Innodisk 3ME SATA SSD 32GB Not Accessible: Unable to Format, RAW & Healthy- Win10 & USB Issues
andrz6 9810 12
Why does my Innodisk 3ME SATA SSD show as RAW and healthy but refuse to format, and is it damaged?
If the SSD cannot be formatted even with another tool, it is most likely damaged. The first thing to try is deleting the existing partition and creating a new one in a partition manager such as Paragon Partition Manager, then formatting it again [#16654172] If formatting still fails in Windows and even from the Win10 installer, that strongly points to a faulty drive rather than lost files [#16654101] To verify the drive’s condition, read the SMART data with CrystalDiskInfo or another SMART monitoring tool [#16654217] [#16654316] HD Tune can still show some SSD SMART information such as working time and start count, but it is not suitable for surface testing SSDs [#16654634] [#16654298]
  • Disk appears RAW and cannot be formatted
    #1 16653989
    andrz6
    Rate: 134
    I have a Innodisk 3ME SATA SSD 32 GB drive. The system sees this disk, 29.6 GB RAW, Healthy (Active, Primary Partition). The properties say that the device is working properly and the driver is up to date.
    Whenever you try to open a disk, the system wants to format it. When I try to format it, I get a message saying that the system was unable to complete the formatting.
    The disk is connected to the USB connector, but I also tried to format it with the win10 installer after putting it in the main pocket of the computer.
    Is the disk damaged or did it lose any files?
  • #2 16654101
    Kasek21
    Help: 4981
    Rate: 3547
    If it can't be formatted then it's damaged.
  • #4 16654180
    Kasek21
    Help: 4981
    Rate: 3547
    borg18 wrote:
    enter logs from the HD tune program from the health tab
    What do you need HDTune for SSD?
  • #5 16654195
    borg18
    Help: 8
    Rate: 37
    what for what? and to give information from SMART about the condition of the disk ... whether HDD or SSD will give the data
  • #6 16654201
    Kasek21
    Help: 4981
    Rate: 3547
    You write stupid things!
  • #7 16654217
    borg18
    Help: 8
    Rate: 37
    yyy why this certainty first give an argument and then negate ... I have been using hd tune for years and it comes with both ordinary HDD and SSD, it is known that not all parameters will be shown because the SSD does not have a head etc ... but I will show something ... I also recommend CrystalDiskInfo
  • #8 16654275
    Kasek21
    Help: 4981
    Rate: 3547
    borg18 wrote:
    but he will show something.
    What?
  • #10 16654298
    Kasek21
    Help: 4981
    Rate: 3547
    borg18 wrote:
    at least that
    ... and what have you got there?
    borg18 wrote:
    and you can examine disk surfaces in it
    Not suitable for testing SSDs.
  • #11 16654311
    andrz6
    Rate: 134
    And what is suitable for testing SSDs to clearly recognize it as damaged?
  • #12 16654316
    borg18
    Help: 8
    Rate: 37
    I will not argue but a few SSDs before I studied and the results were satisfactory and showing the truth. And what's interesting ... hmm data relocation e.g. ... I also gave Crystal ... it will also be good and not better, and the reading can also be done using SMART Monitoring Tools
  • #13 16654634
    r103
    Level 37  
    Help: 283
    Rate: 968
    Kasek21 wrote:
    What?
    Working time, number of starts ... Look optimistically into the future :roll:
The discussion revolves around an Innodisk 3ME SATA SSD 32GB that is detected by the system but shows as RAW and healthy, with formatting attempts failing. Users suggest that the drive may be damaged if it cannot be formatted. Recommendations include using third-party software like Paragon Partition Manager to delete and recreate partitions, as well as HD Tune and CrystalDiskInfo for monitoring the SSD's health and SMART data. There is debate over the effectiveness of these tools for SSD diagnostics, with some users advocating for their use based on personal experience.
TL;DR: 1 tool suggested (Paragon Partition Manager) and “first delete the partition, then create a new one and format.” [Elektroda, borg18, post #16654172]
Why it matters: This FAQ helps Windows users fix or diagnose an Innodisk 3ME SATA SSD that shows RAW and won’t format.
Why does my Innodisk 3ME 32GB show RAW and keep asking to format in Windows?
Windows can see the drive but the partition isn’t readable, so it shows RAW and prompts to format. In the thread, the 32 GB Innodisk appeared as 29.6 GB RAW and Healthy, yet remained inaccessible. That symptom points to a damaged or corrupted partition structure on the SSD. [Elektroda, andrz6, post #16653989]
Does a failed format mean the SSD is dead?
A respondent stated, “If it can’t be formatted then it’s damaged.” Treat repeated format failures across different ports or hosts as a strong failure signal. Back up any recoverable data before further writes. “If it can’t be formatted then it’s damaged.” [Elektroda, Kasek21, post #16654101]
What’s the first fix to try when an SSD is RAW?
Try a partition-manager workflow: delete the existing partition, create a new partition, then format it. Paragon Partition Manager was suggested specifically for this sequence. This can repair a broken partition table without deeper firmware work. “First delete the partition, then create a new one and format.” [Elektroda, borg18, post #16654172]
How do I check this SSD’s health quickly?
Pull SMART data and review health indicators with tools mentioned in the thread, such as CrystalDiskInfo or SMART Monitoring Tools. These tools surface reallocated sectors, wear indicators, and power-on counts that help confirm failing media or controller issues. “I also recommend CrystalDiskInfo.” [Elektroda, borg18, post #16654217]
Is HD Tune good for SSD diagnostics?
One participant argued that HD Tune’s surface test is not suitable for SSDs. If you use it, focus on SMART data reporting rather than surface scans. Prefer SSD-aware tools for wear metrics and controller health. “Not suitable for testing SSDs.” [Elektroda, Kasek21, post #16654298]
I tried USB and internal SATA, and even the Win10 installer. Format still fails. What does that indicate?
Cross-environment failures (USB enclosure and direct SATA with Windows installer) suggest a drive-side problem, not a cable or port issue. In the case discussed, both routes failed and a respondent deemed the device damaged. Consider replacing the SSD after data attempts. [Elektroda, Kasek21, post #16654101]
What capacity should I expect to see for a 32 GB Innodisk?
In the case reported, Windows showed 29.6 GB available for a 32 GB-labeled SSD. That aligns with overhead and formatting differences users commonly observe in practice. Treat sudden RAW status at this size as a red flag to check SMART and partitions. [Elektroda, andrz6, post #16653989]
Can Windows show Healthy but the SSD still be unusable?
Yes. The drive in the thread appeared Healthy (Active, Primary Partition) while the file system was RAW and inaccessible. Healthy refers to the partition’s presence, not a readable file system or sound NAND/controller state. Proceed with partition rebuild or replacement. [Elektroda, andrz6, post #16653989]
What metrics matter in SMART for a quick go/no-go?
Look at power-on hours and power cycles first, as one commenter highlighted. Combine these with reallocation and wear indicators in an SSD-focused tool. If attributes look abnormal and formats fail, plan for replacement. “Working time, number of starts...” [Elektroda, r103, post #16654634]
What’s a safe 3‑step how-to to attempt recovery?
  1. Delete the existing partition using Paragon Partition Manager.
  2. Create a new primary partition on the full disk.
  3. Format the new partition (NTFS/ exFAT) and recheck access. If any step fails, stop and assess SMART data. [Elektroda, borg18, post #16654172]
Should I trust a surface scan to find bad areas on an SSD?
Avoid relying on classic sector-by-sector surface scans for SSDs, as noted in the thread. These tests were designed for HDD mechanics and offer limited diagnostic value for flash media. Use SMART and vendor/SSD-aware tools instead. [Elektroda, Kasek21, post #16654298]
Who is this guide for and what problem does it solve?
It targets Windows users with Innodisk 3ME SATA SSDs that appear as RAW, show Healthy partitions, and refuse to format. It consolidates the thread’s practical steps and viewpoints to help decide between partition repair and replacement. [Elektroda, andrz6, post #16653989]
