ILIFE V7s Pro Robot Vacuum cleaner - The robot stops when switched on
Derbi7 26985 11
Why does my robot vacuum stop moving when the cleaning cycle starts, and how can I fix it?
Clean the robot thoroughly, especially the sensors, wheels, brush area, fan, and any dust-packed gaps, because a hidden clog can make it stop during cleaning [#17813714] In one case, the real problem was dust collected in the narrow gap of the yellow lid around the so-called turbo brushes; after removing that dust, the robot started working again [#17813714] Disconnecting the battery first and vacuuming out all the nooks was also part of the fix attempt [#17813714] Another user confirmed that this same cleaning step solved the problem for them too [#17818457]
  • #1 17314117
    Derbi7
    Rate: 13
    Hello, I have a problem with this vacuum cleaner after turning on the cleaning function starts from Zabrze backwards and stops turning when it is turned. If I turn off the return to the base, it goes and looks without any problems what to do with it
  • #2 17314145
    omnixcrs
    Help: 8
    Rate: 60
    Maybe some software update ??
  • #3 17317092
    Derbi7
    Rate: 13
    Any other suggestions, and how should I update this software?
  • #4 17321342
    Jaclyn
    Rate: 12
    I have the same problem . I have already checked several elements, I cleaned the dust and collected hair on a brush or its wheel and there is still a problem ...
  • #5 17321863
    Derbi7
    Rate: 13
    I have to look for a mechanic from such robots in Lodz. Maybe they'll fix mine under warranty, but I don't know how to contact them, I wrote an email, but no echo ...
    I have corrected TONI_2003
  • #6 17323647
    Musiol
    Help: 13
    Rate: 165
    Are there any lights on the device that could indicate an error code?
    How old is the device, in what condition are the batteries?
  • #7 17324028
    Derbi7
    Rate: 13
    Hello, my vacuum cleaner is 6 months old, but it has been standing for two and the indicator is only one from turning on.
  • #8 17324453
    Musiol
    Help: 13
    Rate: 165
    Derbi where did you buy this robot I would advertise the device for 6 months. Have you looked at the manuals, the fault section? Does the indicator turn off or flash when the fault occurs?
  • #9 17448587
    Clarittka
    I have the same problem, I bought on Ali in April. Were you able to "move it"?
  • #10 17467010
    Bukov
    If anyone is interested I can try to fix this problem. I have succeeded several times.
    tel. 600 54 22 66
  • #11 17813714
    Ratec
    I had the same problem, but I managed to remove it in a fairly trivial way. However, I'm not entirely sure what worked, but I thoroughly cleaned all the sensors, and it didn't work. Later, I disconnected his battery, cleaned the wheels, unscrewed the brush, fan and other nooks, vacuumed all the gaps with a regular vacuum cleaner. However, at the end I noticed that a lot of dust was collected in the gap of the yellow lid from the so-called turbo brushes. It is so narrow from the side of the bevelled corner, when I took the dust out of it, it started to whip when I was young :)
    pzdr
    :arrow: I have corrected TONI_2003
  • #12 17818457
    DoriLori
    Rate: 8
    pzdr
    It worked! And I was about to send the robot to the site, thanks a lot! :)
The discussion revolves around issues with the ILIFE V7s Pro Robot Vacuum cleaner, specifically that it stops moving when the cleaning function is activated. Users suggest potential solutions, including performing a software update, checking for error codes indicated by lights on the device, and inspecting the condition of the batteries. Several users report similar problems, with some having success by thoroughly cleaning the sensors, wheels, and internal components, particularly removing dust from tight spaces. One user mentions contacting a mechanic for warranty service, while another offers assistance in fixing the issue.
TL;DR: If your ILIFE V7s Pro stops when turning, 2 users confirmed a cleaning fix—"a lot of dust was collected in the gap of the yellow lid." Deep‑clean the yellow turbo‑brush cover slot and sensors to restore movement. [Elektroda, DoriLori, post #17818457]
Why it matters: This FAQ helps ILIFE V7s Pro owners quickly fix reversing/turn‑stop faults without unnecessary service calls.
Why does my ILIFE V7s Pro reverse or stop when it starts turning?
Hidden debris in the turbo‑brush cover slot can create abnormal load or obstruction. The control system halts movement during turns when resistance spikes. Basic sensor cleaning may not reach that packed dust. Remove the yellow cover and clear the narrow side slot. Clean wheels and brush mounts too. Users reported normal operation after this deep clean focusing on the yellow cover gap. [Elektroda, Ratec, post #17813714]
What’s the quick 3-step fix for the “stops when turning” issue?
  1. Power off, flip the robot, and remove the yellow turbo‑brush cover.
  2. Clear the narrow slot at the beveled corner; pull out packed dust and hair.
  3. Clean cliff/dock sensors, wheels, and brush housings; optionally unplug the battery for one minute, then reassemble. This simple routine restored movement for a user. [Elektroda, Ratec, post #17813714]
Where exactly should I clean to restore normal operation?
Target the yellow turbo‑brush cover, especially the thin slot along the beveled corner. That’s where dust compacts and binds. "A lot of dust was collected in the gap of the yellow lid," reported one user. Use a soft brush or tweezers to remove debris, then wipe sensors. Reinstall the cover securely and test turning. [Elektroda, Ratec, post #17813714]
Does disabling Return‑to‑Base help diagnose the fault?
Yes. One user found the robot moved normally after disabling Return‑to‑Base. That suggests docking sensors or related logic could be triggering the stop. Use this only as a diagnostic step. Complete the deep cleaning before re‑enabling Return‑to‑Base. [Elektroda, Derbi7, post #17314117]
I cleaned the sensors and it still stops—what should I try next?
Go deeper. Remove the yellow brush cover and clear its narrow slot and corners. Clean wheels, brush bearings, and the fan area. Disconnect the battery briefly for a reset, then retest. A user said sensor cleaning alone didn’t help, but deeper cleaning fixed it. [Elektroda, Ratec, post #17813714]
Could the battery or storage time be the cause?
Check battery connections and charge level during troubleshooting. One reported unit was 6 months old and unused for two months when the issue appeared. Still, the effective fix others used was mechanical cleaning and a brief battery reset. If power issues persist, seek warranty support. [Elektroda, Derbi7, post #17324028]
Is there a firmware or software update that solves this?
A member asked how to update the software, but no update steps were provided in the thread. The practical fixes shared centered on thorough cleaning and a battery disconnect reset. Contact your seller or ILIFE support for official firmware guidance. [Elektroda, Derbi7, post #17317092]
How do I hard reset the V7s Pro safely?
Power off the robot. Open the battery bay and unplug the battery connector for about one minute. Reconnect the battery, reassemble, and test again after cleaning. Do not short or puncture the battery. This reset was used alongside cleaning by a member. [Elektroda, Ratec, post #17813714]
What do the indicator lights mean when it fails?
Watch whether the indicator turns off or flashes during the fault. Then consult the manual’s fault section for the pattern meaning. Capture the behavior when contacting support. As one member asked, "Have you looked at the manuals, the fault section?" [Elektroda, Musiol, post #17324453]
When should I use warranty versus DIY cleaning?
Use warranty if the robot is still covered or LEDs show a fault after deep cleaning and a reset. A member suggested returning a 6‑month‑old unit for repair. Document symptoms and what you cleaned before contacting the seller. [Elektroda, Musiol, post #17324453]
I bought mine on AliExpress—who can repair it?
One user noted they purchased on AliExpress and sought a fix. Start with the seller’s after‑sales channel and ILIFE support. If that fails, try the cleaning steps here and then contact a local robot vacuum technician. [Elektroda, Clarittka, post #17448587]
Can a third‑party technician actually fix this problem?
Yes. A forum member offered repair and reported solving this fault several times. Experienced technicians can clear mechanical jams and related issues. Share your symptom details and what you already cleaned. [Elektroda, Bukov, post #17467010]
Is this issue happening to others?
Yes. At least one other member reported the same stop‑when‑turning symptom and tried cleaning hair from the brush and wheels. If that fails, perform the deeper brush‑cover slot clean and reset. [Elektroda, Jaclyn, post #17321342]
