Mercedes W211 2005: Driver's Window Control Issue - Mechanical or Electrical?
gdkj 7047 13
Why does the driver’s window in a 2005 Mercedes W211 only hum when I press the switch, even though the motor runs on a 6V battery and the glass sometimes moves if I help it?
The fault was electrical, not the window mechanism: the window started working again after the damaged cable was bypassed, and the bad section turned out to be the power cable connection near the fuse socket rather than the hinges [#16658770][#16668195] A good first check is whether proper power and ground are reaching the motor’s thick wires, for example with a test bulb, because a broken feed in the door/body wiring can make the module only hum [#16647304][#16647404] The fact that the motor ran on a 6V battery and the glass only needed help suggested a supply problem or high resistance in the wiring path, not a clearly seized regulator [#16658770][#16668195]
  • #1 16647239
    gdkj
    Help: 49
    Rate: 84
    Hello, cars are not my domain so please take that into account.
    Mercedes W211 year 2005, the ability to move the left window disappeared, the only reaction to the buttons is a short humming in the control module in the door, because replacing the relay did not change anything, I wonder if the problem lies in the mechanics and too high engine current, I was controlling the glass with a 6V battery and In motion, the current oscillated around 2A and increased to 6A when stopped. The glass moves, but sometimes it needs help.
    Please let me know if such a low ratio of braking current to work is a good clue to draw a conclusion about the need for maintenance / replacement of windshield mechanics.
    Greetings.
  • #2 16647304
    andrzej20001
    Help: 1578
    Rate: 6669
    There is power on the thick motor wires? Measured light bulb
  • #3 16647310
    gdkj
    Help: 49
    Rate: 84
    This simple test did not come to my mind, but when the engine is disconnected, there is no humming.
    If the voltage on the engine went, I understand the mechanic? Light bulb, how many watts to give?
    Greetings.
  • #4 16647311
    andrzej20001
    Help: 1578
    Rate: 6669
    How many wires do you have on the engine? Provide a photo
  • #5 16647399
    gdkj
    Help: 49
    Rate: 84
    Two thick and probably 4 thin ones go to the motor assembly, they are limit switches or a position encoder, I do not know because I did not dare to take it apart. In electronics, there is a sheet metal shunt from which the current flowing through the motor is monitored. Hence, I wonder if the motor current is too high.
    At the moment I only have the control module.
    andrzej20001
    Help: 1578
    Rate: 6669
    Thick is power plus and mass. I bet one isn't there. Check the door grommet - body.
  • #7 16647424
    gdkj
    Help: 49
    Rate: 84
    Thick on the connector I indicated are the motor wires. Power is supplied to the pins on the other side of the relay. Thanks for your willingness, but I need info on the intensity of the current flowing through the engine while the window is moving. I am asking because I have no practice and I can not judge if the glass mechanism is too heavy for the electronics to react like that.
    Greetings.
  • #8 16647580
    andrzej20001
    Help: 1578
    Rate: 6669
    If the engine runs on a 6V battery, think ... and it should be> 12V after firing. Main + - and 4 thin control power supplies from the panel. How electronics clicks and wants to move and there is nothing ...
  • #9 16648474
    gdkj
    Help: 49
    Rate: 84
    I do not think, this board has a driver with buttons for all windows on two wires (something like 1wire) changed by the processor on the board and fed to the other windows that work. The power supply of the entire contraption through diodes is supplied from the socket after the relay, if there was no electricity there, I would not go through the other windows. For the sake of peace of mind, I will check it after unfastening the load, the relay does not buzz. I will plug a light bulb with a lower current and maybe I can determine at what current it goes crazy.
    Theoretically, the contacting power cord can be broken, but everything else works at this time, now I wonder if the diodes are not helping here.
    Greetings.
  • #10 16649976
    _Megamax_
    Help: 29
    Rate: 131
    Have you heard about something like thermal protection for a window motor. This car model has extensive diagnostics.
    For the computer with him.
    Such a dream, not even knowing which cable to what ...
    1wire in this car, you have only one thing - communication with the alternator.
  • #11 16650797
    gdkj
    Help: 49
    Rate: 84
    Thanks for the info, a simple information on how much power the engine consumes in an efficient system would certainly be helpful to assess if the problem is a computer, i.e. a workshop.
    Greetings.
  • #12 16658770
    gdkj
    Help: 49
    Rate: 84
    A colleague andrzej20001 bingo with the fact that the cable on the last line, the voltage was only weak, the bypass glass was started.
    Greetings.
    ps. I will close the topic in a few days.
    andrzej20001
    Help: 1578
    Rate: 6669
    Because that's what practice is for. :)
  • #14 16668195
    gdkj
    Help: 49
    Rate: 84
    The damage to the cable was not at the height of the hinges, only with the fuse socket welded.
    Regards and thank you.
The discussion revolves around a driver's window control issue in a 2005 Mercedes W211, where the left window fails to operate properly. The user reports a humming sound from the control module when attempting to move the window, indicating potential electrical or mechanical failure. Various troubleshooting steps are suggested, including checking the power supply to the motor, examining the wiring for damage, and testing the current draw of the motor under load. Responses highlight the importance of verifying the integrity of the wiring, particularly at the door grommet and fuse socket, as well as considering the possibility of thermal protection in the motor. The user ultimately identifies a damaged cable as the source of the problem.
TL;DR: W211 window hums but won’t move? A 6 V test is fine, but “it should be >12 V after firing.” Trace power/ground at the door, repair wiring, and re-test before blaming the relay. [Elektroda, andrzej20001, post #16647580]
Why it matters: This FAQ helps DIYers quickly decide if a W211 window fault is electrical wiring, control module, or motor, and how to verify it safely.
How do I fix a W211 window that hums but won’t move?
Check power and ground to the motor at the door first. The documented fix was repairing a damaged feed near the fuse socket, not replacing the relay. After restoring a solid supply, the window worked normally. “Humming” often means the module commands movement but the motor lacks voltage. Focus on wiring continuity and connections before parts swapping. [Elektroda, gdkj, post #16668195]
What current should a healthy W211 window motor draw?
In the cited case study, the motor drew about 2 A while moving and about 6 A at stall when powered by a 6 V battery. Use this as a reference trend rather than a factory spec. Excessive stall current or abrupt cutoff can also indicate binding or protection triggering. [Elektroda, gdkj, post #16647239]
How do I test motor power with a light-bulb load?
Unplug the motor connector and clip a 12 V test bulb across the two thick motor pins. Press the switch up/down. A bright, steady light indicates good supply; dim or flicker signals a voltage drop. This quick load test reveals weak feeds better than a voltmeter alone. [Elektroda, andrzej20001, post #16647304]
What do the thick and thin wires on the window assembly do?
Two thick wires carry motor power and ground. The additional thin wires serve position or limit sensing and control signaling within the door module assembly. Do not assume the thin leads can power the motor. Verify the heavy pair for voltage under load. [Elektroda, gdkj, post #16647399]
If the motor runs on a 6 V battery, is the mechanism OK?
Yes—if it moves on 6 V, the mechanism and motor are generally capable. The next step is verifying vehicle supply, which should be above 12 V with the engine running. “It should be >12 V after firing.” Check for drops across connectors, grommets, and splices. [Elektroda, andrzej20001, post #16647580]
Where do window wiring breaks occur on the W211?
Breaks often appear where the harness flexes, but this documented failure was elsewhere. The damaged conductor was near a welded fuse socket, not at the hinge area. Inspect both the door grommet and upstream fuse/connector zones to catch this edge case. [Elektroda, gdkj, post #16668195]
What does clicking or humming from the door module mean?
It usually means the module is commanding movement, but the motor isn’t receiving adequate power or ground. Low supply, a high-resistance joint, or protection limiting can prevent rotation. Verify voltage at the thick motor pins while activating the switch. [Elektroda, andrzej20001, post #16647580]
Does the W211 window motor have thermal protection?
Yes. The platform uses thermal protection to prevent overheating during overload or repeated operation. If it trips, the window may pause until the motor cools. Persistent tripping suggests binding or a voltage drop that increases current draw. [Elektroda, Megamax, post #16649976]
Can I use the car’s diagnostics to help with window issues?
Yes. This model supports extensive diagnostics. A scan tool can read door module statuses and faults, helping distinguish wiring loss from module or motor faults. Use diagnostics after basic power and ground tests to save time. [Elektroda, Megamax, post #16649976]
Is the driver’s switch panel using a 1‑wire bus?
No. In this platform, the 1‑wire reference relates to alternator communication, not the window switch network. The door electronics interpret switch inputs and drive the motor locally via the heavy wires. [Elektroda, Megamax, post #16649976]
How can I safely bypass power to confirm a wiring fault?
  1. Provide a known-good 12 V and ground directly to the two thick motor pins.
  2. Briefly energize in one polarity, then reverse for the opposite travel.
  3. If the motor runs, repair the weak feed or splice upstream and re-test. This confirmed a weak last-segment supply in the case study. [Elektroda, gdkj, post #16658770]
I replaced the relay and nothing changed—what next?
Stop replacing parts. Verify voltage and ground at the motor while commanding the window. The thread shows relay replacement did not help because the fault was a weak feed. Load-test the circuit and inspect splices and the fuse socket area. [Elektroda, gdkj, post #16647239]
What final repair resolved the issue in this case study?
Repairing the damaged power cable near a welded fuse socket. After restoring a solid feed, the driver’s window operated normally. This underscores the need to inspect beyond the door hinge area for intermittent or high-resistance faults. [Elektroda, gdkj, post #16668195]
What are symptoms of low voltage at the motor?
You may hear module humming or clicking, with little or no window movement. A bypass feed makes the glass move normally, confirming supply loss. Dim light-bulb tests at the motor connector also indicate voltage drop under load. [Elektroda, gdkj, post #16658770]
