LTE ODU/IDU-200 Router Flashes Red: Internet Problems, Limited Downloads & Resetting Fixes
david003 24477 5
  • #1 16939860
    david003
    Rate: 28
    Hello, I have a big problem. I have internet problems recently while downloading. My router is flashing red. how do I download a file. nw why this is happening. When I download something from the net, I pop out the "Limit" every time I download a file that is always the Internet changes to "Limited".
    I am asking for help.
    ps resetting the router helps for a few hours but after a few hours again is the same.
  • #2 16940112
    jarek7714
    Help: 85
    Rate: 119
    Check the modem connection status in the diagnostics of the modem-router (you may have too poor signal parameters and the connection is broken), it is not a device for everyone to which in case of problems with the range we can easily connect an external antenna.
  • #3 16941802
    makosuu
    Help: 369
    Rate: 370
    This miracle had problems just with restarting ODU. How does the restart, reset and so on is not guaranteed. And since when do you have it? Because it's a medium choice.
  • #4 16942746
    david003
    Rate: 28
    Since Summer 2017, I had this problem.
  • #5 16948089
    makosuu
    Help: 369
    Rate: 370
    Give back the guarantees.
  • #6 16956998
    david003
    Rate: 28
    I returned to the service. they repaired the router and now it works without any flashing.
    I close the topic.
