power cable is associated with forging / drilling / digging. Bringing panels onto roofs is the most boring and persistent - you need to cool down stairs / scaffolding. I also dealt with programming inverters and updating softens - this part is the most pleasant. The rate at the former employer (2015) was from PLN 1,300 up on hand.
    PS. If the employer does not provide ropes and security, then you are refused to work - you have to have equipment and full stop.
  • #10 18778230
    ŁukaszPawik
    Recently, I am interested in changing the industry to a solar fitter, but at the beginning I would like to know what it looks like. Maybe someone has a friend who could say more about this or recommend a good company.
    I count on your help thank you in advance
  • #11 18782528
    Marcel Sikoraa
    I worked as a panel fitter, physical work is a bit demanding but not terrible. Earnings at a very good level, if it hadn't been for my move to Krakow, I would have stayed in Lift Up, it was a company where I had worked a few years and if it hadn't been for that, I would have stayed. And that I am issuing opinions now, I can recommend it with a clear conscience
  • #12 18783907
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    For a week, please?
  • #13 18783917
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @ nitros66 Slave :cry: :cry: Hunger rate.
The discussion revolves around the experiences and insights of individuals working as solar panel installers. Key points include the physical demands of the job, particularly the need for climbing equipment and safety measures such as rope protections. Participants compare the work to that of electricians and highlight the importance of experience in the field. Earnings vary, with some expressing dissatisfaction with rates, while others report good compensation. The work is primarily conducted on rooftops, with ground installations being less common. Personal anecdotes reveal challenges such as dealing with difficult employers and the monotony of transporting panels. Recommendations for companies and job opportunities are also sought.
TL;DR: Solar PV fitting is roof‑based, travel-heavy work; pay varies and one installer wrote, "For 500 PLN per kW I would not do that." [Elektroda, Jan_Werbinski, post #16635908] Why it matters: If you’re weighing a PV career, you need realistic pay, safety, and workload expectations to decide if it fits you.
What does a solar panel fitter actually do day to day?
Expect roof work, mounting rails and panels, routing and securing DC cabling, drilling/forging runs, and staging panels. Many crews also program inverters and apply firmware updates. Travel for delegated jobs is common. One installer said, "The installation consists of Lego blocks," highlighting repeatable assembly with care. [Elektroda, nitros66, post #17182539]
Do I need to be okay with heights to do this job?
Yes. You work on roofs frequently. A veteran’s guidance was simple: if heights don’t bother you, this path is reasonable. Comfort on ladders, scaffolding, and sloped surfaces matters for both speed and safety. If heights are an issue, consider ground-mount crews or electrical roles off the roof. [Elektroda, osiniak75, post #16634965]
Are ropes and fall protection provided—or do I bring my own?
Employers should provide fall-arrest gear and enforce its use. If a company declines to supply ropes, anchors, and PPE, walk away. That’s a safety red flag and a liability risk. "If the employer does not provide ropes and security, then you are refused to work." [Elektroda, nitros66, post #17182539]
Is this work physically hard?
It’s demanding but manageable with the right methods. The grind is carrying panels and racking up ladders or scaffolding. Good lifting plans and team coordination reduce strain. One installer put it plainly: "Climbing equipment is essential." Prioritize safe handling and rest rotations in hot weather. [Elektroda, Lisciasty, post #16635840]
How is pay structured—per kW, per day, or monthly?
Models vary by company. Some offers quote per‑kW install pricing; one comment said "500 PLN per kW" and rejected it as too low. Others pay day rates or monthly salaries. Clarify scope (roof type, access, inverter setup) before accepting per‑kW terms. [Elektroda, Jan_Werbinski, post #16635908]
What were entry wages like in earlier years?
One installer reported a 2015 take‑home starting from 1,300 PLN. View this historically, not as today’s market rate. Confirm current local pay, travel allowances, and overtime rules in your contract. If a firm undercuts safety or compensation, decline the offer. [Elektroda, nitros66, post #17182539]
What panel sizes and loads should I expect to handle?
Expect modules around 250 W in some legacy or budget jobs, with higher wattage on newer sites. Plan for repeated lifts, safe grips, and wind‑aware handling on roofs. Use team carries and staging platforms to prevent drops and back injuries. [Elektroda, Jan_Werbinski, post #16635908]
Do installers travel a lot?
Yes. Many teams work in delegations, moving from site to site for residential roofs. Ground mounts for private clients appear less often. Ask about travel per diem, vehicles, and overnight policies before you sign. [Elektroda, nitros66, post #17182539]
What tools and gear will I use as a beginner?
Fall‑arrest kit (harness, ropes, anchors), ladders or scaffolding, cordless drills, torque tools, and cable management tools. You may also interact with inverter software for setup and updates. Ensure the employer provides compliant PPE and training. [Elektroda, nitros66, post #17182539]
I’ve never worked on a roof—should I even try this job?
If you’re not afraid of heights and commit to safety training, it’s viable. Start under experienced supervision on access and tie‑off basics. Move to more complex roof work as your confidence grows. Decline any job that cuts corners on safety. [Elektroda, osiniak75, post #16634965]
What employer red flags should I watch for?
Walk away if ropes and security aren’t provided. Be cautious with firms showing high staff turnover, excessive control, or restrictive loyalty demands after basic training. Prioritize documented safety procedures and fair contracts. [Elektroda, nitros66, post #17182539]
How do I lift and stage panels on a roof safely?
  1. Secure fall protection and anchors before moving any materials.
  2. Stage panels via ladders or scaffolding with two‑person carries and rest points.
  3. Land panels near the array, then wire and program the inverter after mounting. "Bringing panels onto roofs is the most boring and persistent"—plan time for it. [Elektroda, nitros66, post #17182539]
Are ground-mounted systems common for residential clients?
They occur but are relatively rare compared with roof installs in private projects. Expect most of your residential work to be roof‑based, with ground frames appearing occasionally. Confirm access and terrain before quoting labor. [Elektroda, nitros66, post #17182539]
What part of the job do installers often enjoy?
Programming and commissioning inverters, including software updates, often feels like the most pleasant phase after the physical mounting. It’s a good skill to develop early. [Elektroda, nitros66, post #17182539]
Who tends to thrive as a solar panel fitter?
People comfortable with heights, steady with tools, and disciplined about PPE. One fitter called the work demanding but not terrible and said earnings were very good at a solid company. Fitters who relocate sometimes change roles for personal reasons. [Elektroda, Marcel Sikoraa, post #18782528]
