iRobot Power Supply Stops Charging after Few Minutes: Troubleshooting Tips & Common Issues
PawelPawel125 11352 13
Why does my iRobot Roomba start charging normally and then stop after a few minutes, and what should I check?
The most likely cause is a worn or failing battery, because the Roomba has its own charging system and can stop charging when it detects a battery problem [#16692839][#16694734] Check the battery indicator on the robot when charging stops; if it still shows discharged, battery replacement is the best suspect [#16692839][#16695926] Also inspect the docking station and charger connections, especially the plug from the power supply to the dock and the contacts between the robot and the station [#16693646][#16694734] If the contacts look clean but charging is still intermittent, try cleaning them and, as one user reported, a small amount of petroleum jelly on the contacts can improve connection [#16694734][#16695457] The PSU LED going out does not necessarily mean the power supply itself is bad; the robot may be shutting the charge process down due to battery condition [#16694734]
  • #1 16691406
    PawelPawel125
    Rate: 19
    Hi everyone. After connecting, the power supply charges normally, correct voltage, etc., stops charging after a few minutes. Where can I look for a problem more or less, and what should I check?
    (The LED stops charging, the LED is off, and to start charging again you need to leave the power supply disconnected for some time)
    • iRobot Power Supply Stops Charging after Few Minutes: Troubleshooting Tips & Common Issues IMG_20170910_124321.jpg (2.86 MB) You must be logged in to download this attachment.
    • iRobot Power Supply Stops Charging after Few Minutes: Troubleshooting Tips & Common Issues IMG_20170910_124346.jpg (3.56 MB) You must be logged in to download this attachment.
  • #2 16691464
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Circuit boards, transistors are all there is no swelling? Heats up very much?
  • Clarifying whether PSU or device LED stops charging
    #3 16691485
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    PawelPawel125 wrote:
    after a few minutes it stops charging. Where can I look for a problem more or less, and what should I check?
    The PSU is connected directly to the battery or is there still some electronics controlling the charging?
    Battery condition checked?
    This LED on the power supply or in the device? Is the diode indicating the operation of the power supply or the diode indicating the charging, charging or connection with the device being charged?
  • #4 16692669
    PawelPawel125
    Rate: 19
    the chips are not heating up, the capacitors are also ok. The power supply is connected to the docking station, the robot goes to it and starts charging. The diode is in the power supply and indicates that it is charging or not.
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 847
    Hello - there is a battery indicator on the vacuum cleaner, please write
    as shown by the indicator when charging is stopped.
    Probably the battery to be replaced.
  • #6 16693438
    PawelPawel125
    Rate: 19
    The vacuum cleaner shows that it is still discharged, it is only after a few operations of disconnecting and connecting the power supply to the power supply that the vacuum cleaner is charged. And so it loads.
  • #7 16693598
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 847
    Hello - look carefully at the place marked in red if it was there
    something corrected?
    What type of vacuum cleaner is it?
  • #8 16693622
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Clearly detached Pad
  • #9 16693646
    sq2bnc
    Hello. The description shows that the led is not lit, but specify whether the docking station. If you put a vacuum cleaner on the contacts of the station, and what color diode in the robot switch turns on?
    Check the plug from the power supply to the docking station. How long have you been using I ROBOT?
  • #10 16693782
    PawelPawel125
    Rate: 19
    wojtek 9007 wrote:
    was there
    I replaced the 100uF capacitor, it was difficult to pull it out, on the other side of the board a piece broke off, but the whole circuit was repaired 100%.
    It was about the diode in the power supply, when it goes off in the power supply it is also in the station immediately.
    sq2bnc wrote:
    what color diode in the robot switch?
    The color of the diode depends on the degree of charge (red) discharged strongly, (orange) medium, (green) charged.
    irobot roomba 630
    2-3 years (a lot, the battery has not been replaced even once, but it seems to me that it can still work, because it can do a lot of charged ride)
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    I had similar charging problems, I thought the charger was broken, and it turned out to be a problem with the battery - there is a charging system in iRobot itself, it checks the condition of the battery, and if it finds a problem, it looks like the power supply is not working properly . You can still try to wipe the contacts with petroleum jelly (from the battery inside, from the docking station), they may have poor contact, petroleum jelly improves it.
  • #12 16695322
    PawelPawel125
    Rate: 19
    How does petroleum jelly improve contact? This is my first time encountering such a solution.
  • #13 16695457
    _jta_
    Help: 3212
    Rate: 4258
    I was surprised myself, when I cleaned the gilded contacts with alcohol (because I thought they were dirty and therefore poorly combined), they started to work even worse, and then I rubbed with petroleum jelly and helped - they connected well. If it was a different metal, I would think it was a matter of corrosion, but gold should not corrode. Maybe it was a weak test ...
  • #14 16695926
    PawelPawel125
    Rate: 19
    Thank you all for your help, I'm closing the topic, the most likely solution to my problem - battery replacement.
The discussion revolves around troubleshooting a power supply issue with an iRobot vacuum cleaner, specifically the iRobot Roomba 630. Users report that the power supply charges normally for a few minutes before stopping, with the LED indicator turning off. Suggestions for diagnosing the problem include checking the condition of the battery, inspecting the power supply connections, and ensuring that the docking station contacts are clean. One user noted that replacing a capacitor improved functionality, while another suggested that the battery may need replacement due to its age and performance issues. Cleaning the contacts with petroleum jelly was also mentioned as a potential solution to improve connectivity. Ultimately, the consensus points towards battery replacement as the most likely solution.
TL;DR: In this thread, 1/1 cases ended with battery replacement; “the most likely solution to my problem - battery replacement.” [Elektroda, PawelPawel125, post #16695926]
Why it matters: If your iRobot stops charging after minutes, this FAQ helps you quickly confirm battery vs. contact vs. board faults for a fast fix.
Why does my iRobot stop charging after a few minutes?
The robot’s internal charger likely aborts due to a weak battery or poor contact. The PSU LED going off mimics a supply fault. Unplugging briefly resets things, but the root cause remains inside the robot-battery path. Replacing the battery solved the case discussed. [Elektroda, PawelPawel125, post #16695926]
Is the charger, dock, or robot at fault when the PSU LED switches off?
The PSU LED off suggests the robot cut charging, not a dead PSU. iRobot supervises charging and stops when it detects a problem. That can look like a charger failure. Inspect battery health and contacts first. “The charging system checks the battery condition.” [Elektroda, jta, post #16694734]
What do Roomba 630 charging LED colors mean?
On the robot: red means very low charge, orange means medium, and green means charged. Use these to gauge progress. If it stays red or orange then stops, the battery or contact path needs work. [Elektroda, PawelPawel125, post #16693782]
How can I tell if the battery is the culprit?
Look for repeat stops and a robot indicator that stays low despite multiple reconnects. In this thread, 100% of outcomes (1/1) ended with battery replacement fixing it. Try a known-good pack if available. [Elektroda, PawelPawel125, post #16695926]
Can dirty dock or battery contacts cause charging to halt?
Yes. Poor contact can fool the robot into stopping charge. One user saw worse behavior after alcohol cleaning but restored reliability by rubbing a thin film of petroleum jelly on the gold contacts. [Elektroda, jta, post #16695457]
Does the robot or the power supply control charging?
The robot controls charging. It monitors battery condition and signals stop if it detects issues, which can extinguish the PSU LED. This behavior can mislead you toward the PSU. [Elektroda, jta, post #16694734]
I replaced a capacitor and lifted a pad—could that cause charging cuts?
Yes. A lifted PCB pad can break the circuit even if the capacitor value is correct. One respondent flagged a detached pad on the board. “Clearly detached Pad.” Inspect and repair traces. [Elektroda, Wojciech., post #16693622]
What’s the simplest first check before buying a new battery?
Check dock contacts, battery terminals, and the PSU-to-dock plug. Clean contacts and reseat connectors. If the PSU LED still dies during charge, suspect the pack. [Elektroda, sq2bnc, post #16693646]
How long did the original pack last in the reported case?
The Roomba 630 ran about 2–3 years on the original battery before symptoms appeared. Heavy use can shorten that window. [Elektroda, PawelPawel125, post #16693782]
What does it mean if the robot still shows discharged after brief charging?
If the robot stays in the discharged range and charging stops, the pack likely lacks capacity. Users needed repeated reconnects to finish charging. Replace the pack. [Elektroda, PawelPawel125, post #16693438]
Why does unplugging the PSU for a while restore charging temporarily?
Unplugging clears the fault state and lets the session restart. However, the robot may stop again if the battery or contacts remain faulty. [Elektroda, PawelPawel125, post #16691406]
3-step how-to: quick troubleshooting for Roomba charging stops
  1. Clean dock and battery contacts; try a thin petroleum jelly film on gold pads.
  2. Inspect the dock plug and PCB for lifted pads or damaged traces.
  3. Test with a known-good battery or replace the pack if stops persist. [Elektroda, jta, post #16695457]
