Xbox One Wired Controller Connection: Micro USB vs Mini USB Cable Compatibility
szarik1404 7020 4
  • #1 16693330
    szarik1404
    Help: 23
    Rate: 124
    Hello, I recently bought an Xbox One plus two battery-powered pads that connect wirelessly to the console. However, I wanted to connect them with a micro usb cable, such as for charging the phone, it turns out that the mini usb does not fit. Please advise what cable to buy.
  • #2 16693913
    sosarek
    Help: 9320
    Rate: 15532
    What charging connector do you have in your phone, maybe USB type C and not mini?
    Z
    Pka, Poznań, 60-850
  • #3 16694591
    szarik1404
    Help: 23
    Rate: 124
    I think I have like most, cables from other telephones fit, and in these pads it is somewhat larger.
  • #4 16694640
    lysy1980
    Help: 209
    Rate: 324
    The pad has 2 slots. Which ones are you trying to push into?
  • #5 16694861
    szarik1404
    Help: 23
    Rate: 124
    Thank you, right - the latter fits in, best regards and I close it.
