[Solved] Citroen C5 MKII - Automatic transmission error P0977 AISIN AM6
Lysyxmv6 19542 6
  • #1 16676149
    Lysyxmv6
    Rate: 60
    I have such a problem with the AISIN AM6 gearbox.
    After buying the car drove and nothing happened. It happened about three weeks without driving and problems started with the box. Original mileage 170,000. motor 2.0 HDI 138HP.
    After driving a few kilometers, the gearbox falls into emergency mode, until then the gears enter as they should be. And the same happens when I start the car after a night and warm up at a standstill and enters the emergency mode. The error is P0977 '' Solenoid S2 output short to + or open.
    Could it be the fault of the gearbox controller itself or the solenoid valve itself :?:
    Where to look for this solenoid after removing the entire disc :?:
    When I remove the disc, how much oil will be lost :?:
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    You don't take off the whole plate, just unscrew the cover and it will be visible. To begin with, you drain the oil and then the cover. The oil drain plug is also a condition check when pouring. Citroen C5 MKII - Automatic transmission error P0977 AISIN AM6
  • #3 16677743
    Lysyxmv6
    Rate: 60
    romuald-f
    Thanks for the help.
    At the beginning I will replace the driver (maybe it is broken)
    Today, after starting the car at night, at idle the gearbox went into emergency mode after warming up and the same error.
    Does this solenoid valve push in quality? or is it screwed in?
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    It is screwed on.
  • #5 16678362
    Lysyxmv6
    Rate: 60
    Thank you very much :)
    Added after 6 [hours] 18 [minutes]:
    And in this picture it is the opposite. Citroen C5 MKII - Automatic transmission error P0977 AISIN AM6
  • #6 16681166
    Lysyxmv6
    Rate: 60
    So how is it finally the right picture?
  • #7 17253786
    Lysyxmv6
    Rate: 60
    Replacing the S2 solenoid valve did the trick.
The discussion revolves around an issue with the AISIN AM6 automatic transmission in a Citroen C5 MKII, specifically an error code P0977 indicating a problem with the Solenoid S2. The user reports that after a period of inactivity, the gearbox enters emergency mode after a few kilometers of driving or after warming up at idle. Responses suggest that the solenoid valve is accessible by removing the cover rather than the entire plate, and it is confirmed that the solenoid is screwed in. The user plans to replace the driver and ultimately finds that replacing the S2 solenoid valve resolves the issue.
