D-link DWR-921 router flashing range LED and no internet access
jakub B. 13074 3
  • #1 16675035
    jakub B.
    Hello, I have a problem with the above-mentioned router. For half a year, it has been working fine, but since yesterday the orange coverage LED is flashing and the POWER and WLAN LEDs are on. When I connect to the router via wi-fi I get a message saying I can't access the network. Do you know what this may be due to? Thank you in advance for your help.
  • #2 16681620
    tomek10861
    Help: 13
    Rate: 199
    The number one question is whether you can get to the router from the wifi level.
    Two what give the commands ipconfig / all and tracert 8.8.8.8
    Does the internet work with a cable?
  • #3 16681946
    KOCUREK1970
    Help: 3858
    Rate: 5486
    Reset it and set it again.
  • #4 16683497
    tomek10861
    Help: 13
    Rate: 199
    If it doesn't help upload the sofa, if it doesn't help replace the router :P and I would seriously check it or give it to someone who is overwhelmed by such things
