Error KERNEL32.DLL win7 - I can not install the program because kernel32.dll
azjata9512 114327 4
  • #1 16684238
    azjata9512
    Rate: 25
    I get this message "the procedure entry point was not found setdefaultdlldirectories in the kernel32.dll" when installing discord, I have windows 7 with sp1.
    The problem arises from the moment when I had to put the system back on the ground that the system disk was burned and installed on the new disk.
    I've tried to run as a cmd administrator and do a scan with "sfc / scannow", I also tried to download kernel32.dll from the net and replace it, but I do not have permission to do it and I'm not sure it will help.
    Please help ;)
  • #3 16684260
    azjata9512
    Rate: 25
    WU? And in the link install everything to win7?
  • #4 16684272
    Killlu
    Help: 64
    Rate: 66
    azjata9512 wrote:
    everything to win7?
    For your system version.
  • #5 16684289
    azjata9512
    Rate: 25
    Thanks for the help :) It works :) I installed and everything started :)
