[Solved] Opel Astra F 1.4 60hp 2000: X14NZ Engine Timing Belt Breakage & Potential Damage
prezes1977 5679 9
Is the Opel Astra F 1.4 60 hp X14NZ engine an interference engine, and what damage can happen if the timing belt breaks?
The X14NZ 1.4 engine is an interference engine, so a broken timing belt can bend valves; the replies mention cases from 4 bent valves to all 8 [#16679971][#20608086] If the belt has broken, do not assume it is harmless—inspect the head/valves and then fit a new belt before running the engine again [#16679971][#16679628] One user found the real cause of the belt failure was a seized water pump, and after replacing the timing set the car ran normally again [#16680329][#16683835] A worn gear on the shaft was also mentioned as a likely contributor to belt failure [#16679971]
  • #1 16678921
    prezes1977
    Rate: 10
    Is the 1.4 60 HP engine collision. Year 2000. Engine model X14NZ. Of course, my question is about the timing belt breakage and is there great damage to the engine after such a defect?
    milejow
    Help: 1563
    Rate: 5148
    You set it up, put on the belt and drive, it's a collision-free motor.
    Moderated By ociz:
    Not true. Collision engine.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #3 16679054
    prezes1977
    Rate: 10
    Thanks for the answer, I will buy a belt and I will. Best wishes.
  • #4 16679406
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    1.6 is collision-free, 1.4 rather not.
  • #5 16679628
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    1.4 is collision - I checked it while doing some work. You can put on the belt because maybe it worked, but I doubt it
  • #6 16679971
    ociz
    Help: 1379
    Rate: 3486
    The motor is 100% collision, and the belt breaking is mostly the fault of the worn gear on the shaft.
    prezes1977 wrote:
    is such a defect followed by great damage to the engine?
    Sometimes 4 jumpers bent, sometimes all 8.
  • #7 16679973
    prezes1977
    Rate: 10
    I would like to add that the symptoms that accompanied the failure was a sound as if I were driving a tire close to the curb, a typical noise. And it came up a couple of times and as I pressed the clutch, the noise stopped. And when you tried to move from the intersection, something seemed to loosen up and it did not start. After dismantling the belt cover, there are teeth broken off the belt for a distance of about 20 cm. Best regards.
    pusty20
    Help: 66
    Rate: 213
    Check if the water pump is not seized by accident.
  • #9 16683835
    prezes1977
    Rate: 10
    empty20, 100% accurate diagnosis, seized water pump + new timing gear and the car runs like new.
  • #10 20608086
    DaroS27
    A small excavation. The 1.4 X14NZ engine is 100% collision
The discussion centers around the Opel Astra F 1.4 60hp (X14NZ engine) and the implications of timing belt breakage. Responses indicate that the X14NZ engine is a collision engine, meaning that a timing belt failure can lead to significant internal damage, including bent valves. Users shared experiences of symptoms prior to failure, such as unusual noises and issues with starting. A seized water pump was identified as a potential cause of belt failure, and after replacing the timing gear and addressing the water pump issue, one user reported that the vehicle ran smoothly again.
