[Solved] Huawei B525s-23A Firmware: Unlocking Router for Plus Network & Software Compatibility
stasiekjunior 11532 2
  • #1 18247806
    stasiekjunior
    Rate: 41
    Hello. I have the above-mentioned router from the orange network (simlock), but I changed the operator to Plus. Is it possible to change the software so that I can continue to use it? Do I have to buy a different model without a lock?
    truski
    Help: 34
    Rate: 21
    Are you sure this router has a simlock or maybe you didn't change the APN in the router when you changed the sim card? If you have the option, insert a sim card from T-Mobile and if it does, you have no lock, only the wrong APN for the Plus network
  • #3 18248036
    stasiekjunior
    Rate: 41
    Thanks for the guidance. Indeed, the router does not have a blockade, but it automatically sets the ip 6 protocol after a manual change to Ip4 everything works as it should. Thanks for your help, the problem is solved.
