Ignition switch Skoda Felicia 1.3 98 - replacement - immobilizer
MonikaMarcin 8712 6
  • Ignition switch fault causing starter and brake lamp issues
    #1 16797390
    MonikaMarcin
    Help: 32
    Rate: 103
    I have a problem with the ignition;
    Symptoms (0-1-2-3):
    - in the direction of 0 to 2 everything looks normal
    -starting at 3 sometimes starts sometimes at all (lights unchanged)
    - if you start the engine and release the key to 2, you can still hear the starter
    no load, brake light on
    - gentle "return" with the key and the starter turned off, the brake is on
    - returning "almost under item 2 the brake lamp turns off.
    And we can go. ;-)
    Has anyone ever had such "eggs"?
    I know the key switch to replace. :-(
    After defeating the screws and "broken heads" (still ahead of me) waiting for me
    electronic problem - immobilizer.
    I read on the forums that there will be a problem with the computer.
    Truth?
    How to get rid of the problem in "home conditions"?
    Replacing a complete ignition with keys is not enough?
    Regards.
  • #2 16797454
    moto-kord
    Help: 137
    Rate: 505
    You have to replace the ignition cube.
  • #3 16797862
    MonikaMarcin
    Help: 32
    Rate: 103
    I am buying an ignition cube with an immobilizer. I mention.
    Fires? Anything else to do? Comp?
  • #4 16797867
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    MonikaMarcin wrote:
    I buy the ignition cube
    The "ignition block" as well as the "ignition box" is something completely separate from the "immobilizer".
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #5 16797877
    MonikaMarcin
    Help: 32
    Rate: 103
    So replacing the cube and putting the transponder in the keys after the problem?
    Added after 7 [minutes]:
    https://www.google.pl/url?sa=i&rct=j&q=&esrc=...%2F%2Fwww.kupsito.sk%2Fi%2F6565399975%2FZAPA% 25C4% 25BDOVANIE_COMPLETE_ 25A0KODA_FELICIA_Felicja_98_SLOVENSK% 25C5% 2581% 25C3% = & psig AOvVaw2N7dWrnc Nx94RCSysqVdf &-paragraph = 1509784561104104
    Added after 37 [seconds]:
    is it such a miracle?
  • #6 16799130
    moto-kord
    Help: 137
    Rate: 505
    You replace the ignition block itself. DO NOT move the transponder, coil, key.
    Added after 5 [minutes]:
  • #7 16802004
    MonikaMarcin
    Help: 32
    Rate: 103
    Thanks.
    Now I know what it looks like "from the inside".
    Exchanged and plays like this doll :-)
The discussion revolves around issues with the ignition switch of a Skoda Felicia 1.3 from 1998, specifically related to symptoms indicating a malfunctioning ignition system. Users suggest that the ignition block (or cube) needs to be replaced, emphasizing that this component is separate from the immobilizer system. It is noted that replacing the ignition block does not require moving the transponder or key coil. The author confirms successful replacement of the ignition block, resolving the starting issues.
