LG 24GM77-B Monitor: Choosing 3-5m DisplayPort Cable (v1.2 vs v1.3) for 144Hz, 20 Pin Options
kwas106 2421 1
  • DisplayPort 1.2 cable is enough for 144 Hz
    #1 16668737
    kwas106
    Rate: 18
    I purchased the LG 24GM77-B monitor. I have a DVI-D cable in the set, which allows me to use 144 hz, but it turned out to be very short, so I want to mock a DisplayPort cable with a minimum length of 3 meters (5 meters is also welcome). There is a lot of it on the Allegro, but I don't know which one to choose. 20 pin? better? worst ? how is v1.2 different from 1.3? I have 2 chosen, will they be suitable? Which one to choose?
    1.http: //allegro.pl/qoltec-displayport-v1-3-m-dp-v1-3-m-5kx3k-3-0m-i6883032292.html
    2.http: //allegro.pl/kabel-display-port-mm-3m-gold-delock-i6590565246.html
  • #2 16668852
    Vinicjusz
    Help: 9
    Rate: 45
    Differs in signal transmission speed.
    Take version 1.3, it gives a faster signal transfer rate than version 1.2.
    Pinowo should match the slot in the graphics card and in the monitor.
