Resolving ID-MAC Incompatibility Issue with Integra 64 v1.15 and ETHM 1 Plus v2.05 Control Panel
bartek0808 13218 10
Why does the Integra Control app show MAC/ID incompatibility and fail to connect to an Integra 64 with ETHM-1 Plus from outside the local network?
The connection problem was caused by incorrect router configuration: one router port was not set for WLAN, so the panel could not connect externally through the Satel server [#16698428] You do not need a public IP; the ETHM can use an address from DHCP or a manually assigned local IP [#16695523] Since it already worked over the internal Wi‑Fi network, the ETHM and MAC/ID entries were basically correct and the fault was on the router/ISP side [#16695752][#16696340] Check the router for the required port forwarding or pass-through options, and if needed change the default HTTP port to another value such as 8080 [#16696340][#16695877]
  • #1 16695242
    bartek0808
    Help: 29
    Rate: 23
    Integra 64 v 1.15 and ethm 1 plus v 2.05 control panel
    Unfortunately, I cannot connect using the integra control application.
    After entering the MAC address and id I get information about the incompatibility between MAC and ID.
    Can anyone send the settings because I can not find the instructions?
    Does IP have to be set as public?
    best regards
    Advertisement
    Also read:
    ETHM 1 Plus / Integra Control. Selected Issues
    Remote view of the recorder or camera on the network. General information + configuration examples
    We invite you to familiarize yourself with other guides, featured topics, articles on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides on security systems
    If the above topics do not find the answer to your question, please visit the forum:
    Security Systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those starting their adventure with electronics:
    General Guides
  • #2 16695374
    sosarek
    Help: 9321
    Rate: 15545
    MAC and ID correctly rewritten?
    ETHM connected to the network?
    Z
    Pka, Poznań, 60-850
  • #4 16695752
    bartek0808
    Help: 29
    Rate: 23
    Thank you for the answers, gentlemen :) , unfortunately they do not solve my problem. : /
    I have read the instructions to ETHM and I have read :)
    In the internal network (WiFi) I am able to connect
    However, I can not connect from the external network via the satellites server, I entered the required data manually and using a QR code
  • #5 16695820
    sosarek
    Help: 9321
    Rate: 15545
    Which supplier do you use? Have you redirected the appropriate ports?
    Z
    Pka, Poznań, 60-850
  • #6 16695873
    bartek0808
    Help: 29
    Rate: 23
    The internet provider is INEA.
    I do not have access to the router for now,
    If you can specify which ports and which ports to route, I will pass this information to the technician from the provider :)
  • #7 16695877
    sosarek
    Help: 9321
    Rate: 15545
    All ports you have listed above in the image, change the default HTTP to another, e.g. 8080.
    Z
    Pka, Poznań, 60-850
    Mar_rcin
    Help: 7
    Rate: 8
    Why forwarding ports?
    After all, the subject is marked that it is about connectivity via the Satel server.
    The only thing you can check in the router / on your part are the options:
    IPSec Pass-Through
    PPTP Pass-Through
    L2TP Pass-Through
    under the vpn tunnel (I do not know what the Satel vpn works on), they are included.
    Alarmy Krakow
    os. Krakowiaków 45A, Kraków, 31-964 | Tel.: 607XXXXXX (Show) | Company Website: https://alarmy.krakow.pl
  • #9 16696565
    bartek0808
    Help: 29
    Rate: 23
    Thanks to Mar_rcin for hints, I will try to ask someone from INEA today.
    And I still have a question regarding push notifications, I understand that they come to the user who is logged in by applications to the headquarters?
    And if so, does the application work in the background?
    And do I make any mistake or just the way it is, that the change in macros is not taken automatically, but I have to delete and add the system again?
    Push notifications work in background via Satel server
    #10 16697385
    Mar_rcin
    Help: 7
    Rate: 8
    Push notifications work on all smartphone-applications that are logged into this particular exchange.
    In the IC application you choose which push notifications should be sent eg to alarms, events, failures, etc.
    in the smartphone system - I have just IOS you can lock them at all, or set as a banner or as an alarm, it's probably the same in the android. Push notifications only work in configuration via the Satel server.
    The application works very well in the background, even if I close it by IOS, or in IC application disconnect, push notifications and so come.
    That's exactly what I do not know and I do not have a check right now, but it seems to me that I need to set up access again.
    After all, look in the edit settings if there is no option to bind macros.
    Alarmy Krakow
  • #11 16698428
    bartek0808
    Help: 29
    Rate: 23
    Ok
    Thanks very much for the answer :)
    The problem was solved, it was so bloated that I did not stop at it immediately and maybe the hour was no longer appropriate :)
    The reason for the lack of connection was the port on the router that was not configured to
    WLAN.
    Subject to be closed
The discussion revolves around resolving an incompatibility issue between the Integra 64 v1.15 and ETHM 1 Plus v2.05 control panel, specifically regarding connectivity through the Integra control application. The user experiences a MAC and ID incompatibility error when attempting to connect. Responses suggest verifying the MAC and ID entries, ensuring the ETHM is connected to the network, and configuring the device to obtain an IP address from the DHCP server. The user also faces challenges connecting externally via the Satel server and is advised to check port forwarding settings on their router. Ultimately, the issue was resolved by configuring the appropriate port on the router for WLAN access.
