UPC Router Exchange: Technicolor TC7200.U vs Motorola Box SB5101 - Which is Better?
tomasz.s 7596 8
  • #1 16695112
    tomasz.s
    I have a question about which router model to ask for when installing UPC?
    As part of the ending contract with UPC, I agreed to exchange a Technicolor TC7200.U router because it hangs frequently and has poor wifi coverage. I got a proposal to install a Motorola box sb5101, because it has better antennas. Is it really worth exchanging for this model or maybe some other? [/ B]
  • #2 16695140
    VooVoo
    Help: 215
    Rate: 266
    Any modem with built-in antennas is worse than a router with antennas on top. As for the better one, I don't know. I know that depending on your home equipment (I hope you have new ones), you should ask for a router working in both bands, i.e. 2.4 and 5 GHz. In the 5 GHz band it is much looser and the devices work better.
  • #3 16695216
    tomasz.s
    Thanks for the advice. It looks like both have built-in antennas. Maybe anyone else has any insights on this topic?
  • #4 16695264
    VooVoo
    Help: 215
    Rate: 266
    You should scan with the application on a smart type of wifi analyzer or bald inssider on which channel your modem is working and see if it is impossible to change the channel to another, where it is looser.
  • #5 16695273
    tomasz.s
    In addition to the poor wifi range, the problem is also that the current router (TC7200.U) often freezes, so I want to replace it, so I will rather not try to leave it at all costs by changing the settings. This router is pretty old for me (I already have it for over 3 years) and probably are better, the question is whether UPC has something better on offer?
  • #6 16695284
    VooVoo
    Help: 215
    Rate: 266
    Ask for Cisco / Techicolor 3928 AD.
  • #7 16695637
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Rather Compal CH7465LG.
    tomasz.s wrote:
    the question is, does UPC have anything better on offer?
    Better than what I indicated above - no.
    They do have Ubee (but he only bonds up to 8 DS channels, so if you think about a 500 Mb network, Ubee can't do it).
    UPC does not own or offer such equipment.
    There are also problems with this Compal (jumping ping - though this has already been corrected), but there is a problem with the PUMA6 processor on the basis of which this Compala was built.
    Paradoxically, despite such problems, you are doomed to Compal (but here I would recommend modem mode and my own router).
  • #8 16695650
    tomasz.s
    Many thanks once again :) .
  • #9 16695669
    KOCUREK1970
    Help: 3860
    Rate: 5488
    As a consolation, I can add that unofficial rumors are preaching :) that in the first quarter of 2018 Intel is to completely "fix" Compala by releasing software for it that will fix ping and a problem with the processor (unfortunately this is not just a few lines of code - you just need to create again with new executable libraries for processor and chipset, change the rules of "polling" by the processor of commands issued by the client, etc.).
    Currently tests are underway at Intel, then it will be soft tested at operators, then beta testers will receive soft test and after confirming the absence of problems (although other problems will probably appear) ;) ) all users of these devices will receive the software.
    As a curiosity, I can add that UPC Polska is the first! he reacted to problems with Compal and implemented soft, based on which other operators in the UK, Switzerland and Germany did so.
The discussion revolves around the user's experience with the Technicolor TC7200.U router, which frequently hangs and has poor Wi-Fi coverage. The user is considering exchanging it for a Motorola SB5101, which is suggested to have better antennas. Responses highlight the importance of choosing a router with external antennas and dual-band capabilities (2.4 GHz and 5 GHz) for improved performance. Recommendations include the Cisco/Technicolor 3928 AD and Compal CH7465LG, with notes on potential issues related to the Compal's PUMA6 processor. Users express concerns about UPC's equipment offerings and the need for better alternatives, while also mentioning upcoming software fixes for the Compal model.
