Opel Corsa C 2001 1.2 Z12XE - Transmission Change & F13 CR Box Compatibility Inquiry
henio 123 10419 10
How can I verify whether an Opel Corsa C 1.2 Z12XE replacement gearbox is the correct F13 CR unit, and how should the GM/Opel markings be read?
You should read the gearbox markings as separate groups, not as one long number: for the offered unit, 90 400 209 is the important housing/model number, while 432150 is a separate number. [#16674155] If the casing number matches, the box should fit physically, although the gear ratios may still differ. [#16674155] The exact F13 model/gear info may be on an engraved marking elsewhere on the gearbox, because the visible GM numbers can refer only to a specific part of the assembly. [#16674308] The seller’s claim that it came from a Z12XE engine is plausible if the gearbox physically matches the original unit. [#16674308]
  • #1 16673790
    henio 123
    Rate: 144
    Hello. Problem as in the subject. Due to defects in the box I am forced to replace it. The box was working with the Z12XE engine. The Allegro offered a F13 CR box which is identical to mine as per vin. Opel Corsa C 2001 1.2 Z12XE - Transmission Change & F13 CR Box Compatibility Inquiry This is the marking on my chest. Opel Corsa C 2001 1.2 Z12XE - Transmission Change & F13 CR Box Compatibility Inquiry And this is the marking from the box sent from the Allegro. There are no F13 markings under the selector. Does the Opel have other markings and how to read them?
  • #3 16673915
    henio 123
    Rate: 144
    Thanks for the feedback. I mean checking whether the seller sold me the right crate or let me go in the raspberries. According to the link where the F13 marking is to be placed on the selector, these markings are on the pictures. Maybe coded by GM. Unfortunately disassembly and replacement costs a lot of work and it is not a pleasure to insert the wrong box, I ask for factual information.
  • #4 16674090
    bubu1769
    Help: 1177
    Rate: 2374
    The one on the allegro has the number GM 90 400 209 or the F13 gearbox on yours I can't see the last digits and I can only read GM 90 400
  • #5 16674129
    henio 123
    Rate: 144
    The one with the Allegro is: GM 90 400 432150 200 my GM 90 400 200 760 Z
  • #6 16674155
    bubu1769
    Help: 1177
    Rate: 2374
    You read the numbering incorrectly, first the numbers are read in "frames" separately 90 400 209 and 432150 separately, and there are 209 instead of 200, there is no box with numbers 90 400 200. The box itself should match, at most you will have different gear ratios.
  • Need help identifying gearbox markings and compatibility
    #7 16674233
    henio 123
    Rate: 144
    The seller claimed it was an F13 CR with a ratio of 3.94 and worked with a Z12XE engine. That's why I bought it because the car has the same engine. Does GM have different markings than Opel. I was based on the Opel description and nothing suited me. There are also markings on the selector cover but will they help? Opel Corsa C 2001 1.2 Z12XE - Transmission Change & F13 CR Box Compatibility Inquiry Opel Corsa C 2001 1.2 Z12XE - Transmission Change & F13 CR Box Compatibility Inquiry
  • GM housing number 90 400 209 identifies the gearbox casing
    #8 16674308
    bubu1769
    Help: 1177
    Rate: 2374
    I can honestly say that I am already lost, it seems to me that these GM numbers apply to a specific element of the box and in this case the numbers 90 400 209 are the most important because they inform about the given housing model. As for the specific model of the box and its gears, one would have to look for some engraving with markings. As I wrote, the box should fit physically and the ratios may differ, but if the seller claims that it is from the Z12XE engine, it is very possible that it is from such an engine.
  • #9 16674371
    henio 123
    Rate: 144
    I looked at my box from the channel and from above and found nothing else. Perhaps these are the symbols of the elements. In the repair book there is no mention of the gearbox. I will risk and put the bought one because the one that is at higher speed begins to howl. Question where to find the description or a cable about replacing the box in corsie c.
  • #11 16675832
    henio 123
    Rate: 144
    Thanks for the link. What about the symbol 90 400 206 on the auction are corsa 1.2 chest auctions
The discussion revolves around the compatibility of a replacement transmission for an Opel Corsa C 2001 with a Z12XE engine. The user is considering a F13 CR gearbox sourced from Allegro, which appears to match their current transmission based on VIN. However, there are concerns regarding the markings on the gearboxes, specifically the GM numbers, which may indicate different models or ratios. Participants analyze the GM numbers, with emphasis on the importance of the last digits for identification. The user expresses uncertainty about the markings and seeks guidance on whether the replacement gearbox will fit and function correctly. They also inquire about resources for gearbox replacement in the Corsa C.
