Establishing Connection for Huawei B593 u-12 Router with Orange SIM Card
Marcin Kawa 10818 4
  • #1 16651170
    Marcin Kawa
    Rate: 8
    Hello, I will join the thread because I just bought this route, Huawei B593 u-12 and:
    Is there any idea why after inserting a plus card works without a problem, but poor coverage but after inserting an Orange card can not make a call? this lamp flashes green and after a moment it shines red (i.e. it has not established a connection to the network) even though it has 3 lines, i.e. better than with Plus simcard. Maybe he has a simlock on orange (although the seller on allegro ensures that the simlock is not)?
    Does anyone from other buyers of this router have a similar problem?
    I would like to add that both cards have put in my internet propeller cell - although I do not have LTE in the cell it worked. In the router, this new Orange card, from this promotion 100 giga for free per month if you register the address - the card from Plus is already several years old, can it make a difference? I do not give out to me but maybe they have changed something: /
    any ideas? please.
    Moderated By jimasek:
    I separated as a new thread - please do not clutter up old topics.
  • #2 16651226
    matek451
    Help: 4352
    Rate: 5808
    Ask the trader of this demobiler from T-Mobile on Allegro, he finally takes the money for something. You know my opinion about them. Try to get LTE phone and show screen from LTE phone with Network Cell Info application with Orange card. It will show signal parameters and BTS data. Test at home at the router site and outside? What is the location? The fact that 3G Orange works on the phone does not mean that it will be the same with LTE. At BTS, ie, Przemków, Wysoka 58 there is no confirmed LTE800 Orange. However, 3G works with UMTS900NetWorks. The same is true for Wilkocin BTS. What technology did you force on this B593, did you do 3G Orange testing? APN for Plus and Orange is the same or internet and it should be set to B593 regardless of whether it is 3G or LTE. Also show a screen from a 3G phone with Network Cell Info.
  • #3 16652108
    Marcin Kawa
    Rate: 8
    Well, the point is that even 3G does not work on the router - there is no connection / login to the network at all (because it means the red lamp is on).
    And since it connects on the phone, it should also be the router. Where there were options to choose "Auto" or Only LTE "or" Only 3G "then I checked each one by one and nothing: /
    I did not test outside because I have a range at home (plus and orange).
    Tests from Network Cell Info I will do again when I am there - for now I am not there.
  • #4 16653230
    prosiak22
    Help: 15
    Rate: 131
    and I'm shooting that it's APN's fault
    for orange, however, is with a slogan
    Apn internet
    o User name: internet
    o Password: internet
    o Authentication: normal
    If you do not connect with the plus it is not simlock because it is after the router with Tmobile.
  • #5 16697673
    Marcin Kawa
    Rate: 8
    prosiak22 wrote:
    Apn internet
    That's exactly what I gave, with the difference that I gave the password to the back of the router - and WORKS.
    This APN setting was enough.
