Washing machine Beko WMB 61011 PL N - It does not pump out my water and does not
laiczka71 13134 2
  • #1 16689405
    laiczka71
    Hello!
    I need help with my washing machine. It does not pump out my water and therefore does not spin the laundry. When I release the water, the filter spins. And one more thing: when it is spinning, it seems as if all the whirled water does not drain away, but goes back to the washing machine ...
    Added after 35 [minutes]:
    I would like to add that during the "pump down and spin" program the washing machine behaves as if it was washing. He's not going to pump ...
    smielnicki
    Help: 9
    Rate: 10
    Drain the water from the washing machine through the filter, and there is a turbine behind the filter in the pump, which you can see when looking at the hole where the filter is removed. Turn the turbine to make sure it is not blocked, and then blow out the drain hose by blowing the hose from the outlet to the sewage system. When the turbine rotates and the hose is not clogged, reassemble the filter and run the washing machine on the rinse-test.
  • #3 16690127
    laiczka71
    The turbine is ok, it's spinning ... The hose is also blocked ... I suspect that the pump pumping out the water does not work ...
    Added after 14 [minutes]:
    Ha! I forgot to add that I found 10 cents in the turbine! And I think that was the reason because the washing machine WORKS!
    smielnicki - thank you for your help! Problem solved - I'm closing the topic.
