Industrial module with Wi-Fi, LAN, PoE, RS485, inputs and relays – ESP32-S3-POE-ETH-8DI-8RO – t
p.kaczmarek2 2694 8
  • The ESP32-S3-POE-ETH-8DI-8RO (SKU 30838) combines Ethernet, Wi‑Fi, Bluetooth, eight relays, eight digital inputs, RS485, PoE, and a WS2812 status LED.
  • It uses a W5500 SPI Ethernet controller, a TCA9554 I/O expander for relay control over I2C, and direct ESP32 GPIOs for the eight inputs.
  • WaveShare rates the ESP32-S3 at up to 240 MHz, with 2.4 GHz Wi‑Fi/BLE, and the relays switch up to 10A at 250V AC or 30V DC.
  • PlatformIO code brought up Ethernet, a web server, relay toggling, WS2812 color control, buzzer beeps, and live input scanning.
  • The relay demo is only a simple prototype, and RS485, RTC, and TF-card features still remain to be tested.
  • Industrial module with Wi-Fi, LAN, PoE, RS485, inputs and relays – ESP32-S3-POE-ETH-8DI-8RO – t
    Here, I will present the versatile ESP32-S3-POE-ETH-8DI-8RO module, which offers a wide range of communication and control capabilities. The device combines Ethernet, Wi-Fi, Bluetooth, digital inputs and relay outputs, making it suitable for various projects in the fields of automation and IoT. Furthermore, PoE support simplifies installation and power supply in hard-to-reach locations. The whole thing is easy to programme using Visual Code and PlatformIO, which I will also demonstrate here – my examples will cover the device’s basic functionality.
    Modules of this type are often marketed as ‘industrial’. The model presented here has the SKU code 30838.
    The pack includes the module, an antenna and a small screwdriver.
    On the front, there are 8 relay outputs – both normally open and normally closed, as well as a common contact, of course.
    On the rear are an Ethernet (PoE) port, an antenna, an RGB LED (WS2812), a boot button, digital inputs, a power supply (up to 36 V) and an RS485 port.
    However, I can’t see the RESET button on the ESP here; it’s only visible once the cover has been removed.
    Now we can refer to the documentation from WaveShare. What do we have on board:
    1. ESP32-S3
    Operating frequency up to 240 MHz, with 2.4 GHz Wi-Fi and BLE
    2. High-quality relay
    Contact rating per channel: ≤10A 250V AC or ≤10A 30V DC
    3. Optocoupler isolation
    Prevents interference with the control system from an external high-voltage circuit connected to the relay
    4. RESET button
    5. PoE port
    Option to connect a PoE module (PoE port version only)
    6. BOOT button
    7. Power supply circuit
    8. Digital isolation
    Prevents interference with the control circuit from external signals
    9. Power supply isolation
    Ensures a stable isolation voltage; no additional power supply is required for the isolated side
    10. Bidirectional opto-isolator isolation
    11. RTC battery connector
    12. Buzzer
    13. Digital input interface
    14. Pin connector
    Ability to connect other devices
    15. Operating status indicator
    PWR: power indicator
    RXD: RS485 receive indicator
    TXD: RS485 transmit indicator
    16. USB interface Type-C
    For powering the module, firmware updates and USB communication
    17. WS2812 RGB colour LED
    Controlled via GPIO38 pin
    18. Network port
    19. External antenna socket
    Female SMA connector, for WiFi and Bluetooth wireless communication
    20. Screw-type power connector
    Supports a wide voltage range of 7–36 V DC
    21. RS485 communication interface
    Supports connection of external RS485 devices
    22. RS485 terminating resistor
    Built-in 120Ω resistor, enabled via a jumper
    23. Screw-type relay terminal
    Makes it easier to connect devices
    24. Built-in TVS (surge suppressor) Effectively suppresses surge voltages and short-term voltage spikes in the circuit
    25. RS485 conversion circuit
    26. MP1605GTF-Z DC-DC power supply module
    27. PCF85063ATL RTC circuit for timing tasks
    28. TCA9554PWR Extends I/O lines for relay control
    29. W5500 Extends 10/100Mbps network connectivity via the SPI interface
    30. TF card slot Supports external TF cards for storing images and files
    Schematic diagram:
    Dimensions:
    Additional photos:
    Industrial module with Wi-Fi, LAN, PoE, RS485, inputs and relays – ESP32-S3-POE-ETH-8DI-8RO – t Industrial module with Wi-Fi, LAN, PoE, RS485, inputs and relays – ESP32-S3-POE-ETH-8DI-8RO – t Industrial module with Wi-Fi, LAN, PoE, RS485, inputs and relays – ESP32-S3-POE-ETH-8DI-8RO – t
    Hello World LAN
    The programme is uploaded via USB. To make working with the UART easier, I have redirected the log output to the CDC, i.e. the virtual serial port.
    The platformio.ini file:
    [env:esp32-s3-poe-eth-8di-8ro]
    platform = https://github.com/tasmota/platform-espressif32/releases/download/2024.08.10/platform-espressif32.zip
    board = esp32-s3-devkitc-1
    framework = arduino
    monitor_speed = 115200
    upload_port = COM60
    monitor_port = COM60
    build_flags =
        -D ARDUINO_USB_MODE=1
        -D ARDUINO_USB_CDC_ON_BOOT=1
    The LAN controller is connected via SPI. It requires the pins to be mapped correctly.
    Code: C / C++
    When the programme starts, we initialise the SPI and Ethernet. The rest will run in the background.
    Code: C / C++
    The library responsible for the connection automatically publishes events that can be used to monitor the connection status. The router’s DHCP automatically assigns an IP address to the board.
    Code: C / C++
    All that remains are the servers – we simply define the resources available there and the content they return, along with the MIME type. All HTTP handling is carried out by the WebServer library.
    Code: C / C++
    The result – the server is accessible via the cable and is working correctly.
    Relay control
    There are eight relays, but they are not accessible via standard GPIO pins. The TCA9554 pin expander, controlled via the I2C interface, is used to control them. This allows the number of GPIOs required to be reduced to just two (SCL and SDA) and enables the bus to be shared with other devices.
    We include the I2C header, define its pins, the TCA9554 address and the addresses of its registers:
    Code: C / C++
    Next, we need a function that sends a value to a specific TCA9554 register:
    Code: C / C++
    I store the relay states as a byte – the individual relays correspond to its respective bits. When a change occurs, I send this byte to the expander.
    Code: C / C++
    Improved HTML page
    Code: C / C++
    Handling a request to toggle a specific relay:
    Code: C / C++
    We still need to set the expander’s pin mode once at start-up:
    Code: C / C++
    This is how the relays can be controlled. This isn’t an ideal solution and isn’t really suitable for the final version of the product, as, for example, sending a command twice (e.g. due to a network issue) will toggle the relay’s state twice, but it’s perfectly fine for a small demo.
    WS2812 control
    The WS2812 is an individually addressable coloured LED, which is used here to indicate the device’s status. Normally, multiple WS2812s are used to create strips and various LED gadgets where animations are played, but here we have just one. However, this does not prevent us from using the same library as for strips – for example, Adafruit NeoPixel.
    We add it to PlatformIO:
    lib_deps =
        adafruit/Adafruit NeoPixel @ ^1.12.0
    We define the number of LEDs and the pin used for communication, then create an object representing the LED strip (pixels) in the appropriate mode:
    Code: C / C++
    All that remains is to add the frontend – a ready-made colour selection form using HTML:
    Code: C / C++
    And finally, the connection – receiving the packet that sets the colour:
    Code: C / C++
    Panel:
    Result:
    Buzzer control
    Finally, something simple but equally important. A visual signal from the WS2812 is one thing, but an audible signal is also useful. That’s why we have a buzzer on board. Let’s define its pin and the associated constants. The buzzer operates using PWM, as this allows us to generate an audio signal with adjustable frequency and volume using a digital pin on the microcontroller. By sending rapid pulses at a specific frequency and duty cycle, the buzzer vibrates continuously, creating the impression of a tone that we can control via software.”
    Code: C / C++
    We use ledc to control PWM. ledc in the ESP32 is a built-in hardware module for generating a PWM signal on selected pins
    Code: C / C++
    The function that plays the “beep” is blocking; it simply sets the duty cycle, waits a moment, and then clears it. I decided I could get away with it in this demo.
    Code: C / C++
    I’ve also added a button for this on the HTML panel.
    The result (please watch with sound):
    Inputs
    That leaves the digital inputs. Interestingly, these are directly on the ESP32 pins – there’s no expander here. GPIO pins 4, 5, 6, 7, 8, 9, 10 and 11 are used. I’ve put them in an array so they can be scanned on the fly whilst generating the web panel:
    Code: C / C++
    They need to be initialised beforehand, just as is traditionally done with Arduino pins:
    Code: C / C++
    And this is what the scan looks like – a simple
    digitalRead
    Code: C / C++
    Result:
    What’s heating up on the board?
    Finally, just a quick test, out of curiosity. What gets the hottest? It looks like the PoE board… or, more precisely, the resistor. That’s strange to me, as I’m powering the board from a USB port.
    The power supply circuit on the output side is also getting hot:
    Thermal image of an electronic board with temperature readings 31.7°C, 29.3°C, and 24.2°C
    Summary
    To sum up, this was a brief overview of the ESP32-S3-POE-ETH-8DI-8RO. We managed to get the basic functions up and running – communication via Ethernet, outputs (relays, LEDs, buzzer) and inputs (digital GPIOs). This wasn’t a comprehensive overview of the hardware, as there’s still RS485, the RTCC and the TF card to cover, but I still think it might help someone get started with this hardware. The board looks very versatile and useful, especially if you need PoE. Otherwise, you can buy the version without it – the ESP32-S3-ETH-8DI-8RO; the rest is similar.
    Do you use WaveShare modules, or can you see a use for this board with PoE?
    p.kaczmarek2 wrote 14794 posts with rating 12943, helped 659 times. Been with us since 2014 year.
  • #2 21937047
    zetor1
    Rate: 33
    A handy, versatile module.
    PoE power supply: a handy feature, but I couldn’t find the maximum power consumption figures for either PoE or the screw terminals.
    The module could be used, for example, to control roller blinds, say, in Home Assistant. Best regards.
  • #3 21937223
    krzbor
    Help: 42
    Rate: 1072
    It’s a shame it doesn’t support MQTT, ideally via HA Discovery. I’ve showcased a similar module Link , which does have these features. Unfortunately, it doesn’t have PoE.
  • #4 21937258
    Rate: 12943
    What do you mean by ‘there’s no MQTT’? Is there no library for it? After all, even on my site at OBK there’s MQTT support via HA Discovery on the ESP32; you can easily control the relays on the device shown in this thread without any programming.
  • #5 21937301
    krzbor
    Help: 42
    Rate: 1072
    In the manual, I read ‘Support for Modbus RTU and Modbus TCP protocols’. I thought programming on this ESP was disabled.
  • #7 21937982
    nobanmeplease
    Help: 7
    Rate: 20
    In my experience, modules of this type suffer from relays burning out, even with LED lighting at a load of 50 W. It’s a great pity that this module doesn’t have sockets that would allow for tool-free replacement of the relays.
  • #8 21938008
    tos18
    Help: 1113
    Rate: 1871
    No miniature relay performs well with inductive or capacitive loads (LED power supplies).
    When designing a circuit, you need to take this into account – read the relay data sheets – or be prepared for rapid contact degradation.
  • DIN-rail relays work reliably with proper contact ratings
    #9 21939493
    mycodename47
    Help: 15
    Rate: 55
    >>21938008 I have about 40 DIN-rail relays for controlling the lighting in my home; they’re Chinese-made with replaceable miniature relays measuring 20x5x12.5mm. I’ve been using them wherever I have LEDs up to 20–30W for four years now, and haven’t had any problems. I have a few 50W lamps where the contacts used to weld together at the first click; I replaced them with, I think, Omron or Panasonic relays rated for inductive loads, and these have also been working fine for four years.
