VOLVO V70 Climatronics Error: CCM-0070, Potential Causes & Solutions, AC & DSTC Systems
18471 11
Why does my Volvo V70 show CCM-0070 when the climate control works normally, and what should I check?
CCM-0070 points to a communication/CAN problem with a subordinate module or its signal path, not necessarily a fault in the climate panel itself [#16686370] If the error is active, related functions can be disabled; if it is passive but keeps returning, the expected default message is not being received and the fault may be intermittent or not immediately noticeable [#16687015] The usual suspects are the module, twisted pair, terminator, connector, bad sensor, or fuse, so check connectors and harnesses and measure the twisted-pair resistance and voltage to locate the break [#16687015][#16698177] Volvo guidance is to rule out bus faults before any calibration or coding, because those actions can aggravate the problem [#16688010][#16698177] If the climate system still works normally, the code may simply be stored in memory, but it still indicates a bus/communication issue somewhere in the linked system [#16687015][#16698177]
  • #1 16685492
  • #3 16685817
  • #4 16686370
    Hektar Zahler
    Help: 230
    Rate: 528
    My friend, the program's hint regarding the communication of the air-conditioning panel is very good, that it suggests something with a subordinate module .. And it is not surprising that the panel is associated with heating or parktronics (or even - the second suggestion from the top, A / C request - with the engine ), because it is he who sends messages on the bus to the controller to enable a given function in it. It's not what you think. Well, it has been a standard for some time due to the saving of wires in a bundle, for example. I wonder what you mean with this heating, because I take this line of reasoning for total ignorance of what and how about this CAN, because in the event of a communication break, Volvo always indicates the controller from which the answer is expected - which also the other two errors (i.e. SAS -> BCM direction as well as AUM -> CEM) you can see that it is. And that's how they should be understood. Because Volvo must be understood.
    It is extremely important in such situations to observe what in the car does not work as intended, because people do not care. For example, they consider the lack of a turn signal buzzer or some "former stupidities" to be insignificant, or temporary, when in fact it may be a sign of a serious CAN fault (including vehicle immobilization).
  • #5 16686642
    Hektar Zahler
    Help: 230
    Rate: 528
    It might be different, because you don't know what's going on. There are three options. 1 - when the errors are active, it means that the functions related to the broken / non-existent connection are disabled. For example, in the event of a steering sensor failure, the traction control will stop working and I suspect that this is the case, because I cannot imagine it otherwise. Sometimes there are no more important messages and the symptoms are, so to speak, visible to the naked eye. 2 - if the error is passive, but it keeps coming back, it means that the so-called The "default message" is not received on request, an error appears that appears as remembered, but nevertheless the integrity of the system is not broken or limited in a manner imperceptible to the car driver. Ie. the symptoms may be more or less severe, or may not be completely noticeable. 3 - has the right to not work all or some of the controllers, but the non-working ones may be completely dead, or (which is easy to deduce) it may be a random fault (e.g. due to poor contact) and mean difficulties with localization. Usually, however, if no one knows what is, we have the option of no. 3 and then no computer will help, only knowledge of CAN and logical thinking. And if you do not understand it, it is important to know that breaking communication is the need to restore it immediately, keeping your hands away from any calibrations, etc. that may aggravate errors in the system. Often the result of not heating the engine or the cabin, because as I said when it passes, no one has a clue what was the reason. Funny, but it happens when the car is not driven much. . The problem is whether the fault will return, and this is already the Virgin Mary. Usually it is about tracing the source by measuring the resistance of the twisted pair, its voltage. The module, twisted pair, terminator, connector, bad sensor, fuse, etc. may be damaged.
  • #7 16687277
  • #8 16688010
    Hektar Zahler
    Help: 230
    Rate: 528
    There is no universal prescription for CAN and each case is individual (so I'm aiming for it). Maybe you didn't even dream about it, because the unplugged ankle of the radio complicates the matter to some extent. It is about the lack of a 120? terminator that could be in it, although I do not know it. I would not say it as if in practice it was not confirmed (probably fiat doblo from what I know). Therefore, I repeat, every detail that may seem irrelevant is important. The blame on the twisted pair is actually forgotten, because it is not a truck, but there are a lot of possibilities. Component activation is this plus the current parameters, and there are two types of them in this car: two-wire CAN and single-wire LIN (as in BMW).
    Perhaps the configuration error is something else (but something like that), except that the CAN error can be fixed immediately.
    Transmission errors can be divided into two types again:
    - detectable and explainable (those recorded)
    - undetectable and unpredictable (perceived as driver's interference, i.e. cruise control waves, etc.)
    Volvo instructions press hard to rule out errors in the fieldbus when calibrating or coding.
    Without it, there's really nothing to talk about.
  • #9 16688131
  • #10 16688170
    Hektar Zahler
    Help: 230
    Rate: 528
    My friend about the VIDA program is summer next to my bag. But I know the truck program and what is said in the instructions. They will half-point everything, and this is the excess of hints in non-existent modules. And that's the truth. Half of them have no idea about the effects of a CAN malfunction. The fault of any sensor as a result of proper operation is still possible (with a factory defect at the forefront, which I do not want to say directly), and you don't get it, because it happens. That's why it's good to have a rule that in the past electronics was not so developed. Ie. if there is a fault of the torsion sensor, unfastening the ankle will fix the errors on the bus. This is for peasant reason. Besides, they are like AQS (cabin air sensor) etc.
    Added after 2 [hours] 2 [minutes]:
    In case of illustrating what it looks like, please see the LIN diagram of the V70 air-conditioning panel.
    Signs:
    SHM - seat heating module
    DMM - damper motor module
    ECC - electronic climate control system
    CCM - Climate Control Module
    AQS - air quality sensor
    LHD - left hand drive
    RHD - right hand drive
    CAN looks similar, but much more extensive.
  • #11 16697966
  • Active CAN fault means physical bus damage
    #12 16698177
    Hektar Zahler
    Help: 230
    Rate: 528
    Buddy, there is nothing to rediscover America, because with an active CAN error, this system is seriously damaged and some modules work in emergency mode. Like any vehicle with a similar fault, it is badly damaged. Therefore, as I said, hands away from coding on a malfunctioning bus. And although the symptoms may not be noticeable as serious, it should be presumed that until they are corrected they may appear, and even pose a hazard on the road, and remember it. It's not like you code something and the error disappears, only the fault is a physical damage of a nature unstable as evidenced by DSC what works when it wants, and you don't know the source of the problem (check connectors, harnesses, etc.).
    eurotips wrote:
    to change anything in Car Config it's just an Authorized Service Center
    As an example of what is not allowed to do this, I am pasting a translation of an almost identical error from the Volva D7C bus (twin year old) over which we are sitting at the moment, because it's all like peas against the wall normally. As if I speak Japanese to you. Needless to say, almost identical ones are now being lost successively while restoring communication.
    VOLVO V70 Climatronics Error: CCM-0070, Potential Causes & Solutions, AC & DSTC Systems VOLVO V70 Climatronics Error: CCM-0070, Potential Causes & Solutions, AC & DSTC Systems
The discussion revolves around the CCM-0070 error in the Volvo V70's climate control system, with users exploring potential causes and solutions. The error appears to be linked to communication issues within the vehicle's CAN bus system, affecting various modules, including air conditioning and DSTC (Dynamic Stability and Traction Control). Users suggest that if the climate control functions normally, the error may not indicate a critical fault. Calibration attempts and battery disconnection did not resolve the issue, leading to speculation about connector problems or previous modifications to the vehicle's systems. The complexity of the Volvo's electronic architecture, including the interaction between different modules, is emphasized, with suggestions to check for wiring issues and the importance of proper coding for replaced components. Ultimately, some users express a willingness to live with the error if the system operates correctly, while others stress the need for thorough diagnostics to prevent potential safety hazards.
TL;DR: CCM-0070 on a Volvo V70 usually flags a communication fault on the climate module’s CAN/LIN network; note the 120 Ω terminator detail and the expert warning: "breaking communication is the need to restore it immediately." [Elektroda, Hektar Zahler, post #16687015]
Why it matters: This FAQ helps V70 owners diagnose CCM-0070, avoid unsafe DSTC behavior, and decide what to fix or code in VIDA.
What does Volvo code CCM-0070 actually mean on a V70?
It indicates the climate panel (CCM) reports lost or invalid communication with a subordinate module over the vehicle network. The CCM brokers messages to other systems, so a bus fault can surface as an air‑conditioning code even when cooling works. Fix network integrity first. [Elektroda, Hektar Zahler, post #16686370]
My AC works fine—should I ignore CCM‑0070?
No. Communication faults can place modules into fallback modes and later disable functions. Drivers may miss subtle symptoms until DSTC or other safety features drop out. “With an active CAN error, this system is seriously damaged.” Address bus health before anything else. [Elektroda, Hektar Zahler, post #16698177]
Could an aftermarket or swapped radio cause CCM‑0070?
Yes. An unplugged or incompatible radio can remove a 120 Ω terminator from the network, upsetting bus integrity and triggering communication errors like CCM‑0070. Reconnect or restore termination before further diagnostics. [Elektroda, Hektar Zahler, post #16688010]
Why did DSTC disable when CCM‑0070 appeared?
Shared network issues affect multiple modules. A steering angle sensor communication fault can make traction/DSTC switch off. If bus integrity drops, expect cross‑system warnings alongside CCM‑0070. [Elektroda, Hektar Zahler, post #16687015]
What is a CAN bus, and what is LIN in this Volvo?
CAN is a two‑wire high‑speed network linking control modules; LIN is a single‑wire sub‑bus for simpler nodes like damper motors or sensors. The V70 climate system uses both; faults on either can surface as CCM‑0070. [Elektroda, Hektar Zahler, post #16688010]
How do I run a safe CCM calibration in VIDA?
Follow this sequence: 1) Clear and repair bus faults first. 2) Verify connectors, fuses, and module power. 3) Then run VIDA Component Activation/Calibration. Volvo guidance warns against calibrations on a faulty fieldbus because it can worsen errors. [Elektroda, Hektar Zahler, post #16688010]
I tried calibration and got “Permanent Error” with CCM‑0070—what now?
Stop calibrations. Inspect network connectors, twisted‑pair integrity, and power to mirror modules or heaters. Restore communication, then retry. Battery disconnects won’t repair wiring or termination faults. [Elektroda, Anonymous, post #16685817]
Could missing BLIS/Park Assist coding be the reason?
If the car was reconfigured or modules removed, VIDA can still show hints for non‑present equipment. However, the key issue here is communication health. Resolve bus errors first; then address configuration at ASO if needed. [Elektroda, Hektar Zahler, post #16688170]
How much does coding a used radio typically cost at ASO?
A forum user reported PLN 350 + VAT for coding a used, model‑correct radio at an Authorized Service. Prices vary by dealer and region. [Elektroda, Anonymous, post #16688131]
Is there a quick 3‑step way to check bus integrity before chasing modules?
Yes: 1) Measure twisted‑pair resistance and supply voltage; confirm expected values. 2) Inspect connectors, fuses, and harness for poor contact. 3) Restore termination and re‑test communication. “Restore it immediately” if communication is broken. [Elektroda, Hektar Zahler, post #16687015]
Why does the climate panel reference non‑AC systems like Park Assist?
The CCM publishes requests and status on the shared bus to other controllers, so its fault lists can include non‑HVAC systems. That’s normal for networked architectures designed to save wiring. [Elektroda, Hektar Zahler, post #16686370]
Can I keep driving with CCM‑0070 if cooling still works?
You can, but it’s risky. Intermittent communication faults can escalate and immobilize the vehicle or disable safety functions without warning. Fix the network first, then verify all systems in VIDA. [Elektroda, Hektar Zahler, post #16698177]
What modules/sensors on the climate network can set CCM‑0070?
Examples include damper motor modules (DMM), seat heating modules (SHM), and the air quality sensor (AQS). Loss of their messages at the CCM can set CCM‑0070. [Elektroda, Hektar Zahler, post #16688170]
VIDA shows many hints—how do I prioritize?
Treat active bus errors as top priority. Restore communication, then re‑scan. After network health is confirmed, chase remaining module‑specific hints or configuration items. This avoids chasing ghosts from a sick bus. [Elektroda, Hektar Zahler, post #16688010]
Does disconnecting the battery clear CCM‑0070?
No. Power resets won’t repair physical bus issues, missing terminators, or bad connectors. The code returns until communication integrity is restored and verified. [Elektroda, Anonymous, post #16685817]
What’s the practical order of operations if I just bought this V70?
Scan with VIDA/DiCE, note active comms faults, repair bus wiring/termination, verify module power, then calibrate and code as needed at ASO. Avoid coding on a faulty bus. [Elektroda, Hektar Zahler, post #16698177]
