Zgemma Star 2S Tuner Hangs & Stuck on Boot, Red Light Issues: Power Supply & OpenATV 5.3
Tomy@ 18792 8
  • #1 16677219
    Tomy@
    Rate: 11
    I have a problem with my Zgemma Star 2S tuner, i.e. it hanged me a couple of times today and after reboot it had a problem with restarting. Currently, for nothing in the world I do not want to start the boot, it stands on a red control and nothing moves.
    I have ruled out the power supply because it is in working order, the condensers are also okay. It is not an old equipment because it is maybe half a year old.
    During this time I was very happy with him, he went on OpenATV 5.3 without complaint.
    Do you have any ideas what could have failed? Will the repair be profitable?
    In the annex, inside photo. I will be extremely obliged for any suggestions.
  • #2 16677762
    maksar
    Help: 177
    Rate: 1030
    Tomy@ wrote:
    condoms are also ok.
    You can look out the window.
    This is a guarantee.
    Repair, the problem is not a malfunction.
  • #3 16678885
    matrix5
    Help: 8
    Rate: 37
    Buddy, go to some good service, boxing is 100% repaired though it's an older version of the motherboard that you can fix it.
  • #4 16699031
    bratek_44
    Rate: 12
    here you have everything, jtag and bootloader you upload and hula. I had the same problem.
    .sat-universe.com / showthread.php
    go to this page and read
  • #5 16699393
    matrix5
    Help: 8
    Rate: 37
    If this is a problem with the bootloader then yes, if you do not forget about the jtag. Unfortunately, most of the forums can not cope with jtag because the problem is elsewhere.
  • #6 16699618
    bratek_44
    Rate: 12
    That's how I understood
  • #7 16701244
    Tomy@
    Rate: 11
    Thanks for the info in the subject, I am willing to try to resuscitate him Jtag.
    Will someone tell me what kind of Jtag I need to buy? I am thinking of something like "The ATMEGA64 launch module"
    The question of the program remains.
  • JTAG recovery may be enough for Zgemma box
    #8 16703986
    matrix5
    Help: 8
    Rate: 37
    Buddy, all the descriptions you have on the internet with photos of how to use jtag in boxes of zgemma, may it be enough in your case only jtag :) if not, then you are left because the box is recoverable.
  • #9 16705017
    Tomy@
    Rate: 11
    I read somewhere on the net that it is worth trying even a dozen times to make a flash via usb for a long time holding the Power button.
    It is also worth changing the installation file noforce to force in the installation directories.
    After a dozen or so without any effective attempts, I left it with the pendrive inserted for about 15 minutes, after which the tuner suddenly stood up and started loading the image files.
    Soft installed correctly and so far everything is ok.
    Thanks for the help
The Zgemma Star 2S tuner is experiencing boot issues, remaining stuck on a red light after several hangs and failed restarts. The user has ruled out power supply problems and is seeking solutions. Responses suggest that the issue may be related to the bootloader or motherboard, with recommendations to use JTAG for recovery. Some users have successfully revived their devices by flashing via USB and holding the power button. The discussion includes advice on JTAG equipment and methods for troubleshooting the boot process.
