[Solved] Anet A8 Printer Issue: Unresponsive, Doesn't Print, SD Card/File Recognition & USB Connection
wiktor13570 6171 4
  • #1 16663518
    wiktor13570
    Rate: 39
    I bought and assembled an anet a8 printer. Everything in it works when it comes to its LCD panel (fans, heating the head and table, axis alignment). The problem appeared when I wanted to make the first print in the form of a 20x20x20 dice. The printer does not recognize the sd card, or it recognizes it but does not display files. Attempting to print via the usb cable also failed. The printer is connected to the computer, the program recognizes it, but it does not respond to any commands. I am asking for help, because I am helpless at this point.
  • #2 16667075
    adam_es
    Level 30  
    Help: 175
    Rate: 185
    It's a bit strange, even incorrectly connected elements should not block the reading from the card. What version of the software do you have in yours? Let me just suggest that selecting an operation in the menu, first use the "SD-mount" option. You can also try to format the card (FAT) and save the files again, or change to another card. If something does not work, I suggest writing to the manufacturer: I was surprised how quickly and effectively they work - I reported a faulty heater, after a week they sent me ... the entire head :D .
  • #3 16668870
    wiktor13570
    Rate: 39
    It turned out that replacing the card with a lower capacity one helped. I still can't operate the printer via the computer, but even if I could, I wouldn't. The card is convenient.
  • #4 16720721
    jacynka84
    Help: 13
    Rate: 29
    And in pronterface, aren't any of your counterparts spitting out information that cold extrusion prevenented? It heats, it moves the engines, whatever it does or is it only detected and you can connect to it?
    Do you even know if the printing program can see it?
  • #5 17163423
    wiktor13570
    Rate: 39
    My printer did not read 16gb cards at first. Everything is fine now.
