[Solved] Tauron Tech Recommendation No. for Unsealing Measurement & Billing System - Numerator Board
Tomek12351 24549 5
  • #1 19048715
    Tomek12351
    Rate: 34
    Hello, I have to submit an application for permission to unseal the measurement and billing system and there is a field:
    No technical recommendations, unfortunately I have no idea what to enter there, can you ask for help?
    It's about a numerator board.
    Thank you greetings
    stanislaw1954
    Help: 2013
    Rate: 4675
    Such no. it would be on a 'paper' that some inspector issues to recommend -force repair. And what is the reason to unseal the measuring system?
  • #3 19048768
    Tomek12351
    Rate: 34
    The reason is the desire to replace the meter board
    stanislaw1954
    Help: 2013
    Rate: 4675
    Well, it will not be such a number, unless the power industry uses its codes to mark the scope of work. Maybe there is a field to fill in with words, then enter e.g. replacement of a wooden meter board with the current one, or something similar.
  • #6 19048791
    Tomek12351
    Rate: 34
    Everything was explained by colleagues, thank you!
