I recently bought a Mercedes W211, on the day of purchase, when it got dark, I noticed stains on the meter (visible in the attached photo) It is a bit irritating because it looks ugly, and then something in it squeaks slightly (probably the backlight converter, because when I dim it with the potentiometer it stops ). The question is whether the backlight of the dials is a replaceable part? Do you need to replace the entire meter? Does it matter which meter will fit in the event of a replacement? Will the new odometer take mileage from the car?
Last question - where could these traces come from?
If possible, I would only like to replace the backlight.
Mercedes W211 E280 CDI 2009
