Opel Astra G 1.7 TD: Timing Diagram & Head Gasket Replacement Inquiry
Bartoszek1998 16707 7
  • #1 17173213
    Bartoszek1998
    Rate: 10
    Hello, how to set the timing on Opel Astra G 1.7 TD?
    And I have a question, do you need to replace the head gasket when it was not removed, only the unscrewed screws?
    Use timing marks on camshaft and crankshaft pulleys
    #2 17173267
    barteksmrek
    Help: 89
    Rate: 224
    Why did you tighten the screws? You don't do such things. As for timing, there are marks on the camshaft pulley and on the head as well as on the shaft pulley and engine block. All characters must match. Use the book "I repair myself". Very helpful. Look in google.
    https://www.google.pl/search?ei=qyfWWsGDB8XAg...4%85du&oq=astra+g+1+7+td+ustawienie+rozrz%C4% 85du & gs_l = dogs ab.3..0i8i13i30k1.1730.8478.0.8814.20.20.0.0.0.0.156.2122.0j18.18.0 .... 0 ... ... 1c.1.64.psy-ab..2.18.2116 0i22i30k1j0i22i10i30k1j33i22i29i30k1 .0.5jgZh0i7BSU
  • #3 17173270
    Bartoszek1998
    Rate: 10
    I did it because I had to pull out the shaft, because unfortunately the camshaft jumped and broke the levers - that's why I did it. As for the book, I will read. What, do you have to change the gasket or not?
  • #4 17173273
    barteksmrek
    Help: 89
    Rate: 224
    I asked why you tightened the head bolts? What have you done As the timing has jumped, the shaft does not need to be pulled out. And the head does not need to be removed to remove the shaft (I think).
    With broken levers, you have bent valve stems and maybe cracked piston crowns.
  • #5 17173277
    web69
    Help: 188
    Rate: 629
    Broke the levers and the valves? Roll the head off, don't fight off the maniana ...
  • Timing jump means the shaft need not be removed
    #6 17173299
    Bartoszek1998
    Rate: 10
    Added after 57 [seconds]:
    I would like to do it art, I think the valves are fine because it is the second time ... during the week ...
  • Check valves, cracks, and timing with dial indicator
    #7 17173921
    Paweł#G
    Help: 19
    Rate: 118
    Like the screws removed, I would knock the head down, check the valves, and give a new head gasket. By the way, he checked the GMP dial gauge, protruding pistons and whether there are already large cracks between the valves ?
    The injection pump and the shaft set for signs, and the camshaft for the sign (but this is indicative, because the camshaft gear has no wedge) and when the camshaft is loose, the shafts set for dial indicator. Without dial indicator it is asking for problems with starting in winter.
    scheme from asters f but 99% fits
    Out of curiosity, what is the reason for the failure? Sliding strip? Some "mechanic" dipped his hands there?
    "Na artie" - what if it turns out that the valve has bent? Probably 4 or 5 times I was dealing with broken levers in this engine, once the valves were ok, but usually 1, 2 valves were bent.
  • Timing belt rubbed timing cover and jumped
    #8 17174844
    Bartoszek1998
    Rate: 10
    The reason was that the belt together with the tensioner, rubbed against the timing cover, the wheel almost made a hole in the belt, the belt got loose, and jumped.
The discussion revolves around setting the timing on an Opel Astra G 1.7 TD after a timing belt issue caused the camshaft to jump, leading to potential damage to the engine components. Participants emphasize the importance of aligning timing marks on the camshaft pulley, shaft pulley, and engine block. There is debate over whether the head gasket needs replacement if the head was not removed, with suggestions to inspect the valves and consider replacing the gasket as a precaution. The author mentions that the timing belt and tensioner had worn against the timing cover, causing the belt to loosen and jump.
