Fiat Panda II: Fixing Flail Gearbox, Damaged Roller Bearing, & Sliding Clutch at 270,000km
jbek 28035 13
  • #1 16684632
    jbek
    Rate: 82
    I would like to share information on how to deal with the "crushing" Fiat Panda 2 gearbox and then with the sliding clutch (in my case, first was the "crumbling" of the box and then slipping the clutch).
    The gearbox was damaged due to the damaged roller bearing, which has 7 balls. It is the most delicate bearing of this car's box, although in my case it went up to 270,000. kilometers. It is located on the side of the gearbox housing, called the bell of the box, just at the exit of the shaft on the clutch disc. Damage to the bearing has its basket, which is made of plastic. The elements of this basket, therefore, are not so harmful to the work of the other elements of the box (its sprockets, synchronizers). I personally dismantled the entire gearbox to replace it. After checking the elements of the box (watchmaker's loupe): gears, synchronizers, including its remaining bearings, it turned out that they are in perfect condition and do not have to be replaced. Some experts, however, recommend replacing all bearings. In my opinion, there is no need to expose yourself to additional costs of repairing the box (the cost of all Fiat Panda gearbox bearings is about 700 to 800 PLN). The cost of damaged, in my chest, SKF bearing in ASO is about 100 PLN. And it is worth to put them on. There are such Polish production bearings with 8 balls and a plastic basket for about PLN 15 (most likely intended for the Fiat Seicento gearbox), but I do not recommend them. I watched both of these bearings under the watchmaker's magnifying glass and SKF is more accurately made and mounted. You can also set up a roller bearing of the French company SNR matching the Fiat Panda box, mounted, among others in boxes eg Fiat Doblo. Its cost is also about PLN 100, but it is supposedly more durable. I do not know how loud it would work in the box compared to the original ball, so I did not assume it.
    The box was working loudly, because you could hear yourself bumping the bearings in which the basket was damaged. There were also metal rubbing noise from the metal coming from the friction of the shaft of the attacking roller against the metal part of the shaft's simering as a result of the play in the damaged bearing.
    However, the proper reason for gearbox regeneration was the slipping clutch. The reason for this was getting onto the clutch disc of oil from the box by unsealed simering due to the beating of the shaft, which was the result of damage to the bearing, which was loose. It was impossible to drive. With such a slipping clutch, I passed a week until I started repairing. On the occasion of repairing the box, I exchanged all its simering and o-rings, simering the crankshaft from the clutch side (it was necessary to unscrew the flywheel) and replaced the clutch, ie clutch plate, impression and impression bearing. I exchanged the clutch in my car during this work for the first time since the news. Therefore, 270,000 traveled. kilometers and you could really ride it, because the clutch plate was quite well, the impression bearing was also, but the impression feathers were too much worn from the impression bearing. I've replaced the whole clutch. When replacing the gearbox selector, it is necessary to buy a wedge that broke in half when punching. It serves to attach in a suitable place the sliders of the selector, pushing the cradle of the crate, on the shaft / axis of the selector..
    From my observations, during these works it appears that one could risk and not undress the entire gearbox, what is being done from the 5th gear in the dome. As I wrote above, the basket of the damaged bearing is made of plastic and, as a rule, its remains, even if they fell deeper into the chest, should not cause damage to other components - gears, synchronizers. There were all 7 balls in it - none of them disintegrated and did not threaten damage to other elements of the crate, and other bearings are massive. Also, despite the "crunching" of the box, the fact that its components (except for the mentioned damaged bearing and simering) are okay can be assumed after properly switching on (putting in) all the gears. Therefore, to get only to the mentioned, the most delicate, damaged bearing and oil permoring, it would be enough to unscrew the bell of the box and there are damaged parts available immediately for exchange, as on the palm of your hand. Of course, in this way we will not check the condition of the other elements of the chest and we will not rinse it thoroughly, but we will do less for it. Here I must point out that my chest was not so dirty inside that it would be necessary to clean it. The box requires external cleaning before it is dismantled. In this case, it would also not be necessary to replace counter nuts on both rollers, i.e. attacker and intermediate (cost 2 x 11 zlotys = 22 zlotys), twisting all gears, synchronizers and other bearings together so that they do not move because they would not be unscrewed. These nuts are in a sense one-off, because their sides are bent in two places so that they do not unscrew.
    Here, I betray to unscrew the nuts that counter the shafts of the box, it should be locked both of them by throwing two gears. I did it with the gear selector removed.
    By doing this repair, you do it at your own risk.
    I emphasize here that I did not try to disassemble the chest from the side of the bell and I do not know if it is possible at all (I was just curious and undressed it all). I saw, however, a picture of the chest with its bell dismantled on one of the Forums. I give him a link:
    http://fiatpunto.com.pl/post375002.html.
    Speech is there about the Fiat Punto II, which is very similar to Fiat Panda. The picture shows a roller bearing on the shaft attacking from the side of the bell, with which I had a problem, only mine was ball. Link to the photo:
    http://fiatpunto.com.pl/largeimg,IMG_4c0579837fe7f820.jpg.
    In this case, during such disassembly, along with the bell of the chest would have to go out, bolted to it, a reverse gear stick, which would have to descend from the reverse gear rack and perhaps this back rack will come with it. In addition, the reverse slider would have to descend from the ball pusher, which is located on the axis of the other race sliders. I do not know how it would go, the reverse process, i.e. the assembly of the chest. I think, however, that it is worth a try and I personally would try to disassemble the chest (from the bell's side) during the next refurbishment.
    When assembling the crate, I used a torque wrench and the screws, on the glue that prevents them from loosening, I tightened with the recommended moments.
    The repair costs are less than PLN 500 - the same spare parts, including the entire Valeo clutch, simering (Corteco), O-rings, SKF bearing, counter nuts of both gear shafts, hub fixing nuts for the drive bolts, mass cable because I damaged it during disassembly and maybe something yet. The costs of repair do not include the purchase of tools in Biedronka, Lidl, Kaufland, Castorama, which I used during the repair. When I repair something myself, I allocate a part of the cash for the purchase of tools, because I do not pay for the repair service that I have done myself and are useful for the next.
    I have not written anything yet about the dismantling and assembly of the box. I did these works under the house, next to the garage, without a channel! Yes, without channel !!! It's good that it was not raining! Everyone was surprised how I did it, I have a gentle belly, so to speak, and they wondered how I fit in under my car. And I raised it quite well in the front and put it on Lidl's trestles. I put one hydraulic jack with Biedronka under the oil sump of the engine. The second hydraulic lift from Biedronka is a chest. This second lift for the chest, you do not need it and you can do everything only one thing. Because Panda's chest is not that heavy, but you have to somehow protect it from falling down, it helped me with the help of a rope a little son who does the muscles in the gym. I unscrewed the appropriate bolts with the keys from Biedronka, Lidl, Kaufland and the chests pulled out from the left front wheel. First of all you had to unscrew the nuts holding the hubs to the driveshafts (here you need a massive key, because they are twisted 240 Nm torque and additionally baked, you need to hold the foot on the brake when unscrewing - I borrowed the key from the neighbor, but then I bought one myself) , wheels, bolts fixing shock absorbers to the hub mechanism (no other need to unscrew). Before extracting the driveshafts, drain the oil from the box so that it does not leak. After removing the outer joints of the semi-axles from the hubs, one should pull out the inner joints of the axle shaft from the box, eg with the side part of the wood chisel - that's what I did. The joints of the internal driveshafts leave the box without a problem. You do not need to download the gums of the joints here! Then the need was to disassemble the battery and the basket in which it is located. The built-in battery and basket facilitate access to the screws with which the box is bolted to the engine. Under the basket there is also a screw, which box with the engine is bolted by a rubber cushion to the engine compartment of the car body. The screw should also be removed. Do not forget to unscrew the screws from the chest lollipop, which is located underneath the car. The chest lollipop is one of the three elements that fix the entire engine with the gearbox to the car's body on the rubber (the engine leg is the last of these three elements, I mentioned the box cushion earlier). After unscrewing the bolts burning the engine box, do not forget to secure the starter, which is kept only on the power cables, so as not to get hit by them. The starter does not need to be completely removed, it can be placed on the suspension elements. Installation should be carried out in reverse order for disassembly and here I used torque wrenches purchased in Castorama and Kaufland when turning.
    After repair the car works as if it has just left the salon.
    I would like to point out here that I did this work alone (with the delicate help of my son and my closest friend) and for the first time in my life and it was possible thanks to the numerous information on the Internet forums..in. also on Elektrodzie. I did not ask any mechanics about how to do it. And here I can write that I acquired, through this repair, in a sense the skills (powers) of a motor vehicle mechanic, although I am not a profession of it, of which I am very happy and satisfied.
    If I helped someone with my subject, please click on this post: "Helpful post?" at the top of the text on the left, possibly with a gift of a point. Pressing "Helpful post?" you only charge 0.2 points.
    jbek :bye:
    Pictures of my chest:
    Fiat Panda II: Fixing Flail Gearbox, Damaged Roller Bearing, & Sliding Clutch at 270,000km Fiat Panda II: Fixing Flail Gearbox, Damaged Roller Bearing, & Sliding Clutch at 270,000km Fiat Panda II: Fixing Flail Gearbox, Damaged Roller Bearing, & Sliding Clutch at 270,000km Fiat Panda II: Fixing Flail Gearbox, Damaged Roller Bearing, & Sliding Clutch at 270,000km Fiat Panda II: Fixing Flail Gearbox, Damaged Roller Bearing, & Sliding Clutch at 270,000km
  • #2 16692871
    Paradisehm
    Rate: 9
    Very helpful fast, best regards :)
  • #3 18522620
    lukparis
    hello I confirm you can replace the bearing by unscrewing only the bell of the chest with the selector. Much less work we unscrew only the left wheel, the lid of the box and the attachment of the clutch cable. you don't even have to touch polosi. the only problem is only during assembly with this reverse closure inside the box but you can :) this is to go through. Best regards fiat panda1.2 year 2011
  • #4 18822264
    widuch sławomir
    Rate: 24
    Hello, where did you buy the seals for this box, or did you cut them yourself and what moments did you tighten the clamp and other elements, you can write here, and so the post is very helpful
  • #5 18829464
    jbek
    Rate: 82
    To seal the gearbox, while assembling it, I used the original high-temperature silicone gasket number: 71753861 purchased from an Authorized Service Center (it's just high-temperature silicone in a tube - like toothpaste).
    The tightening torques for the screws of the Fiat Panda gearbox were taken from the Internet and based on the Fiat Punto II C514 gearbox (I also found a few tightening torques for the Fiat Panda):
    - fastening of the bracket for the reverse lever: 15 Nm,
    - 5th gear fork mounting: 12 Nm,
    - nuts fixing gears of 5th gear on the clutch shaft and main shaft: 118 Nm,
    - 5th gear cover mounting: 12 Nm,
    - gear cover mounting: 20 Nm,
    - oil filler cap: 36 Nm,
    - oil drain plug: 22 Nm,
    also:
    - flywheel mounting bolts: 44 Nm (I unscrewed them because I replaced the oil seal),
    - clamping bolts: 25 Nm,
    - bolts securing the gearbox to the engine: 80 Nm,
    - starter mounting bolts: 27 Nm,
    - hub knuckle mounting bolts to the shock absorber socket: 75 Nm,
    - driveshaft nuts: 240 Nm,
    - bolts for fixing steel rims: 86 Nm,
    - aluminum rim mounting bolts: 98 Nm.
    I secured practically all bolts of the box against unscrewing with blue glue. I used the red locking bolt glue to tighten the flywheel.
    best regards
    jbek
  • Need to remove shaft to replace differential bearing
    #6 20299672
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    Hello. I didn't want to start a new topic because this one is very similar and the solution can be useful as a development. Encouraged by your awesome description, I decided to "renovate" my gearbox. I unscrewed the bell and separated it from the whole box by unscrewing the two screws inside. Unfortunately, the bearing is smaller and easily accessible, it is ok. The damaged one is the big one under the gear that enters the differential, on the left side below ? Yes normally, i.e. forward, it will unfortunately not go down (inner diameter is smaller than the gear) ? You probably need to remove the whole shaft and remove all its components one by one and remove the bearing to the rear and reassemble in the reverse order. I hope I'm wrong and there's an easier way to do this. If anyone has any experience or ideas, please help because the car is on wheels and winter is just around the corner.
    P.S
    I don't know how to give up points so that I don't collect points looking for help, I will give all points to the person who helps ?
  • Hydraulic press needed to remove damaged bearing
    #7 20300032
    jbek
    Rate: 82
    It should be done as you wrote: "You probably need to remove the entire shaft and remove all its elements one by one and remove the bearing to the back and reassemble in the reverse order." There is no other alternative. You will have to dismantle the chest, as I did and described in the topic above. Then you will have to use a hydraulic press and bearing pullers to remove the damaged bearing and shaft components and reassemble them.
    Regards
    jbek
  • #8 20300077
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    And I was hoping that I could do without it ? One question - if I unscrew these nuts at the back, pull the rollers forward with the selectors or somehow selectors first, and then the rollers ? Maybe a stupid question but I don't want to spoil something and I don't want something to fall out and I don't know where from
  • Recommend disassembling gearbox from 5th gear cover side
    #9 20300115
    jbek
    Rate: 82
    In my opinion, disassembly of the gearbox from the side of its bell can be attempted only when we are 100% sure that only the smallest bearing of the attacking shaft is damaged (advantages of this method of disassembling the gearbox: you can easily and quickly replace the damaged small bearing of this shaft and less work, disadvantages: you will not check the condition of the other elements of the box). Otherwise, it is best to dismantle the gearbox from its other side, i.e. from the steel cover of the fifth gear gearbox. In your case, I would advise you to put the gearbox back together and disassemble it, as I indicated in the previous sentence, from the steel cover of the fifth gear gearbox. It must be remembered that the nuts securing the 5th gears on the shafts are tightened with a large torque and to unscrew them, you must first lock both shafts against each other, and then apply yourself to the wrench. Due to this procedure, it is important that the box is in its entirety (the bell and the middle casing of the box are screwed together). By disassembling the gearbox in this way, it will be easier to remember the reverse order of its assembly. If you disassemble the gearbox from its bell, and then from the steel cover of the fifth gear gearbox, you will most likely not know how to put it back together. In this case, to assemble the box, you will have to use the service manual of the car, or give it to a person who already has experience in repairing it. Once you unscrew the nuts of the shafts securing the gears of the 5th gear, you will pull out these shafts together with the selectors, after removing the middle part of the gearbox housing, of course. However, you must first unscrew one screw on the side of this housing, which holds the axis of the reverse gear mode (if I remember correctly, because I dismantled my Panda's gearbox a long time ago - 5 years ago, and the car after my regeneration of the gearbox is still running and has already driven 370 thousand km). In addition, you also need to remove the retaining rings from the bearings, with which the shafts are mounted to the steel middle plate of the gearbox housing (the plate and the retaining rings can be seen in the last photo of this topic, they are on a table against the wall). A hydraulic press can be used to empty the shaft of its components to remove the damaged bearing. Recently, when I was replacing the bearings in the M32 gearbox of my second car, Fiat Bravo II, I bought a 30-ton press (PLN 1,500) especially, because without it I would not have been able to deal with this problem. The use of a hydraulic press can be very helpful in disassembly and assembly of bearings and shaft components. Especially when you have to dismantle the entire main shaft, which is the case in your case, where the bearing you failed in the Panda gearbox is at the very bottom of the shaft, with its mode cooperating with the differential gear mode. Note here, when disassembling the shaft elements, it is very important which mode to grab to pull it all together. Grasping the wrong gear during removal can lead to damage to some of the shaft's dismounted elements, especially since its individual elements can be locked onto it with the appropriate snap rings, which must be removed with the appropriate pliers (these snap rings are similar to the ones I mentioned earlier, but have a smaller diameter matched to the shaft). I do not know how to catch the individual modes when removing them from the shaft, because I did not do it when repairing my Panda's gearbox (I dismantledand I dressed "Christmas trees" - shafts, of my Fiat Bravo II), because it was the bearing that failed you, I didn't have to replace it. You need to look on the Internet about which part of the shaft you need to grip properly to get everything off it. If you do not find such information, in your place I would try to carefully grasp the individual elements of the roller and pull them off sensitively so as not to damage them. It should be remembered that only the modes of individual gears are firmly mounted on the shaft on the spline, the rest slides freely. A puller may also be needed to remove the gears and synchronizers from the shaft. The hydraulic press, however, will be very helpful when installing a new bearing, as well as other elements of the shaft, previously removed. It ensures smooth sliding of elements onto the shaft. If it is not possible to use it, the only option is to beat it with a hammer using properly prepared bushings, and this may not end well for the shaft elements that are mounted back - they can be damaged.
    Regards
    jbek
  • Stronger puller and impact wrench for gearbox strip-down
    #10 20301743
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    The chest dismantled, the "Christmas tree" dismantled. The press is not needed, a stronger puller is enough and pliers are needed to remove the rings because there are two. You don't need to block the shafts to unscrew, an impact wrench is enough. I bent the nut protections with a suitable screwdriver. The disassembly went relatively smoothly but putting it all together can be quite a challenge but I have a lot of photos. The bearing will come, there will be assembly ?
  • #11 20303775
    jbek
    Rate: 82
    However, I would advise using a hydraulic press to dress the "Christmas tree" (roller). If you don't have it, I think you can always count on your good friends who can lend it to you.
    Regards
    jbek
  • #12 20308853
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    Christmas tree folded. I used the press to press the bearings in because they are not cheap, besides, it must work as long as possible. Tomorrow I will have seals for the shaft, selector and axle shafts, I will put the box together and install it. It should be dry and quiet.
    I will use the moments for torsion of the box from your description. You've done a great job ?
  • #13 21918689
    Meister99
    Hello, I would like to know how the gearbox in the Panda is performing today after your refurbishment?
  • #14 21921507
    jbek
    Rate: 82
    I had the gearbox in my Panda reconditioned when it had done 270,000 kilometres. The car now has 470,000 kilometres on the clock and is still going strong. The gearbox is working properly; I can’t tell any difference compared to how it worked when it had done 7,000 kilometres, back when I bought the car.
Discussion of repairing a Fiat Panda II gearbox damaged by a failed roller bearing on the clutch/input shaft side, followed by clutch slipping. The gearbox was dismantled, inspected, and found to have intact gears and synchronizers, so only the damaged bearing and related seals were replaced. The thread covers two repair approaches: removing only the bell housing for the smallest bearing, or fully dismantling the gearbox from the 5th-gear cover side when the larger bearing on the differential/input shaft side is damaged. Practical details include using a hydraulic press or strong puller, impact wrench, sealant instead of a paper gasket, replacement of shaft/selector/axle seals, and tightening torques for gearbox and related fasteners. A later update confirms the rebuilt gearbox remained reliable after extensive use, with the car reaching 470,000 km.
TL;DR: Fiat Panda II/C514 gearbox “crunching” often traces to a failed 7-ball input bearing; a home fix can cost < PLN 500. “There is no other alternative” than full teardown if the larger shaft bearing fails. [Elektroda, jbek, post #16684632] Why it matters: This FAQ shows DIYers how to diagnose slipping clutch and noisy gearbox, choose parts, and decide when a partial vs full rebuild makes sense for a Panda II.
How do I diagnose the Panda II “crunching” gearbox and slipping clutch?
Listen for bearing rumble and metallic rub that changes with clutch use. Oil on the clutch disc from a leaking input seal causes slip. Damage starts when the small input bearing loosens, letting the shaft beat the seal. If gears still engage cleanly, internals are often fine. Replace the failed bearing and seals to stop the slip and noise. Inspect synchronizers with a loupe if you fully open the case. [Elektroda, jbek, post #16684632]
Can I replace the noisy small input bearing without stripping the whole gearbox?
Yes, if only the small input bearing is bad. Remove the bell housing with the selector attached, then replace the bearing and the input seal. This saves time and avoids axles in some setups. Expect a tricky reverse idler alignment during refit. If more than that bearing is damaged, stop and plan a full teardown. [Elektroda, lukparis, post #18522620]
When is a full C514 teardown mandatory?
If the larger bearing under the gear driving the differential is damaged, you must remove the entire shaft, strip components in order, press off the bearing, and reassemble. As one expert put it, “There is no other alternative.” Attempting shortcuts risks internal damage and misassembly. [Elektroda, jbek, post #20300032]
What causes the clutch to slip after gearbox noise starts?
Play from a failed input bearing lets the shaft beat the seal, leaking gearbox oil onto the clutch disc. The disc then slips under load. Replacing the bearing, input seal (simering), and fitting a new clutch kit restores drive. The poster drove one week with slip before repair; avoid prolonged use to prevent disc glazing. [Elektroda, jbek, post #16684632]
What torque values should I use during reassembly?
Examples: 5th-gear fork 12 Nm, cover 12–20 Nm (steel cover 20 Nm), 5th-gear nuts 118 Nm, gearbox-to-engine bolts 80 Nm, flywheel bolts 44 Nm, driveshaft hub nuts 240 Nm, wheel bolts 86 Nm (steel) or 98 Nm (alloy). Apply blue threadlocker on most gearbox fasteners and red on the flywheel bolts. [Elektroda, jbek, post #18829464]
Which sealant and seals should I use on the Panda II gearbox?
Use high-temperature silicone gasket PN 71753861 on mating faces. Replace input/output simerings and O-rings while open. Many DIYers choose Corteco seals and SKF or SNR bearings for durability. Clean the exterior case before removal, then apply sealant sparingly and torque to spec. [Elektroda, jbek, post #18829464]
Do I need special tools like a press, or will a puller and impact wrench do?
For the small-bearing-only job, standard pullers and hand tools work. For main-shaft bearing service, use a hydraulic press to avoid damaging costly gears and synchronizers. An impact wrench can remove 5th-gear nuts without cross-locking shafts, but protect nut locks and threads. “The press is very helpful” for dressing the shaft. [Elektroda, zdzichra, post #20301743]
Is it safe to leave plastic cage debris inside if I only swap the small bearing?
The failed small bearing’s cage is plastic, so fragments are less harmful than metal. If all seven balls remain intact and gears engage correctly, a targeted repair from the bell side is reasonable. However, you will not inspect or flush the entire box this way. [Elektroda, jbek, post #16684632]
What brands and part choices work well (bearings and clutch)?
SKF small input bearing fits and runs quietly; SNR is a durable alternative. Avoid very cheap 8-ball units intended for other Fiat boxes. A Valeo clutch kit performed well even at 270,000 km before replacement. Replace counter nuts and hub nuts if deformed by staking. [Elektroda, jbek, post #16684632]
How do I remove the gearbox in a driveway without a lift?
Raise the front on stands, remove battery and tray, drain oil, remove hub-to-axle nuts (240 Nm), separate outer CVs from hubs, pop inner joints from the box, support engine and gearbox with jacks, unbolt mounts and starter, then withdraw the box through the left wheel well. Reinstall in reverse with a torque wrench. [Elektroda, jbek, post #16684632]
Quick 3-step: How to swap only the small input bearing from the bell side?
  1. Remove left wheel, bell housing with selector, and clutch cable bracket; keep axles in if your layout allows.
  2. Extract small input bearing and replace the input seal; inspect reverse idler alignment.
  3. Refit bell housing, set selector correctly, seal, and torque fasteners. [Elektroda, lukparis, post #18522620]
Any assembly pitfalls on the reverse gear and selectors?
During bell-side service, the reverse idler and its actuator can misalign on reassembly. Expect patience guiding the reverse fork/closure back onto the idler and ball pusher. Photograph selector positions before disassembly to avoid mis-shifts after startup. [Elektroda, lukparis, post #18522620]
What’s the real-world outcome after this DIY rebuild?
After replacing the failed bearing, seals, and clutch, the Panda “works as if it has just left the salon.” One vehicle continued past 370,000 km after a 270,000 km service, demonstrating longevity when set up correctly. [Elektroda, jbek, post #20300115]
Edge case: What if the bearing is trapped behind a gear with a smaller inner diameter?
You must remove the whole shaft, strip components in order, and pull the bearing from the rear, then rebuild in reverse sequence. Plan for snap-ring pliers, a strong puller, and ideally a press for reassembly to avoid gear damage. [Elektroda, zdzichra, post #20299672]
Can I really avoid touching the driveshafts for the bell-only bearing swap?
On some Panda 1.2 (2011) configurations, yes. Users report removing only the left wheel, box lid, and clutch cable bracket to access the small bearing. Expect careful alignment during reassembly, especially on reverse gear components. [Elektroda, lukparis, post #18522620]
Should I replace every bearing while I’m inside the gearbox?
If inspection shows gears, synchronizers, and other bearings in perfect condition, replacing only the failed unit can control cost. Complete bearing kits (~PLN 700–800) add expense without guaranteed benefit when parts are healthy. Choose quality brands and renew seals regardless. [Elektroda, jbek, post #16684632]
