Punto 2 Wiper Mechanism Replacement: Broken Part, Mechanism Only or with Engine?
gsmowiec 6933 7
  • #1 17045316
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    I have a broken wiper mechanism in the place marked below.
    Will I buy the mechanism only or only with the engine?
    andseg
    Help: 32
    Rate: 89
    I would try to fix it - by soldering, riveting.
    The photo does not show exactly the damage, but it is a pity to give up the remaining functional elements.
    if you do not feel up to it yourself, look for a small workshop, locksmith, etc. in the vicinity. Buying a new one is a last resort.
    I pick up.
  • #3 17045434
    gsmowiec
    Help: 27
    Rate: 128
    This is a pictorial photo - I have it broken exactly in the place I marked with a black line. The plastic in the middle has broken and a piece of it has been pressed in this tube
  • #4 17045743
    andseg
    Help: 32
    Rate: 89
    I think it is not difficult to repair - the broken plastic from the tube can be easily removed by heating it - and in this place you can place a prepared piece of metal sheet with a thickness of 1-2 millimeters, the element to which you attach the rest. Connections of elements - hammer, rivet, solder, use epoxy glue. It all depends on how much space there is -.
    Best regards and good luck with the repair.
  • #5 17047198
    RobertLodz09
    Level 30  
    Help: 123
    Rate: 542
    You buy it in a set, you can look for something disassembling it, just pay attention to the degree of wear.
  • #6 17047501
    qoompel
    Help: 25
    Rate: 197
    gsmowiec wrote:
    I have it torn off exactly in the place I marked with a black line. The plastic inside broke and a piece of it was pressed in this tube
    If I picture it right, it's epoxy glue and drive. Just prepare the material well.
    The cheapest two-component (this is what you are interested in) epoxy from Dragon costs about PLN 9.
  • Recommend replacing the wiper mechanism instead of repairing it
    #7 17136112
    Mourin
    If I can advise you, I would replace it with a new one, the cost of PLN 115, or the cost of PLN 30. Welded gluing, metal soldering, gives mediocre results, and wipers on snow, ice or with a dry glass have quite a lot of resistance, so in order not to return to the topic, it is worth trying the above-mentioned repair.
    Ps. if you don't have anything to do with this broken mechanism, maybe we could agree on a replacement.
    Greetings Marcin
  • #8 17136188
    Ricoh_220
    Help: 464
    Rate: 754
    Only exchange for stimulant.
    It's not expensive, check on aledrogoo I paid 80 zlotys for the Skoda Octavi. Lubricate the eccentrics before assembly. And you have peace of mind for years.
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
The discussion revolves around the replacement of a broken wiper mechanism for a Fiat Punto 2. Users suggest various repair options, including soldering or riveting the broken plastic part, and using epoxy glue for a more durable fix. Some recommend purchasing a new mechanism, citing costs ranging from PLN 30 to PLN 115, while others advise checking for used parts to save money. The consensus leans towards replacing the entire mechanism for reliability, especially under challenging weather conditions.
