[Solved] Bosch SMV50E70EU: Seeking Values for Burned Diode and Capacitor in TNY264GN Converter
Telo 26841 4
  • #1 16671445
    Telo
    Service technician RTV
    Help: 1536
    Rate: 2383
    I have a question, a damaged converter based on the TNY264GN system, burned elements probably a diode and a capacitor, can I ask for the value of these elements?
    • Bosch SMV50E70EU: Seeking Values for Burned Diode and Capacitor in TNY264GN Converter SMV50E70EU.jpg (2.25 MB) You must be logged in to download this attachment.
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    Telo wrote:
    probably a diode and a capacitor, can i have the values of these elements?
    The diode is L9 and the capacitor is probably good!
    The image shows a close-up of a circuit board with a diode labeled as L9 and an integrated circuit TNY264GN.
  • #3 16671543
    Telo
    Help: 1536
    Rate: 2383
    Thank you for the answer, but the capacitor is charred and the photo is from a functional module.
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    The one next to the diode comes out to me about 270 nF, and the other one on the legs of the IC no. 1-2 - 100 nF :D
  • #5 16680026
    Telo
    Help: 1536
    Rate: 2383
    Thank you for your help, and after the exchange:
    SMD transistor 6Ct = BC817-40,
    capacitor SMD 220 nF - 0603,
    SMD diodes L9-BZX384-B12 designation (12 V Zener diode, SOD323 housing) of the TYN264GN converter controller,
    and making a bridge, connecting the power supply after the 100 ? power resistor, the converter started.
    Thank you for your help.
    Bosch SMV50E70EU: Seeking Values for Burned Diode and Capacitor in TNY264GN Converterelementy s...aprawa.jpg (363 kB)You must be logged in to download this attachment.
