Seeking Durable and Affordable Chain Alternatives for Stihl MS 180 Chainsaw
zwyklyludzik 10290 9
What durable, affordable replacement chain should I buy for a Stihl MS 180, and what specs do I need to match?
Buy a good-quality chain from a reputable brand like Oregon, but make sure it matches the saw’s pitch, gauge/link thickness, and number of drive links before ordering [#16323796][#16323885] If you often cut dirty or sandy wood, a half-chisel chain is a better choice because it resists dulling better than a full-chisel chain, though it cuts a bit slower [#16323801] A small MS 180 is likely meant for a smaller pitch chain rather than 3/8
  • #1 16323756
    zwyklyludzik
    Rate: 19
    How to buy a chain for a small chainsaw Stihl MS 180 So far, a chain was bought in the Stihl store for about PLN 34 / item. Because this original chain gets dull quickly, so maybe there is no need to overpay? We thought that maybe we could buy something much cheaper and durable
    Can you drop something, any examples? (the name of the manufacturer does not matter as long as the quality is ok)
    As a layman in petrol saws, I would not want to buy some junk, and buying 3 chains per season is starting to be an expensive solution
    Greetings
  • #3 16323801
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    zwyklyludzik wrote:
    Because that original chain gets dull quickly
    But the chains are sharp. :D
    If, however, the chain of a good company is better than the "no name" ones, only proper exploitation and service of this, let's say, quite simple element of the saw is needed.
    However, if you cut wood, so to speak, "dirty", sanded, contaminated, I would advise a chain of the so-called "half chisel" is a bit more resistant to blunting when cutting such wood as I indicated above, except that its efficiency is slightly lower than the "full chisel" chain, but even such a chain also needs to be properly sharpened and operated, sharpened, etc. - nothing is not eternal ...
    Chain sharpening:
    http://pilarz.org/viewtopic.php?f=55&t=1433&p=12394&hilit=ostrzenie+%C5%82a%C5%84cucha#p12394
    http://www.stihl.pl/ostrzenie-pily-lancuchowej.aspx
  • #4 16323848
    zwyklyludzik
    Rate: 19
    I try to take care of the equipment. After a few hours of work (i.e. probably in the summer, once a month) I clean the saw quite reliably. I remove the side casing, chain. It seems to me that I care about the tool (I was taught this) but without being overly exaggerated :roll: It's a machine, after all, not a shiny conference table :lol:
    We use saws in the family for allotment and home tasks, not professional. Cutting small trees that grow back, sometimes cutting boards for a new outhouse, sometimes cutting logs of firewood before winter. The fact is that the wood is made of earth, it was lying somewhere on the ground, I do not check its cleanliness but I cut it :wink: The problem is that these original Stihl chains get dull for a company store, and they are not cheap. Maybe it should be like that?
    On average, 3 chains a year go We even gave them for sharpening (to a store where we bought a cheap Stihl saw) because it is a cheaper solution Unfortunately, the sharpened ones cut worse, finish faster Sharpening in this original Stihl store is PLN 12 / item (maybe more than elsewhere but it's a professional hardware store after all)
    Oh, we were offered a chain with longer blades at this store. Same price. Reinforced or something Worth a try? :?:
    We bought a Stihl saw for about PLN 1400, because the Chinese (for less than PLN 200) died after a month (the engine stopped working)
    How so, it would turn out that your own Stihl saw is not a cheap party? :roll:
    Greetings
  • #5 16323859
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    zwyklyludzik wrote:
    sharpening in this original Stihl store is PLN 12 / item
    Expensive. We have 5 to 10, depending on what "sharpening range" ...
    zwyklyludzik wrote:
    On average, 3 chains per year go
    How many cubic meters will you do with this?
    I cut the blade myself, normally with a file, at the beginning I used the file guide, but now "after practice" it is unnecessary for me, all I need is a round and flat file of the right size to file the limiters.
  • Hand-sharpening saves costs; reinforced chain may be worth trying
    #6 16323863
    zwyklyludzik
    Rate: 19
    Meters? 8-O Oh, maybe a meter, maybe 2 cubic meters max
    We were proposed in this store chain with longer blades Same price Strengthened or something Worth a try? :?:
  • Chain life depends on sharpening and saw pitch
    #7 16323885
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Ojojoj, it is extremely modest. for three chains. When you were still working (old times) with a saw (small cuttings and wood cutting for the neighbors and anyone who had such a need), this was the result on one or two chain sharpeners, and the chain is still operational and still for long use. Sometimes 6.8 liters of fuel were burned a day and all on one chain (well, not exactly like that, because they were always sharpened in the morning, because it is easier to change a sharp chain like "sharpen" in the field), but they were functional throughout the season and even longer. There is also the question of what chain you have in this saw (which can be used with this saw), for me the pitch is 3/8 inch, and with this small Stihl there is certainly one with a smaller pitch and not very intended for heavy, intense work and with lower efficiency, rather for light cutting branches than for cutting thick logs, because the efficiency and power of the saw are also not that right.
  • #8 16327229
  • #9 16328729
    zwyklyludzik
    Rate: 19
    Kurtka na wacia wrote:
    zwyklyludzik wrote:
    then I lubricate the guide bar and the guide wheel with oil to keep it running nicely.
    And do you pour chain oil into the saw?
    Yes Yes of course! I admit that I poured a car one for lack of lacquer :wink: He was on hand in the car (15W40)
    Oh, by the way, I noticed that when there is some oil left in the tank and I put the saw away while it is idle, it gets a tiny spot underneath. Just oil for lubrication. Is this normal?
    Greetings
  • #10 16328789
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    zwyklyludzik wrote:
    Is it normal?
    How small is normal.
The discussion revolves around finding durable and affordable chain alternatives for the Stihl MS 180 chainsaw. The original Stihl chains are criticized for dulling quickly and being expensive, prompting the user to seek cheaper options without compromising quality. Recommendations include OREGON chains, which are noted for their quality, and the importance of knowing the chain's pitch, link thickness, and number of links when purchasing. Users also discuss the benefits of sharpening chains and suggest considering "half chisel" chains for cutting dirty wood, as they are more resistant to blunting. The conversation touches on maintenance practices, including the use of proper chain oil and the normality of minor oil leakage when the saw is idle.
