The boiler with a coil heats only part of the water from the top
Agula158 6246 5
  • #1 16687026
    Agula158
    Good morning
    I am asking for your help.
    I have central heating installations, house heating and a boiler with a horizontal coil, the water in the tank heats up only a little (by checking it, about 5 cm from the top, the tank is hot and the rest is winter and the result is one shower and the end of hot water). There is no air in the installation (input and output correspond to the temperature on the stove). Whether I smoke shorter or longer with a temperature of 90 on the stove, the effect is the same. Should the boiler be installed exactly horizontally or at an angle? It happens from the very beginning, not even once did the tank be completely warm? I am asking for advice and help with what it may be caused.
    best regards
  • #2 16687054
    gersik
    Help: 164
    Rate: 639
    Pictures and installation diagram, please. The boiler should be horizontal.
  • #3 16687162
    tronics
    Help: 358
    Rate: 840
    What a colleague describes is impossible. If the return from the coil has a specified high temperature, the water in the DHW at this connector should be the same. Depending on the shape of the coil, a different part of the tank will be heated, while a horizontal double-jacket tank and a vertical one with a coil are the best. If the return from the domestic hot water is hot and there is little hot water, I would see the poor coil as the fault.
  • #4 16687189
    Agula158
    If there is something wrong with the coil, it remains to replace the boiler?
  • #5 16687228
    tronics
    Help: 358
    Rate: 840
    Have a colleague answer question first. colleague Gersik, give the exchanger model and see what can be done.
  • #6 16687381
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    If the boiler has coils as shown in the picture and is installed the other way around, it will appear exactly as the author of the post describes.
