Motherboard 9000 597 461 in dishwasher SIEMENS SR25M28EU / TNY 264 burnt
ccglbonnet 3768 3
  • Request for diode references on TNY264 output stage
    #1 19954833
    ccglbonnet
    Hello everyone.
    Probably the same problem for everyone, the 2 TNY output diodes have heated up.
    Can you give me the reference of these 2 diodes connected at the output of the TNY 264 GN in // on the coil.
    They have the Marking Code "F5" and "DU", but impossible to find the correspondence on internet.
    They are visibly HS (The Run Fuse also jumped).
    Card mounted on Siemens dishwasher SR25M283EU
    Thanks for your help.
    ccgl
    • Motherboard 9000 597 461 in dishwasher SIEMENS SR25M28EU / TNY 264 burnt Carte vue emplacement TNY.jpg (2.85 MB) You must be logged in to download this attachment.
    • Motherboard 9000 597 461 in dishwasher SIEMENS SR25M28EU / TNY 264 burnt diodes hs details.jpg (1.99 MB) You must be logged in to download this attachment.
  • #2 19954996
    alekt77
    Level 40  
    Help: 900
    Rate: 1339
    View topic: :arrow: Link and attachments.
  • Measured F5 and DU voltages on the PCB
    #3 19955018
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3826
    ccglbonnet wrote:
    They have a code labeled "F5" and "DU", but cannot be found datasheld on the internet.
    Why do you think they are supposed to be damaged? I have not yet encountered a situation where they are damaged, and the damage in these PCB versions is rather different.
    F5 A29 RJ RJ DU DU SR DU
    = = = :arrow: on them = 119V ~ 123V === :arrow: on them = 96V ~ 105V
    22 F5 9B 81A 22B 35A E0 22W
    Fragment of a table with technical data and voltage values.
  • #4 19958096
    ccglbonnet
    Hello TONI
    Indeed, the diode (F5) is still good, but the TVS diode (DU) is short (in both directions) so for safety I change both
    thanks for the matches
    I 'll try this
    LAB
