Affordable thermostat for electric radiator to maintain 2-5°C in insulated room
djlexus 2025 3
  • #1 16657979
    djlexus
    Rate: 18
    I have a room which in winter cools down almost to ambient temperature, a difference of a few degrees on the + inside. this room is externally insulated, but due to the lack of heating in it, it cools down over time and keeps cold.
    I have decided to heat it electrically this year, but I am looking for a device, not prohibitively priced, to regulate the switching on of the radiator so as to keep the inside temperature positive, within a few degrees, 2-5, and to keep it as simple as possible.
    Perhaps an esteemed colleague has a solution to this issue.
    Regards,
    djlexus
  • #2 16658000
    rb401
    Help: 750
    Rate: 984
    djlexus wrote:
    in the limit of a few degrees, 2-5, and to make it as simple as possible.
    I have the impression that quite a few of the convection heaters or fan heaters or similar that are in the shops have an "anti-freeze" position on the thermostat (snowflake symbol). I have not checked this myself, but according to the manufacturers' descriptions in the instructions, this is used to keep the rooms a few degrees above freezing.
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    djlexus wrote:
    however, I am looking for a device
    This is called a 230V thermostat , you can buy it on allegro.
  • #4 16661463
    djlexus
    Rate: 18
    It's called a 230V thermostat , buy it on allegro.
    And I have found it,
    Thanks a lot.
    Greetings,
    djlexus
