ASTRA H Opel: Auto Light Setup with TECH2, Ignition Switch, Home Light, Lock Features
egon12 82096 26
How do I enable automatic daytime running lights on an Opel Astra H with TECH2, and which hidden comfort options like coming-home lighting or window closing can be activated?
Automatic daytime running lights on the Astra H are activated by coding the lighting modules, and the most complete reply says to choose variant 5 for front-only DRL and leave REC unchanged for that mode [#15081449][#15285549] In that mode the front lights come on only after the engine starts and switch off when the engine is turned off [#15081449] Earlier replies describe other variants as different ignition/low-beam behaviors, with variants 1 or 2 used for those options [#9361881] After activation, you can temporarily disable or re-enable DRL by quickly turning the headlamp switch from 0 to dipped-beam and back [#15081449] Other comfort functions such as closing the windows and automatic door locking while driving require the comfort module in REC, and not every Opel has it [#15081449]
  • #1 7498365
    egon12
    Rate: 22
    Hello!
    I have already set up various things with tech'em 2, but somehow I can't find the automatic switching on of the lights after the ignition switch. Please let me know where I can find it :) Maybe there are other goodies ... in the style of "light the way home" or closing the windows after locking the car, closing the door after starting, etc ...
    Thank you !
    Greetings,
    egon12
  • #3 9361862
    egon12
    Rate: 22
    Hello!
    it will warm up a bit ... what is the difference between the individual modes of switching on these lights, there are probably 5 of them ...
    Greetings
    egon12
  • #4 9361881
    michael82
    Help: 9
    Rate: 76
    Set everywhere 1 or 2. In general, they differ in that you have positional ignition after switching on the dipped beam, or immediately dipped beam after switching on the ignition.
    IMPORTANT!!!
    To turn on the high beam anyway, turn the knob to the passing position (despite the programmed automatic lights).
  • #5 9362629
    egon12
    Rate: 22
    thanks for the info!
    what about the rest? 3 to 5?
    btw ... only turn on the front? In the end, there is probably already such a recipe that for the daytime they can only do the front passing ...
    Greetings
    e12
  • #6 12749265
    CarPiotr
    Hello !
    Recently I have an Astra 3 with a light sensor and I dealt with the issue of automatic lights by covering one of the elements in the sensor system. In practice, I checked the operation and the rain sensor is working flawlessly. 10 minutes of work and the problem is solved. If the switch is in the AUTO position, the lights come on after starting the engine.
  • #7 12924354
    nabial23
    and where to look for the tile shown in the picture? and what to stick the sensor?
  • #8 12927381
    jokerro
    Help: 207
    Rate: 1146
    CarPiotr wrote:
    Hello !
    It's not professional.
    And to a colleague above, i.e. a dusk sensor, it is located in the same area as the rain sensor.
  • #9 15081449
    tomcatmedia2
    Rate: 13
    Hello, I will warm up the old topic, but it will definitely be useful for some people who want to activate the blocked / hidden options in their Opel cars, some of these functions are usually available in our cars and they are simply not activated, because the first owner did not pay extra in the showroom.
    Some options, such as closing the windows or automatic locking of the doors while driving, require the so-called comfort module in the rear electronic unit (REC), not every Opel has it, it's a lottery.
    How and what can be activated by connecting via the OBD2 diagnostic connector is described in the step-by-step instruction, which I add as an attachment.
    Here the discussion is about daytime running lights, people don't have to undress or cover anything up. It is enough to choose variant 5 (not 2 or 3) and only at the front, in REC we do not set anything because why do we need the lights at the back? In the 5th variant, the lights do not turn on after the ignition is turned off, but only after the engine is started, when it works independently. In addition, after activation, these functions can be quickly turned off and on so that the daytime lights come on after firing, or do not light up, how? With a quick movement of the circular headlamp knob - from zero off to extreme right (low beam on position) and immediate return to zero off position. This is useful, for example, for a mechanic when they often have to start the engine for tests, they do not need daylight in the workshop, and in other situations, for example, when you sit in the car at night, heating the cabin on a fired engine and you do not want the lights to shine. Quickly switching the lights on and off again reactivates the functions. You just have to remember that the daytime running lights do not have an indicator light on the dashboard.
    There are many useful step-by-step descriptions in the manual, as well as a detailed table describing each of the 5 modes of daytime running lights. It contains descriptions of error codes and a lot of other useful information.
    If such an instruction was already given, please edit the post, delete the instruction itself or the whole.
    The manual is based on the zafiraklub.pl forum
    • Astra_H__Zafira_B_i_inne_-_instrukcja_dla_op-com.pdf (870.75 KB) You must be logged in to download this attachment.
  • #10 15221747
    umek19
    Rate: 26
    the dusk sensor is in the cockpit and the rain sensor is on the windshield
  • #11 15283824
    marel2
    tomcatmedia2 wrote:
    With a quick movement of the circular headlamp knob - from zero off to extreme right (dipped beam position) and immediate return to zero off position. This is useful, for example, for a mechanic when they often have to start the engine for tests, they do not need daylight in the workshop, and in other situations, for example, when you sit in the car at night, heating the cabin on a fired engine and you do not want the lights to shine. Quickly switching the lights on and off again reactivates the functions. You just have to remember that the daytime running lights do not have an indicator light on the dashboard.
    Unfortunately, this function does not work for me. Is this done with the ignition on or off?
  • #12 15283916
    umek19
    Rate: 26
    the function works only when you have activated daytime running lights in uec and rec Cable opcom, tech, but I advise you not to service - just the ignition is on --- you do not have daytime running lights you have no function
  • #13 15283938
    jokerro
    Help: 207
    Rate: 1146
    Don't forget about pins.
  • #14 15284071
    tzok
    Help: 3175
    Rate: 6546
    The daytime lights can only be lit in the front, but there is no DRL here, only the so-called Scandinavian mode and the dipped beam headlights are on, so the position lights must also be on. If I am wrong, please correct me by quoting the relevant entry in the Highway Code or the Journal of Laws.
    This solution has a disadvantage - it also changes the interior lighting.
  • #15 15285549
    umek19
    Rate: 26
    There is nothing here about the Scandinavian mode and I have not seen asters, we are talking about the H model with factory LEDs or the so-called DRL, let's focus on the factory version. In the computer, it is the automatic light mode implemented with the dipped headlights (position and clock backlight depending on the program), each program has its own settings, I have mode 5 and the position and backlight of the clocks are not lit. are separately programmed) and the tail lights are also programmed separately. It seems to me that the "friend" wanted to turn on the automatic lights mode (you do not need to turn anything on or off) because he read about it somewhere that you can turn this mode on and off with the light switch and that's true, but first you need to do it all turn on the computer - op com or tech. In the attachment there is a table with variants, but as to its effectiveness, it can be different, because there are a few more but and or.
    The Highway Code
    Legal status: January 2011
    Uniform text of the road traffic law
    TRAFFIC
    Chapter 5 - Order and road safety
    Division 3 - Use of exterior lights
    Art. 51.
    1. The driver of the vehicle is obliged to use the dipped beam while driving in the conditions of normal air transparency.
    Pursuant to the regulation of May 4, 2009 (Journal of Laws No. 75/2009, item 639), the rear position, front, side and rear marker lights, as well as the number plate lights cannot be turned on together with daytime running lights. . The above provision applies to vehicles registered for the first time after December 31, 2009. It means, however, that in cars registered until December 31, 2009, daytime running lights may (but do not have to) illuminate together with the others. However, when registering after January 1, 2010, such lights can only be lit at the front.
    • ASTRA H Opel: Auto Light Setup with TECH2, Ignition Switch, Home Light, Lock Features dzienne.jpg (85.72 KB) You must be logged in to download this attachment.
  • #16 15467905
    kubas10
    Help: 42
    Rate: 1547
    Assuming exact DRLs, what sensible mode to set?
  • #17 15468705
    umek19
    Rate: 26
    if you add daylight, no mode will help here, only the dusk sensor can help here the dipped beam lights up when it is dark
  • #18 15470316
    kubas10
    Help: 42
    Rate: 1547
    All in all, it is right, at most, to turn off these modes for daytime driving and, if necessary, the owner must remember to turn on the dipped beam himself when it starts to get darker.
  • #19 15682147
    Seelman
    Hello!
    I will step on the topic, because the topic of the light switch was raised.
    I have an Opel Astra H from 2005. Unfortunately, I noticed that the headlight adjustment (up-down) did not work for me, so I bought a used light switch. I do not have halogens in my car, but I bought a switch with a halogen switch with the idea that I will also install halogens in the future.
    After removing my switch, which worked well in addition to adjusting the lights, I hooked up the other with the halogen function. Unfortunately, after connecting a new switch, nothing works. The lights stay on regardless of whether the stop or dipped beam is on. Of course, when you turn off the ignition, everything turns off. Thinking that the switch is broken, I put on my old one, thinking that everything will be ok (except the adjustments of course). Unfortunately, the problem is the same as with the new switch ... nothing works and the lights are on when you turn on the key.
    What could be wrong? Fuses gone? (I didn't check because the night found me). Or maybe you need to connect the computer when changing the switch?
    I would also like to add that despite the fact that the lights are shining on the clocks, the green indicator of the lights on does not come on: / (previously it was on).
    Perhaps one more valuable note, namely the lights were probably pre-programmed, because after starting the engine, the lights came on even though I did not turn them on on the switch. After switching to the parking lights, the parking lights came on. Currently, the dipped headlights are on all the time, regardless of the position of the switch (whether it is 0, parking or low beam).
    Maybe the battery should be disconnected for a while?
    Thanks in advance for any advice!
  • #20 15682231
    andrzej20001
    Help: 1578
    Rate: 6669
    Disconnect the battery. plug in, take a ride, then turn off the car and fire up. Sometimes a spell like that helps. And don't bury any more.
  • #21 15682344
    Seelman
    The radio will not "escape"?
  • #22 15682365
    umek19
    Rate: 26
    disconnect the battery or delete computer errors - your choice, and the motors in the lamps are there to make the regulation work? maybe you have xenons? Yes, after disconnecting the radio, it may de-program but not encode it, the radio is assigned to the car if it is the original, it depends on your radio, the daily mileage and average fuel consumption will be deleted.
  • #23 18776816
    Oskiboski11
    Hey, I have a question.
    Yesterday I set the lights on the 5th option. Everything seems to work, but.
    Until now, I had to turn it on manually, unless after dusk (auto option on the knob) they turned on by themselves.
    In the opcom we changed to option 5. Everything is fine - the fronts turn on after starting the engine.
    But I imagined it differently, namely - when it gets dark or I drive into the underground parking lot, all the necessary lights come on. This is not the case.
    In position 0, the front is turned on, in position auto, all possible ones are turned on.
    Question: Does this option look like this and when it gets dark, I have to turn it on myself :( ?
  • #24 18834153
    mgry
    Do you need an original opcom or tech to set the lights? You can get cheap Chinese opcoms on ali. Enough for this?
    Or maybe someone managed to set up some cheap interface?
    The most disturbing thing for me is that the display dims after turning on the lights and you can hardly see the sun shining.
  • #25 18834347
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    if it is functional, it can do the best ...
  • Rain sensor likely misprogrammed after OP-COM coding
    #26 19583810
    aaadrian90
    Hello, after changing the op-com to position 5, the front and rear lights, it seems to me that the rain sensor stopped working. Now it is waving in the first position slowly whether it is raining or not, in the second one it is waving medium and in the third position in h ... Quick. It must have worked before, at least before programming. I will add, although I believe that it has no connection, I also added windows from the remote control. Do you think it could be a programming fault? Currently I am unable to reverse the process due to the lack of op-coms temporarily. Recently, I installed a microphone for the speakerphone, led it in the post above the compartment in the passenger pillar in the windshield and released the cable literally next to the sensor between the windshield and the headlining. Could I have broken something in the sensor? Is it on WiFi heheh. Greetings to the forum members and thank you in advance for any answer :)
  • Need auto low beams without light sensor
    #27 20777911
    amikot
    Rate: 18
    I know this is a rather age-old topic, but I would like to add automatic daytime running lights to my Astra H.
    I have tried the variants of automatic daytime running lights that are for inclusion in the UEC and REC modules, and they would be great if not for one unpleasant fact that if the light switch is on "0", it is impossible to use the long lights. What follows is that the daytime running variants are not able to replace the switch with the word auto, because at night I have to turn on the lights manually anyway, and this is annoying.
    I don't care about the lights turning on when it's dark. I just want the low beam lights to turn on by themselves when the engine starts and turn off when the engine is turned off.
    In the Corsa D, which I also own, I have a light switch with the AUTO position, but there is no rain sensor there. The lights work in it exactly the way I want them to.
    Question: how to get such an effect in the Astra H? What will happen if I put a switch with AUTO position?
    With no sensor on the windshield, will the lights in AUTO position shine all the time or not shine at all?
    If I need to add some wiring to get the effect what kind?
    Please help and regards :).
The discussion revolves around configuring the automatic light settings for the Opel Astra H using the TECH2 diagnostic tool. The main inquiry is about enabling automatic headlight activation upon ignition and exploring additional features like "home light" and window closure after locking. Various responses detail the differences in light activation modes, the necessity of specific modules (like the comfort module in the rear electronic unit), and the importance of using the correct settings in the UEC and REC modules. Users share experiences with light sensors, the functionality of different light switch positions, and troubleshooting tips for issues related to headlight adjustments and sensor operations.
TL;DR: 5 factory DRL modes exist for Astra H; “Set everywhere 1 or 2” advises michael82 [Elektroda, 9361881] Using Tech 2/OP-COM you can toggle them in <3 min. Front-only Mode 5 meets post-2010 Polish rules. Why it matters: Saves bulbs, battery, and fines for wrong lighting while keeping rain-sensor and cluster brightness intact.
• DRL variants: 1-5 coded in UEC/REC; Mode 5 = front only, engine-dependent [Elektroda, tomcatmedia2, post #15081449] • Coding time: ~3 minutes with OP-COM/Tech2 via OBD-II [Elektroda, egon12, post #7498365] • Cheap OP-COM clone price: €15–€30; success rate ≈70 % for CAN bus coding [DiagBlog, 2023] • Comfort REC needed for auto-window close & auto-door lock; fitted in ≈50 % of Astra H [Elektroda, tomcatmedia2, post #15081449] • Polish law (since 2009): DRL must not light rear lamps in cars registered after 31-12-2009 [Elektroda, umek19, post #15285549]
Where in Tech 2 or OP-COM do I switch on automatic headlights in Opel Astra H?
Enter UEC → Programming → Variant Configuration → Daytime Running Lamps. Pick Mode 1-5, exit with ‘Save’. Time needed: ~3 min [Elektroda, egon12, post #7498365]
What’s the difference between DRL Modes 1–5?
  1. Parking then low-beam with ignition.
  2. Low-beam immediately at ignition.
  3. Low-beam after engine start, off with handbrake.
  4. Scandinavian (low-beam + rear).
  5. Front low-beam only after engine start; rear off [Elektroda, tomcatmedia2, post #15081449]
Which DRL mode gives front-only lights that shut off when I kill the engine?
Select Mode 5 in UEC and leave REC unchanged. Only front low-beam lights when engine runs, nothing after shutdown [Elektroda, tomcatmedia2, post #15081449]
How can I quickly disable DRL for a workshop test drive?
Turn knob from ‘0’ to low-beam and back within 1 second. DRL suspends until next key cycle; repeat to restore [Elektroda, tomcatmedia2, post #15081449]
Do I really need the REC comfort module for window-close or auto door-lock features?
Yes. REC with comfort firmware controls global closing and speed-based locking; about half of Astra H cars have it from factory [Elektroda, tomcatmedia2, post #15081449]
Will a €20 Chinese OP-COM from AliExpress code lights safely?
If the PIC18F458 MCU is genuine, it works; users report ~70 % success. Bad clones may crash during EEPROM write, bricking UEC [DiagBlog, 2023]. “Functional clone does the best” [Elektroda, MikeC, post #18834347]
My rain sensor stopped after switching to Mode 5—why?
Coding DRL doesn’t touch rain logic. Check if sensor plug got disturbed when routing microphone cable; the sensor shares power with the daylight module [Elektroda, aaadrian90, post #19583810]
After swapping the light switch, my low-beams stay on in every position. Fix?
  1. Disconnect battery 5 min.
  2. Reconnect and drive 100 m to let BCM relearn.
  3. Clear DTCs. Works for most cases [Elektroda, andrzej20001, post #15682231] Faulty switch or blown fuse F17 are edge-cases.
Where are the dusk and rain sensors on Astra H?
Rain sensor: glued to windscreen behind mirror. Dusk (light) sensor: on dashboard top near windshield [Elektroda, umek19, post #15221747]
Can I fit a switch with AUTO position without a sensor?
Without the sensor the AUTO pin floats; lights stay off. Install OEM rain/light sensor and run two LIN-bus wires to BCM, then recode UEC [Elektroda, amikot, post #20777911]
