Lenovo Ideapad 700-15: How to Check HDMI Output (1.4b or 2.0) for 120Hz Monitor Compatibility
TargonTM 12714 6
  • #1 16656742
    TargonTM
    How can I check what HDMI output my laptop has? The model is Lenovo Ideapad 700-15. Someone told me that hdmi 1.4b but I don't know how he knew it. I looked at the instructions, xy box on the internet but I couldn't find anything myself.
    I need to know this if I want to connect a 120 Hz monitor. 1.4b and 2.0 can handle this frequency.
  • #3 16656839
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    here and there they write differently: 1.4a, 1.4b and 2.0.
    If I were you, I'd ask the manufacturer's support for this, giving you the exact designation of your model.
    Regards
  • #4 16656869
    TargonTM
    That's what I meant. Now the monitor probably also needs 1.4b or 2.0?
  • #5 16656879
    Kasek21
    Help: 4981
    Rate: 3548
    From what you can read at Uncle Google and 1.4b copes with such refresh at FullHD.
  • #6 16657073
    TargonTM
    I know that but cxy will do 1.4bw on a laptop? I think the monitor must have it too
  • #7 16657075
    Kasek21
    Help: 4981
    Rate: 3548
    If the monitor supports 120 Hz or more it has.
The discussion revolves around determining the HDMI output version of the Lenovo Ideapad 700-15, specifically whether it supports HDMI 1.4b or 2.0, which is crucial for connecting a 120 Hz monitor. Users suggest checking Lenovo's official support for accurate specifications, as there are varying reports about the HDMI version. It is noted that HDMI 1.4b can handle 120 Hz at Full HD resolution, but the monitor must also support the same HDMI version for optimal performance.
